POV-Ray : Newsgroups : povray.advanced-users : Projecting sRGB gamut into xyY space Server Time
16 May 2026 16:29:35 EDT (-0400)
  Projecting sRGB gamut into xyY space (Message 1 to 6 of 6)
Subject: Projecting sRGB gamut into xyY space
Date: 28 Mar 2017 22:36:14
Message: <58db1d9e$1@news.povray.org>
I am once again projecting the sRGB gamut into xyY space. This time,
however, I am generating a mesh parametrically instead of creating an
isosurface.
All goes well until R, G and B are all equal to zero, since xyY space
doesn't like this coordinate.
How should I handle this case? Should I just skip it and not render a
triangle there? Or is there a better way to handle it?
Thanks!
Mike
Subject: Re: Projecting sRGB gamut into xyY space
Date: 29 Mar 2017 12:18:43
Message: <58dbde63@news.povray.org>
Am 29.03.2017 um 04:36 schrieb Mike Horvath:
> isosurface.
My recommendation would be to go as close to 0 as you can (e.g. 1e-6).
If you feel like it, you can add some hard-coded triangles from there to
(x,y,Y)=(0,0,0) to get a closed shape.
Date: 29 Mar 2017 19:59:07
Message: <58dc4a4b@news.povray.org>
>> isosurface.
Plotting the triangles to (x,y,Y)=(0,0,0) or very near there is not
going to produce nice/correct results. See the attached image. Those
triangles would look very much out of place.
Mike
Download 'cie_srgb_gamut_xyy_space_cube_mesh000.png' (37 KB)
Preview of image 'cie_srgb_gamut_xyy_space_cube_mesh000.png'
Date: 30 Mar 2017 09:09:55
Message: <58dd03a3$1@news.povray.org>
Am 30.03.2017 um 01:59 schrieb Mike Horvath:
>>> isosurface.
The "closure" to (0,0,0) was only suggested as a final add-on.
What you need to do is take R,G,B to a very small value (e.g. 1e-6)
separately.
It may be sufficient to plot the (distorted) cube as usual, but every
time /any/ R,G,B coordinate drops to zero you replace that value with
1e-6 instead.
Then again maybe that's not enough, and you may need to increase your
cube's resolution near (0,0,0).
Date: 3 Apr 2017 08:18:52
Message: <58e23dac@news.povray.org>
In my mind, the point RGB=0,0,0 corresponds to the surface that "caps"
the bottom of your 3D shape. ie the one where Y=0 and is bordered by the
classic "horseshoe". Any point on that "cap" would be RGB=0 because Y=0.
Date: 3 Apr 2017 13:35:00
Message: <58e287c4$1@news.povray.org>
I couldn't figure out what values to use for x and y, so I just skipped
those points.
Mike
