>>> Help, Math wizards, you're my only hope.
>> Try the attached.
> Yeah baby! There's nothing like a copy/paste solution that I almost
> understand, but does exactly what I want. ;)
> I can't wait to try it out on non-solid, non-spherical shapes.
> Thanks!
What you're trying to do is transform some kind of "screen" coordinates
into world coordinates. What I did was to calculate the directions of
the "new" x,y,z axes and then use those to transform the original
coordinate to the actual world coordinate:
> #local newZ = vnormalize( Lookat-Camera );
The new Z axis direction should be from Camera to Lookat, this is what
you want. vnormalize makes sure it's a unit length vector.
> #local newY = y;
The new Y axis direction is just y to start (it will be fixed later).
> #local newX = vnormalize(vcross(newY,newZ));
The new X axis direction is perpendicular to the Z and Y defined in the
above two lines (ie to the right). X and Z are now correct, but Y needs
to be adjusted to take account of Z probably not being horizontal (Y
needs to be "tipped back" a bit).
> #local newY = vnormalize(vcross(newZ,newX));
The new Y is now calculated as perpendicular to the Z and X just
calculated. This is correct now, with all 3 perpendicular to each other.
> #local bar = bar.x * newX + bar.y * newY + bar.z * newZ;
This line essentially takes the original xyz coordinates and transforms
them using the new XYZ axes. There are neater ways to do this, but I
thought this made it a little more clear what is going on.
Note the new coordinates are relative to the camera, so you still need
the translate camera line.
I have started again to try to tackle this problem.
Scott's solution gave me a vector, which is not what I need. :( I need
an angle.
http://www.buckosoft.com/tteoac/video/testRenders/test2.mp4
The first 3 moves are correct, when I move x or z. As soon as I move
both, all hell breaks loose.
The kid in my movie is carrying a flashlight. It has an offset of
<-0.4,-0.3,0.7> from the origin and points down the Z.
The red ball is Lookat.
I have the angle between Lookat-Camera shown by the cyan ball.
It seems to me that if I move my flashlight to its offset, rotate it by
the Lookat-Camera angle, then add the Camera vector, it SHOULD BE LOCKED
TO THE CAMERA.
argh.
Download 'test2.pov.txt' (5 KB)
Download 'animtest.ini.txt' (1 KB)
> an angle.
> TO THE CAMERA.
> argh.
So, just so I fully understand what you want,
1. You want to have a flashlight that always points at "Lookat"
2. You want it offset by a certain amount from the camera position
3. ... ? (if any)
On 12/15/2017 07:50 AM, Bald Eagle wrote:
> argh.
> 3. ... ? (if any)
Yes, like in Doom, where the gun is in a fixed position relative to the
game window.
(Wait, isn't there a text thingy in the object library that draws text
in a fixed position on the screen? ...)
> > argh.
> > 3. ... ? (if any)
> game window.
Yes.
There is Screen.inc
I think the idea there is that with a default camera position at the origin, and
a view direction of +z, you have a standard -0.5 to +0.5y and -0.5*4/3 to
0.5*4/3x rectangle in the view frustum.
Then you can normalize everything and locate it on that rectangle and if it's a
3D object, squish it really flat. It gets jammed up right against the camera
with all the no_shadow etc stuff, so it doesn't interfere with the scene.
I had some problems unraveling it all at first, but once I wrapped my head
around it, it wasn't too bad.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.587ce3fc782d1af2c437ac910%40news.povray.org%3E/?ttop=418740
&toff=50&mtop=415328
2 more things:
1. I have no idea what version of Doom YOU were playing - a flashlight? :O
#MomMode
2. You need 2 angles - shine the light at +z, then rotate y and rotate x
I'll see if I have some time to give it a quick look when I get back tonight.
Last night was rather late.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.587ce3fc782d1af2c437ac910%40news.povray.org%3E/?ttop=418740&toff=50&mtop=415328
Hmm, I missed that thread. It looks ... interesting to me.
dik
On 12/15/2017 04:48 PM, Bald Eagle wrote:
> 2 more things:
> #MomMode
It's not a gun, Mom, it's a flashlight. It just looks like a gun.
Looking at this picture
http://snipd.net/wp-content/uploads/2011/05/Spherical-coordinates.png
from this page
http://snipd.net/2d-and-3d-vector-normalization-and-angle-calculation-in-c
I wondered if doing it in two rotates was an answer, as opposed to
rotate <x, y, 0>
Well, you should. There is no greater purpose in life than helping a
fellow anonymous POV-er. I don't want no excuses about last night.
dik
> rotate <x, y, 0>
Yes, because the POV-Ray coordinate system is in x, y, z Cartesian space, not
spherical coordinates.
If you are getting a vector as a result, then you can likely just translate that
to spherical coordinates.
Slave.
Driver.
Give the following a whirl and see if you follow what's going on:
#version 3.71;
#declare Radiosity = off;
global_settings {
assumed_gamma 1
#if (Radiosity)
radiosity {
pretrace_start 0.04
pretrace_end 0.01
count 200
recursion_limit 3
nearest_count 10
error_bound 0.5
#include "glass.inc"
#include "textures.inc"
#include "metals.inc"
#include "rand.inc"
#declare Perspective = image_width/image_height;
#declare P = Perspective;
#declare Camera = <0, 0, 0>;
perspective
up <0,1,0>
right x*Perspective
location Camera
look_at <0, 0, 1>
light_source {<1, 1, -50> color rgb <1,1,1>}
//plane {y, 0 texture {pigment {Gray50} normal {granite 0.1}} }
#declare Flashlight = <-0.4, -0.3, 0.7>;
#declare Size = 0.025;
#for (Y, -0.5, 0.5, 0.1)
#for (X, -0.5*P, 0.5*P, 0.1)
#declare LookAt = <X, Y, 1>;
sphere {LookAt Size pigment {rgbt <1, 0, 0, 0.9>}}
// Imagine a sphere at <0, 0, 1>
// rotating around the x-axis brings the height of the
// flashlight impact to the same height as the LookAt point
// Then, when it is rotated around the y-axis, it maintains this height
// and is oriented to point at the LookAt point
// Note that this "vector" direction is not corrected for the distance to the
plane
// and so it is is a cylindrical curve, it is not the same as the Lookat
point,
// but one can draw a line from the Flashlight
// to the LookAt point, which is in the +z view plane
#declare Xo = LookAt.y - Camera.y;
#declare Xa = LookAt.z - Camera.z;
#declare XAngle = degrees(atan2 (Xo, Xa));
#declare Yo = LookAt.x - Camera.x;
#declare Ya = LookAt.z - Camera.z;
#declare YAngle = degrees(atan2 (Yo, Ya));
#declare Xo2 = LookAt.y - Flashlight.y;
#declare Xa2 = LookAt.z - Flashlight.z;
#declare XAngle2 = degrees(atan2 (Xo, Xa));
#declare Yo2 = LookAt.x - Flashlight.x;
#declare Ya2 = LookAt.z - Flashlight.z;
#declare YAngle2 = degrees(atan2 (Yo, Ya));
sphere {<0, 0, 1> Size/2 pigment {rgbt <0, 1, 0, 0.9>} rotate x*XAngle rotate
y*YAngle}
sphere {<0, 0, 1> Size/4 pigment {White} rotate x*XAngle2 rotate y*YAngle2}
Should the white/green spheres be centered in the red spheres?
or, at least, "in front of".
This looks kinda like what I got now. Once you move away from the
origin, it goes out of whack.
dik
