POV-Ray : Newsgroups : povray.advanced-users : the POV-ray SDL--similar to Java and/or Python? Server Time
19 Mar 2026 06:37:10 EDT (-0400)
  the POV-ray SDL--similar to Java and/or Python? (Message 10 to 19 of 79)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: the POV-ray SDL--similar to Java and/or Python?
Date: 12 Sep 2006 13:20:00
Message: <web.4506ebe8dcfb777ff5fba6ef0@news.povray.org>
> George Pantazopoulos <go### [at] tomyaboutpage> wrote:
> > This would have benefits for parallel rendering, since a fast machine could
> > parse the scene, then distribute the pre-parsed scene info to other nodes.
>   Parsing the SDL is actually often not the slowest part of the whole
> parsing step. The vast majority of time usually goes into allocating
> and setting up the objects and such.
>   The exception is when the SDL has loops which loop a lot, in which
> case a bytecode would speed up this interpretation. (For example, I once
> compared the speed of an SDL code which just prints an ascii mandelbrot
> set to stdout with a completely equivalent Perl code, and the latter was
> approximately 13 times faster. This is because Perl compiles to bytecode
> and then interprets that.)
Would it be possible to imagine such a thing: Develop Java POV-equivalent
classes and an adaptation layer though JNI that would parse Java code and
build the actual POV scene, and then render it by the actual POV engine
(adapted and activated by JNI)? Or am I off-track? It would be possible to
benefit all the power of the java syntax and modularity (and a debugger for
our macros).
Could one imagine something like this
import org.pov.*;
import org.pov.vegetation.*;
import org.pov.hormann.isowood.*;
import org.pov.tran.clouds.*;
import org.pov.someguru.WonderfulFeature4;
import org.pov.cabasson.PoorFeature1;
public class MyScene extends BasicOutDoorScene // Which extends POVScene,
and already has a light_source, a sun, and methods for the seasons and
Earth rotation ....
    public static main (int argc, String [] argv)
        SetHandedness(LEFT_HANDEDNESS);
        GlobalSetting gs = new GlobalSettings();
        Radiosity rad = new RadiositySettings(); // Empty constructor with
defaults
        rad.setPretrace(0.04, 0.01);
        rad.setErrorbound(0.6);
        gs.setRadiosity(rad); // Or
gs.setRadiosity(Radiosity.OUT_DOOR_LOW_QUALITY)
        BuildScene();
        Render(640, 480);
    private void BuildScene() // virtual method
        final RADIUS = Double.parseDouble(argv[0]).doubleValue();
        Sphere s = new Sphere (0, RADIUS); // promotion is implemented by
method overloading: could be new Sphere (new Position(0,0,0), RADIUS) or so
        s.translate(10, 0, 0);
        s.rotate(-20, 0, 0);
        Pigment p = new Pigment(new Rgbt(1));
        Interior interior = new Interior();
        interior.setIor(Consts.GLASS_IOR);
        interior.setFadeColor(Colors.Blue);
        interior.setFadeDistance(s.getRadius()/2);
        s.setPigment(p);
        s.setInterior(interior);
        set.setPhotons(new ObjectPhotons(...));
        this.add(s);
        Plane ground = new Plane
            y, 0,
            new Pigment
                CHECKER,
                new ColorMap
                new Turbulence(0.5, 2.0, 0.65, 8)
        ground.getPigment().setWarp(BLACK_HOLE, new Position(...));
        ground.getPigment().scale(2.0);
        this.add(ground);
        /// Etc ....
If the java classes are well chosen, I think the java-equivalent syntax of a
scene could be as clear as sdl. Maybe more, when the scene would use lots of
complicated macros. Btw, JNI allows a DLL to call java code, then the sdl
function{} feature would execute at java speed (quite fast with HotSpot).
Then this scene would be rendered with a command line like:
java org.pov.MyScene 1.0
But I would not mind if you called me insane ... cos' I am  already  LOL
    Bruno
Date: 12 Sep 2006 13:44:00
Message: <4506f1e0$1@news.povray.org>
>> As an aside, if the SDL ever becomes object-oriented, the whole subject
>> will become a whole lot more confusing. ;-)
>   Not really. C++ doesn't talk about "objects" anywhere in its syntax,
> and neither has the SDL to do so (when referring to class instances).
> Even the documentation could avoid the word "object" in relation to
> class instances (and talk about "instances" instead).
Yeah, that sounds like it would work. Just need to be careful to *stick*
to that terminology and it should be fine...
BTW, I was thinking about just inventing my own new SDL language and
writting a program that can convert it to standard POV-Ray SDL. But,
unfortunately, this would of course involve writing a parse, so that
project never really got anywhere...
Date: 12 Sep 2006 13:59:47
Message: <4506f593$1@news.povray.org>
http://sourceforge.net/projects/lome
     Just because you find out you are
     telepathic, don't let it go to your head.
Date: 12 Sep 2006 14:17:21
Message: <4506f9b1$1@news.povray.org>
Mmm, looks *highly* active...
Date: 12 Sep 2006 14:44:41
Message: <45070019$1@news.povray.org>
No. I wrote it. I put it up. Use it if you please. Don't use it if you
don't want to. But if you're looking for a new SDL language that
includes converters to standard POV-Ray SDL, there it is. Source and
everything.
And no, it won't *be* highly active before someone else wants a similar
thing. So go ahead, and give me your improvements, instead of just
complaining. ;-)
Date: 12 Sep 2006 14:56:09
Message: <450702c9$1@news.povray.org>
Really?
Interesting; I didn't know it was possible to do that...
> everything.
> complaining. ;-)
OK, how about... some instructions? (Or am I just looking at the wrong
page?)
Date: 12 Sep 2006 14:59:43
Message: <20060912195946.705e4d6a@mekanori.mon.istic.org>
> page?)
Yes. You want to be looking at the page with the source code on it.
"After all, one can't complain.  I have my friends. Somebody spoke to me
only  yesterday.  And was it  last week or  the week before  that Rabbit
bumped into  me and said  'Bother!'  The Social Round.  Always something
going on."  -- A. A. Milne, 'Winnie-the-Pooh'  http://surreal.istic.org/
Date: 12 Sep 2006 15:03:31
Message: <45070483$1@news.povray.org>
>> page?)
o__O
Looks like I need to learn C# really fast... heh.
Date: 12 Sep 2006 16:49:46
Message: <45071d69@news.povray.org>
  Please don't take this in the wrong way, but your example gives me
cold shivers.
  No Java, please. Something more suitable for POV-Ray and less "javaish".
  Of course nothing stops you from creating a library for Java which can
be used to create POV-Ray scenes, but that's a different matter.
Date: 12 Sep 2006 16:51:34
Message: <45071dd6@news.povray.org>
  A project like that would be more or less a waste of time.
  A new SDL language should be such that it can be interpreted even
at render time (in order to create, among other things, shaders).
