![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hey,
I have this function in my isosurface object:
function{(1+front_smoothness) - pow(front_smoothness, f_Sphere(7/4*x, 2*(y+0.9),
1/(8/2)*(z+8))) - pow(front_smoothness, f_Sphere(12/4*x, 4.55*(y-0.17),
10/12*(z+8.7))) - pow(front_smoothness, f_Sphere(12/4*x, 10*(y+0.5),
6/4*(z+7.8))) }
(a set of spheres that are smoothly unioned together)
where f_Sphere = function{ sqrt(pow(x,2) + pow(y,2) + pow(z,2)) - 2.8 }
(just a sphere with radius 2.8)
I was just wondering how I might convert this isosurface to a union of spheres.
I understand how to to apply the scaling and translations of the isosurface I
just don't seem to be able to perform the same transformation as the pow
function.
This is my not working attempt at the CSG...
object{Sphere
scale x*4/7 scale y*1/2 scale z*8/2
translate x*-0 translate y*-0.9 translate z*-8
object{Sphere
scale x*4/12 scale y*1/4.55 scale z*12/10
translate x*-0 translate y*0.17 translate z*-8.7
object{Sphere
scale x*4/12 scale y*1/10 scale z*4/6
translate x*-0 translate y*-0.5 translate z*-7.8
Thank you for help!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Bridgeofstraws who wrote:
>Hey,
>2*(y+0.9),
>6/4*(z+7.8))) }
>function.
> object{Sphere
> object{Sphere
> object{Sphere
>Thank you for help!
That's correct, as long as you've remembered the 2.8 when you #declared
your Sphere object:
#declare Sphere = sphere{0,2.8}
The isosurface approaches that CSG as front_smoothness approaches zero,
but as front_smoothness approaches zero, the required max_gradient
approaches infinity.
With front_smoothness=0.001 and max_gradient 30 they look pretty
similar.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> your Sphere object:
> similar.
> Mike Williams
I forgot to add #declare Sphere = sphere{0,2.8}, but you guessed it correctly
anyways.
You've helped me to understand a bit mroe about how the pow function works and I
really want to thank you for that. I have another question though...
I unfortunately have front_smoothness set to 0.5, which makes the resulting
isosurface much different, so is there anyway I might be able to account for
this besides changing front_smoothness too much?
I could probably reduce the smoothness to 0.1 but if I go any further I loose
the smooth look I want (but I'd do this only as second last resort, the last
being, redoing my isosurface).
Thank you for your help.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>anyways.
>works and I
If you're looking for a shape that consists of scaled spheres smoothly
blobbed together, then you're not going to achieve that by placing three
spheres next to each other. And you can't do it with the blob primitive
if your spheres are scaled differently.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: How do I convert this isosurface into a CSG object
Date: 1 Apr 2008 04:21:50
Message: <47f1feae$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually, transformations are allowed as blob component modifiers.
This includes "scale".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 1 Apr 2008 23:28:11
Message: <47f30b5b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Christian Froeschlin" <chr### [at] chrfr de> wrote in message
news:47f1feae$1@news.povray.org...
The spheres in the isosurface are smoothed with a function that
distorts the component spheres, it isn't a simple blob-like function.
It results in pointy ends, more pointy than just scaled spheres.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
