POV-Ray : Newsgroups : povray.advanced-users : Lightsys Server Time
4 Jul 2026 20:35:21 EDT (-0400)
  Lightsys (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Lightsys
Date: 24 Feb 2018 11:06:33
Message: <5a918d89$1@news.povray.org>
On 2/23/2018 8:18 AM, Alain wrote:
> The 3 lumen looks a little to bright.
> Can you post the 1 lumen image?
> Also, the sun position is not the same for the two images. It mover by
> around 40°.
Here it is with RGB instead of SRGB, and 1 lumens.
https://i.imgur.com/AcGBbla.jpg
As you can see, it is pretty dim and lifeless.
Mike
Date: 24 Feb 2018 12:22:47
Message: <5a919f67@news.povray.org>
>> around 40°.
> Mike
Slightly dimmer, not prety dim, than the 2 lumens but not lifeless on my
monitor. Maybe your monitor is set to dim...
Definitively better than the 3 lumens version.
Set assumed_gamma 1
When using lightsys, always use RGB for the lights. lightsys is made to
return values in the rgb colour space, not the srgb one. You may use
srgb for the textures.
Date: 25 Feb 2018 02:53:27
Message: <5a926b77@news.povray.org>
>> around 40°.
On my screen it looks right.
I often use CIE.inc myself, maybe in a little different way than you do.
This is an example of how I define my sunlight in a scene:
//start code -----------------------------------
#include "CIE.inc"
#if (Fog)
   #local Intensity    = 5;
#else
   #local Intensity    = 3;
//Sun's temperature (Kelvin): 2800=red; 7500=blue white
#declare SunColor     = Blackbody(6500)*Intensity;
#declare SunPosition  = <0, 0, -2>*10e4;
#declare SunDis       = vlength(SunPosition)*2/215;
#declare Sun_alt      = 60;
#declare Sun_azm      = -115;
#if (Area)
   #debug "\nUsing an area_light for the Sun.\n"
   light_source{
     <0, 0, 0>
     color SunColor
     area_light
     SunDis*x, SunDis*z, // lights spread out (x * z)
     4, 4                // total lights in grid (4x*4z = 16 lights)
     adaptive 1          // 0,1,2,3...
     area_illumination on  // full area diffuse and specular
     jitter              // adds random softening of light
     circular            // make the shape of the light circular
     orient              // orient light
     translate SunPosition
     rotate Sun_alt*x
     rotate Sun_azm*y
     parallel
     point_at <0, 0, 0>
     media_interaction on
     media_attenuation off
#else
   light_source {
     <0, 0, 0>
     color rgb SunColor
     rotate Sun_alt*x
     rotate Sun_azm*y
     parallel
     point_at <0, 0, 0>
//end code -----------------------------------
Date: 25 Feb 2018 19:02:50
Message: <5a934eaa@news.povray.org>
>>> by around 40°.
> #include "CIE.inc"
> #if (Fog)
> #else
> #end
> #if (Area)
>    light_source{
>      <0, 0, 0>
>      color SunColor
>      area_light
A better, more descriptive, name would be "SunDiam"
lights)
This will actually use a 5 by 5 array...
...and start with a 3 by 3 one.
With adaptive, you can use a much larger value, like 17 or 33 without
increasing the render time much.
adaptive 0 DON'T turn the feature off, but start with a 2 by 2 array.
Makes the penumbra grainy if using a sparse array.
>      rotate Sun_alt*x
>      rotate Sun_azm*y
>      parallel
>      point_at <0, 0, 0>
> #else
>    light_source {
>      <0, 0, 0>
>      color rgb SunColor
>      rotate Sun_alt*x
>      rotate Sun_azm*y
>      parallel
>      point_at <0, 0, 0>
> #end
Using adaptive, you need larger arrays to get all the benefit. Some
suggested sizes in relation with the adaptive steps values :
adaptive 0 (0 initial subdivisions)  at least 5 by 5 (2 steps)
adaptive 1 (1 initial subdivisions)  at least 9 by 9 (3 steps)
adaptive 2 (2 initial subdivisions)  at least 17 by 17 (4 steps)
adaptive 3 (3 initial subdivisions)  at least 33 by 33 (5 steps)
You can always use larger arrays to get smoother results.
Date: 26 Feb 2018 02:43:55
Message: <5a93babb$1@news.povray.org>
>>>> by around 40°.
>> do. This is an example of how I define my sunlight in a scene:
>> #include "CIE.inc"
>> #if (Fog)
>> #else
>> #end
>> #if (Area)
>>    light_source{
>>      <0, 0, 0>
>>      color SunColor
>>      area_light
lights)
>>      rotate Sun_alt*x
>>      rotate Sun_azm*y
>>      parallel
>>      point_at <0, 0, 0>
>> #else
>>    light_source {
>>      <0, 0, 0>
>>      color rgb SunColor
>>      rotate Sun_alt*x
>>      rotate Sun_azm*y
>>      parallel
>>      point_at <0, 0, 0>
>> #end
Thanks Alain, well spotted indeed. I always unthinkingly use the set up
as is. ;-)
Date: 26 Feb 2018 17:51:08
Message: <5a948f5c$1@news.povray.org>
>>> by around 40°.
>> Mike
> Set assumed_gamma 1
> Alain
My monitor is set to "SRGB". Dunno what it should be set to.
Mike
Date: 27 Feb 2018 20:38:29
Message: <5a960815@news.povray.org>
>>>> by around 40°.
>>> Mike
>> my monitor. Maybe your monitor is set to dim...
>> Set assumed_gamma 1
>> to return values in the rgb colour space, not the srgb one. You may
>> use srgb for the textures.
>> Alain
> Mike
Same thing here. sRGB is correct for the monitor.
But, what about the brightness and contrast settings? Normally, contrast
should be set high (100%) and brightness relatively low (<30%).
Brightness is to be adjusted for the ambient lighting level of the room,
but not the contrast.
A low contrast makes your display washed out and generally lifeless.
If you have a saturation setting for the monitor, set it around 50% to
start.
Next, you have the file gamma and display gamma to adjust. File gamma
can be set from 1 to 2.2 or srgb, or something else if you want to.
Display gamma should be the same as your actual gamma setting for the
monitor : SRGB in your case.
Date: 28 Feb 2018 00:02:09
Message: <5a9637d1@news.povray.org>
> start.
I just checked on my phone, and it looks just as bad. So, I don't know
what's wrong with your monitor.
Mike
Date: 28 Feb 2018 00:17:09
Message: <5a963b55$1@news.povray.org>
> #if (Fog)
> #else
> #end
This is much lighter, thanks. But maybe a little too white. I want a bit
more color, but don't have an atmosphere to filter the sun's rays.
Mike
Date: 28 Feb 2018 02:40:20
Message: <5a965ce4$1@news.povray.org>
>> #if (Fog)
>> #else
>> #end
Just play with the Intensity value :-)
Intensity=1; would be the normal use. I always adapt according to the
scene I am working on.
