POV-Ray : Newsgroups : povray.advanced-users : Triangles faster than objects Server Time
6 Oct 2024 15:20:44 EDT (-0400)
  Triangles faster than objects (Message 13 to 22 of 22)
Subject: Re: Triangles faster than objects
Date: 6 Jun 2007 06:03:21
Message: <46668669@news.povray.org>
simply answer this
Did you texture them ?
and how ?
i think that came from the way your render it , ore than the time to parse
file mesh or object ..
news:web.464c7756a93451f1d8ef73430@news.povray.org...
> Hello,
> With my last render I noticed that if you render a scene which is divided
in
> triangles the render time is better than if you render the same scene
> divided in objects.
> For example, supose a scene formed by 50 objects with 100 triangles each
> one:.
> //TRIANGLES version:
> //5000 triangles = 5000 mesh2
> union{
>   //Triangle 1
>   mesh2 { [..] }
>   //Triangle 2
>   mesh2{  [..] }
>   //Triangle 5000
>   mesh2{  [..] }
> //OBJECTS version:
> //50 objects = 50 mesh2
>   mesh2{ [..] } //Object 1
>   mesh2{ [..] } //Object 2
>   mesh2{ [..] } //Object 50
> The TRIANGLES version has took 6 minutes to finish the render, while the
> OBJECTS version has took 8 minutes.
> Any comments?
> Regards,
> Joel.
Date: 6 Jun 2007 07:15:01
Message: <web.4666971d10a189edd8ef73430@news.povray.org>
"Penelope20k" <pen### [at] caramailfr> wrote:
> just a question ...
> Is it the render (trace) which takes less time . or is it the parse time ?
Triangles version:
- parse time  : 17 sec
- render time : 5 min 44 sec
- Total time  : 6 min 1 sec
Objects version:
- parse time  : 4 sec
- render time : 7 min 43 sec
- Total time  : 7 min 47 sec
Joel.
Date: 6 Jun 2007 07:23:11
Message: <4666991f@news.povray.org>
JSR <jsr### [at] gmailcom> wrote:
> Triangles version:
> Objects version:
  I'm still completely confused about what you mean with "triangles version"
and "objects version".
Date: 6 Jun 2007 07:30:02
Message: <web.466698e710a189edd8ef73430@news.povray.org>
> simply answer this
> and how ?
TRIANGLES VERSION
union
    mesh2
        vertex_vectors
         3,<200.0,0.0,550.0>,<-300.0,0.0,550.0>,<-300.0000,0.0000,50.0000>
        normal_vectors
         3,<0.0,-1.0,0.0>,<0.0000,-1.0000,0.0000>,<-0.4470,-0.8940,0.0000>
        uv_vectors
            3,<0.000,0.000>,<0.000,1.000>,<1.000,0.000 >
        texture_list
            1, texture { mat_0_89_0_0_0_0_TEX_L004 }
        face_indices
            1,<0,1,2>,0
[...] the same for the next triangles...
OBJECTS VERSION
    mesh2
        vertex_vectors
         53,<200,0,550>,<-300,0,550>,<-300,0,50>,............
        normal_vectors
         53,<0,-1,0>,<0,-1,0>,<-0.4470,-0.8940,0>,..............
        uv_vectors
            53,<0.000,0.000>,<0.000,1.000>,<1.000,0.000>,.........
        texture_list
        face_indices
            76,<0,1,2>,<2,3,4>,<2,7,12>,..........
[...] the same for the next objects
Joel.
Date: 6 Jun 2007 07:57:46
Message: <4666a13a@news.povray.org>
For the sake of clarity, could you in the future use more descriptive
names, please? I'm getting completely confused with the use of the terms
"triangles version" and "objects version" which are completely nondescriptive.
  How about "each triangle as its own object" and "a single mesh2 with
all the triangles inside it"?
Date: 6 Jun 2007 08:24:07
Message: <4666a767$1@news.povray.org>
yes me too ..
i think that he s calling about object version by
creating a union of each meshes ...insteed of making list of meshes
news:4666991f@news.povray.org...
> > Triangles version:
> > Objects version:
version"
Date: 6 Jun 2007 08:37:07
Message: <4666aa72@news.povray.org>
  That wasn't actually clarifying at all... :P
Date: 6 Jun 2007 08:45:22
Message: <4666ac62$1@news.povray.org>
Did your triangle can be mixed together ... means that when you union them,
POV will care only about visible faces (cause it have precompute them before
in the parse section) ..
when you dont union them ..the render has to think if or not the object is
visible by creating a ray,
so that means that it need to identify which objet is shown, and which part
of object is shown .
when you union it..the render send ray which intersect an object (and only
one cause you union meshes) , then it only need to compute what part of this
object must be shaown
news:46668669@news.povray.org...
> simply answer this
> and how ?
> > Hello,
divided
> in
> > divided in objects.
> > one:.
> > union{
> >   //Triangle 1
> >   mesh2 { [..] }
> >   //Triangle 2
> >   mesh2{  [..] }
> >   //Triangle 5000
> >   mesh2{  [..] }
> > //OBJECTS version:
> > Any comments?
> > Regards,
> > Joel.
Date: 6 Jun 2007 12:00:02
Message: <web.4666d94f10a189edd8ef73430@news.povray.org>
> > Triangles version:
> > Objects version:
Ok, supose the next scene: One cube, one sphere and one cylinder.
Objects version -> the format usually used by programs which can convert to
povray. Every object in the scene is represented by a mesh2 structure.
//cube
mesh2{
  vertexs 8
  faces 12
//sphere
mesh2{
  vertexs 50
  faces 70
//cylinder
mesh2{
  vertexs 30
  faces 50
Triangles (Faces) version -> Each mesh2 in the scene is just one face
union{
  mesh2{
    vertexs 3
    faces 1
  mesh2{
    vertexs 3
    faces 1
  //Total number of faces (mesh2) in this union = 12 + 70 + 50
                                              (cube + sphere + cylinder)
Date: 7 Jun 2007 03:06:44
Message: <4667ae84@news.povray.org>
Warp scripsit::
> Le Forgeron <jgr### [at] freefr> wrote:
>> precision of objects is infinite.
>   Exactly what do you base this claim on?
Well, now that "objects" have been clarified as mesh, I just stand
corrected. Both are bullshit.
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
