POV-Ray : Newsgroups : povray.advanced-users : how can a square mesh be changed to a rhomboid Server Time
3 Jul 2024 04:30:06 EDT (-0400)
  how can a square mesh be changed to a rhomboid (Message 11 to 16 of 16)
Subject: Re: how can a square mesh be changed to a rhomboid
Date: 9 Aug 2010 17:42:03
Message: <4c60762b$1@news.povray.org>
> I have a DTM (digital terrain Map) which is square, a mesh comprising of 140,000
> smooth triangles. I need to adjust the map for convergence - difference of the
> grids north to the earths true north. The adjustment would result in a rhomboid
> where the top-left corner might be rotated by, say 3 degrees from the
> bottom-left corner and the top-right corner rotated by 2 degress from the
> bottom-right corner.
> Does anybody have an idea on whether this can be achieved in POV-Ray?
Normaly, for most maps, the sides are parallel to the local longitude,
and the top and bottom are parallel to the local latitude.
If I read correctly, you don't realy want a rhomboid but a trapezoid or
something close to that. (top and bottom sides are parallel, but the
sides are NOT parallel)
Furthermore, the sides don't seems to stay straight, but somewhat curves
out on the sides and bottom, and curven IN for the top.
What I think you /realy/ want is to treat the DTM as a
longitude/latitude object and map it on a sphere, keeping the sides
parallel to the latitude and longitude lines of the sphere.
If I'm right, then, the other answers are not what you need. You need a
spherical transformation of every vertex of the mesh. Then, most
straight lines traced on the map will become curves.
It can be done, but involve much more work than a simple matrix
operation. You need to scan the raw mesh array using loops and transform
every point individualy from rectangular coordinated to spherical
coordinates.
Date: 10 Aug 2010 01:11:33
Message: <4c60df85@news.povray.org>
davidafisher <dav### [at] coppernet> wrote:
> x   |-446.448|   | 1+20.4894,  0.8421,    -0.247    |   |x|
> y = | 125.157| + |-0.8421,     1+20.4894,  0.1502   | * |y|
> z   |-542.06 |   | 0.247,     -0.1502,     1+20.4894|   |z|
  Well, that looks to me like a matrix transformation and a translate.
Why don't you simply try it?
Date: 10 Aug 2010 05:55:30
Message: <4c612212$1@news.povray.org>
Am 09.08.2010 21:52, schrieb davidafisher:
> New                                                   current
> but I don't know how the matrix command works within POV-Ray and whether it can
> be used in this manner. My mind has stopped working and I'm stuck on thinking I
> have to build a separate routine to parse and convert every triangle coordinate
> within the mesh
No, this is exactly the kind of job the POV-Ray "matrix" statement is
made for. See section 2.2.7 "POV-Ray Coordinate System" of the
documentation, subsection 2.2.7.1.4 "Matrix", for how the 12
coefficients are interpreted.
I must confess I'm not too familiar with the mathematical notation of
matrices, but I /think/ the parameters should be as follows:
New                                   current
x   |Val30|   |Val00, Val10, Val20|   |x|
y = |Val31| + |Val01, Val11, Val21| * |y|
z   |Val32|   |Val02, Val12, Val22|   |z|
matrix <Val00, Val01, Val02,
         Val10, Val11, Val12,
         Val20, Val21, Val22,
         Val30, Val31, Val32>
I hope I'm of help.
Date: 15 Aug 2010 16:10:00
Message: <web.4c68497ba72b83ae6175cda10@news.povray.org>
> coordinates.
> Alain
The matrix sugestion did put me on the right track! but Alain, you are correct,
parsing every tringle is what would need to be done, and I believe I have the
resolution.
the vertices of the triangles in the map are given in easting and northing.
I have to convert these eastings and northings to geocentric cartesian xyz
points.
There doesn't seem to be a single step conversion to do this so a a two step
process has to be employed. First converting the eastings and northings to
latitude & longitude and then convert the Lat longs to the cartesian xyz.
But this raises an issue. The triangles will be "distorted" from their original
shape - if this impacts the normals to the vertices I don't know how to deal
with that.
Date: 16 Aug 2010 04:54:53
Message: <4c68fcdd@news.povray.org>
Am 15.08.2010 22:09, schrieb davidafisher:
> with that.
If I understand you correctly, then re-computing the normals should be a
piece of cake: They should point right away from the center. So
presuming that the sphere is centered around the origin, you can simply
set all normals to the same value as the corresponding vertices.
Date: 16 Aug 2010 06:35:05
Message: <4c691458@news.povray.org>
> > with that.
  A shearing transform doesn't sound to me like it would keep a sphere
spherical.
