"Woody" <nomail@nomail> wrote:
> > Hey, some people do it by hand rather than on inkscape! :)
> I guess I'll have to google "inkscape".
www.inkscape.org
excellent open-source vector drawing program. Exports beziers as povray prisms.
Subject: Re: Beziers/Quadratics and Cubics splines
Date: 4 Jan 2008 17:19:03
Message: <477eb0d7@news.povray.org>
> www.inkscape.org
> prisms.
I like Spilin Editor for simple cubic splined lathes and prisms.
http://www.flashnet.it/users/fn027571/spil/main.html
> > www.inkscape.org
> > prisms.
But Still,, some of us like the manual control without using specialized
editors.
> editors.
yeah, like wasting time in trial-and-error steps entering lots of points
by hand as well as the always annoying internal points in the lathe... I
find more fun to program in Brainf*ck...
To be fair I must admit that sometimes I have done this manually
for cubic splines by sketching a profile onto graph paper then
entering the data. It's not really that hard to come up with a couple
extra control points when the rest are on the curve.
Bezier curves are a different matter, it's very difficult to visuallize
where all the control points should be without some feedback,
at least for complex curves. For simple curves they're just
tangent to the normal, with the magnitude controlling the flatness,
that's OK manually if the normal is along an axis.
There's really two ways to go about making a scene, one is
to do sketches on paper (or mentally if you can visualize well),
then try to make your scene match. Somethime text entry is a
fast way to put your picture into SDL.
The other method is to create your scene on the computer in
the first place, and modify it until it looks good. A GUI can
make this method fast, since it helps visualize the scene.
> > Can someone please explain why Quadratics and Cubic splines are even necessary?
> AFAIK they are simple to specify: you just specify the in-between points,
> rather than specifying the control points as well as is the case with bezier
> splines. The bezier spline requires 2 control points for each point specified
> while in quadratic and cubic they are considered as the next and previous
> points.
That's the best way in my opinion since I'm bit of povray purist. It would be
nice if beziers were included as options in features where they are not
currently available (such as spherical sweeps), since beziers and linear
splines are alot easier to visualize (in my insignifigant opinion for what
little change that is worth). And since beziers require a lot less points than
a linear spline that looks otherwise identical, it seems to make sense.
Any chance of these getting into future POV Ray versions?
I'm not privy to why they aren't built into POV-Ray, but I have just
recently put together a macro that creates a sphere sweep-like object
along a bezier spline (including interpolation of radii). I was
planning on putting it up in the object collection with a set of macros
sometime, but I can post it by itself sooner if there's any interest.
I've also been pondering how best to create a standalone spline-like
macro using the same method.
-The Mildly Infamous Blue Herring
Date: 2 Jun 2008 14:40:48
Message: <48443eb0@news.povray.org>
There's definitely interest :-)
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 6 Jun 2008 11:02:53
Message: <4849519d@news.povray.org>
That's nice to hear :) I've actually finished up this version of the
package its in so I've posted the whole thing to the object collection:
http://lib.povray.org/searchcollection/index2.php?objectName=PointArrays&version=1.0.0&contributorTag=Blue%20Herring
I've also posted a sample image (the same as in the collection) to p.b.i.
The macro that does the bezier sphere_sweep is called PA_Bezier_Sweep.
If you try it or any other macro in the package any feed back is both
welcome and appreciated :)
Date: 6 Jun 2008 11:07:18
Message: <484952a6@news.povray.org>
Got it. Many thanks
John
