![](/i/fill.gif) |
While working on a scene, I noticed what I perceive to be an inconsistency in
the way light_groups behave with global lights. Specifically, the objects in
the light_group may or may not be illuminated by global lights as specified by
the user, but they always cast a shadow from global light_sources. Using the
no_shadow keyword for the object also turns off the objects' shadows from the
light_sources within the light_group, which may be/is undesirable.
After reading the docs, I wasn't sure whether this was a bug or just a different
way of thinking of things, since the docs describe it as a way of controlling
the scene brightness by selectively illuminating objects. They mention the
lights in a group do not contribute to global scene lighting, but do not really
mention shadows.
At this point, I think the shadows should be selected, too, perhaps by a
global_shadows keyword, but what I want to know first is whether or not I am
Doing It Wrong, and there already is a way to keep the shadows within the
light_group without global light shadows.
/* EXAMPLE CODE:
** Simple example scene illustrating light_group issue
** Scene Description: 2 light groups, each containing a
** single colored light source and a white sphere.
** One has global_lights on, the other has it off.
** In both cases, the spheres cast shadows for the
** global light.
light_source{ // global light
<100,75,-75> * 100,
color rgb <1,1,1>
light_group // red light group
sphere{
<0,0,0>, 1
pigment{ color rgb <1,1,1> }
light_source{
<0,5,0>,
color rgb <1,0,0>
global_lights off
translate <-1.5,1,0>
light_group // blue light group
sphere{
<0,0,0>, 1
light_source{
<0,5,0>,
color rgb <0,0,1>
global_lights on
translate <1.5,1,0>
plane{
y, 0
background{ color rgb <0.75,0.875,1.00> }
camera
location <0,3,-5>
look_at <0,1,0>
-Reactor
![](/i/fill.gif) |
![](/i/fill.gif) |
I don't know if this has any relevance, but there's actually three objects
to be considered: The light, the object casting the shadow, and the object
the shadow is cast upon.
In other words, if the statue casts a shadow on the floor, perhaps it's
because the *floor* is illuminated by global lights, even if the statue isn't.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
![](/i/fill.gif) |
![](/i/fill.gif) |
That is an interesting perspective that I hadn't considered, but I think my
expectation was that the illumination and shadows would be together. That is,
if a light doesn't illuminate an object, then it probably shouldn't be shadowed
by it, either.
-Reactor
![](/i/fill.gif) |
