POV-Ray : Newsgroups : povray.advanced-users : L*C*h(uv) color solid Server Time
1 Jun 2024 19:56:10 EDT (-0400)
  L*C*h(uv) color solid (Message 53 to 62 of 82)
Subject: Re: L*C*h(uv) color solid
Date: 24 Nov 2016 20:56:34
Message: <58379a52$1@news.povray.org>
On 11/24/2016 8:28 PM, Mike Horvath wrote:
> I've attached the final shape, with the outside sRGB bits trimmed off.
> Mike
For comparison, here is the same image with the corner bits left in.
Mike
Download 'cielch_color_solid_cylinder_isosurface.png' (24 KB)
Preview of image 'cielch_color_solid_cylinder_isosurface.png'
Date: 24 Nov 2016 20:59:28
Message: <58379b00$1@news.povray.org>
On 11/24/2016 8:33 PM, clipka wrote:
> Don't try to go via that route; it won't work with the approach I've
> described.
> Instead, in the function pipeline, insert a function to explicitly
> convert from sRGB to RGB:
>     3D cartesian -> Lch -> sRGB -> RGB -> "distance"
>     3D cartesian -> Lch -> sRGB -> RGB -> pigments
Do you have a function to convert between sRGB and RGB? One was not
included with ColorMine AFAIK.
Mike
Date: 24 Nov 2016 21:11:30
Message: <58379dd2$1@news.povray.org>
Am 25.11.2016 um 02:59 schrieb Mike Horvath:
>> described.
No ready-made function; you'll need to piece things together from e.g.
https://en.wikipedia.org/wiki/SRGB.
Date: 24 Nov 2016 21:19:30
Message: <58379fb2$1@news.povray.org>
Am 25.11.2016 um 02:33 schrieb clipka:
I forgot: You won't necessarily need the sRGB->RGB step for the
"distance" function, as sRGB channel values of 0 and 1 map to RGB
channel values of 0 and 1, respectively.
Date: 24 Nov 2016 21:31:18
Message: <5837a276$1@news.povray.org>
>>> described.
I am looking at the "The reverse transformation" section. Do I just need
to use the C_linear function?
Mike
Date: 24 Nov 2016 21:55:02
Message: <5837a806$1@news.povray.org>
Am 25.11.2016 um 03:31 schrieb Mike Horvath:
>>>> described.
Yup, that's the one.
Date: 24 Nov 2016 22:09:15
Message: <5837ab5b$1@news.povray.org>
Okay, I will try that.
Mike
Date: 28 Nov 2016 03:23:40
Message: <583be98c@news.povray.org>
>> May I ask the stupid question, "why not"?
>> I would expect the Lch colour space to encompass all the RGB colour
>> space, so the boundaries of the latter should be sufficient to bound the
>> shape.
>> My guess is that the issues you see with the shape are due to bogosities
>> in your colour conversion functions.
> L, C and H are supposed to form a cylinder. There are some very small
> sRGB bits poking outside of the cylinder. I guess I could show the bits
> as well, as long as I explain what they are.
If sRGB is poking out of your cylinder, then Adobe RGB is going to poke
out even more, and the entire human visual range is going to be much
larger. Are you sure you've got the radius of your cylinder correct to
match your colour calculations? Also it would be surprising to me if the
human visual range came out exactly as a cylinder (after a brief glance
of the maths involved), are you sure about this?
Date: 28 Nov 2016 03:28:21
Message: <583beaa5$1@news.povray.org>
>>> shape.
Yeah, I explain the mistake I made in this thread:
http://news.povray.org/583bd889%241%40news.povray.org
Mike
Date: 28 Nov 2016 03:33:52
Message: <583bebf0$1@news.povray.org>
The human visual range has a very irregular shape.
https://en.wikipedia.org/wiki/File:Cie_Chart_with_sRGB_gamut_by_spigget.png
There's a lot of blank empty space around it in every color space. (The
one in the picture is called CIExyY I think.
I would like to learn how to plot this irregular shape in the near future.
Mike
