POV-Ray : Newsgroups : povray.advanced-users : Spherical camera upside-down Server Time
8 Feb 2026 05:12:16 EST (-0500)
  Spherical camera upside-down (Message 1 to 10 of 19)
Subject: Spherical camera upside-down
Date: 8 Sep 2016 08:44:35
Message: <57d15d33$1@news.povray.org>
I have the following spherical camera:
		#declare Camera_Up		= -y;
		#declare Camera_Right		= +z;
		#declare Camera_Location	= <0,0,0>;
		#declare Camera_Direction	= -x;
		#declare Camera_LookAt		= Camera_Location + Camera_Direction;
		#declare Camera_Transform = transform
			matrix <0,0,-1,0,1,0,1,0,0,0,-88,-640>		// front entrance
		//	matrix <0,0,-1,0,1,0,1,0,0,0,-88,100>
		//	matrix <0,0,-1,0,1,0,1,0,0,0,-88,-180>
		//	matrix <0,0,-1,0,1,0,1,0,0,-280,-88,-180>
		//	matrix <0,0,-1,0,1,0,1,0,0,280,-312,140>
		//	matrix <0,0,-1,0,1,0,1,0,0,200,-312,-140>
		//	matrix <0,0,-1,0,1,0,1,0,0,-200,-312,-140>
		//	matrix <0,0,-1,0,1,0,1,0,0,-360,-312,140>
		camera
			spherical
			angle		360 180
			up		Camera_Up
			right		Camera_Right
			location	Camera_Location
			direction	Camera_Direction
			transform {Camera_Transform}
It is a LDraw model, which has an inverted y axis or handedness. The
problem is when I render the scene, it appears upside-down. Even though
I already compensated by making the y axis negative. Anyone have an idea
what is going on?
Mike
Subject: Re: Spherical camera upside-down
Date: 8 Sep 2016 08:49:50
Message: <57d15e6e$1@news.povray.org>
>         camera
>             spherical
>             angle        360 180
>             up        Camera_Up
>             right        Camera_Right
> what is going on?
> Mike
You might enjoy a "sky" in your camera. And I do not know what the
matrix transform is doing, but there is also a -1 in it.
But classical "right hand" is z up, y forward, x right
Date: 8 Sep 2016 14:14:47
Message: <57d1aa97$1@news.povray.org>
>> Camera_Direction;
>> entrance
>>         camera
>>             spherical
>>             angle        360 180
>>             up        Camera_Up
>>             right        Camera_Right
>> what is going on?
>> Mike
The docs don't say anything about "sky", nor should I need one. Adding
one doesn't help. Also, I removed the matrix transformation but the
result is still upside-down.
Mike
Date: 8 Sep 2016 15:15:01
Message: <web.57d1b861978968acb488d9aa0@news.povray.org>
> Mike
I do believe that Jerome meant that you might find adding a sky VECTOR to your
camera definition may be of some help.
I realize you must be frustrated, but he is very knowledgeable and provides
excellent advice, and I would suggest taking a step back, a breath, and a few
more minutes to search before responding.
This may help in addition to the docs which DO explain the use of a sky vector:
http://www.joshuarenglish.com/cyclopedia/sky.html
Date: 8 Sep 2016 16:10:28
Message: <57d1c5b4$1@news.povray.org>
Am 08.09.2016 um 14:44 schrieb Mike Horvath:
> what is going on?
To me it looks like you're trying to achieve via camera up, right and
direction what someone else has already cared for via the matrix
transform, so effectively the two cancel out.
My recommendation would be to try and start from scratch:
- The `sky` vector should be set to whatever is really "up" in the
scene; the default is `y`, but you most certainly want `-y`.
- The `up` vector should also be set to whatever is really "up" in the
scene, possibly multiplied by `image_height/image_width`(*).
- The `right` vector should be set to whatever is "right" according to
the orientation you find the scene easiest to visualize, possibly
multiplied by `image_width/image_height`(*). You might pick `+x`.
- The `direction` vector should be set to whatever is "forward"
according to your choice of "right", possibly multiplied by a zoom
factor. (Alternatively, you can keep the `direction` vector constant and
apply a factor to both `up` and `right` for zooming.
- The `location` should, for now, be a place from where, given the above
settings, you should be able to see something in the scene.
(*only one of `up` or `right` should be multiplied with the stated
factor; note that one is the inverse of the other)
Once you get something remotely useful out of this straightforward
camera setup, you can proceed to tweak the perspective to your liking in
one of the following manners:
(A) The Hard Way: Mess with the `up`, `right` and `direction` vectors
manually. It is up to you to make sure they stay orthogonal and at the
proper relative lengths, and since that can be quite a pain and prone to
errors I really wouldn't recommend this.
If you choose this approach, I think you should theoretically be able to
get away without a `sky` vector.
(B) Transformation: Simply add rotations and translations to the camera
statements. Be aware that rotations are always around the origin, so
unless your camera is at <0,0,0> rotations will not only change the
viewing direction, but also the location of the camera. (Theoretically
you can also use scaling and matrix transformations, but I would would
advise against this, as both may cause you to accidently flip the
coordinate system if you don't pay attention.)
If you choose this approach, I think you should also theoretically be
able to get away without a `sky` vector.
(C) Look At: Specify a `look_at` point; the camera will automatically be
re-oriented (but remain at the same place) to point at the specified
location. This is my preferred approach.
If you choose this approach, a `sky` vector is mandatory. POV-Ray will
re-orient the camera in such a manner that the effective `up` vector
will remain as close as possible to the `sky` vector
In all three variants, you can zoom by either messing with the length of
the direction vector in relation to that of the up/right vectors, or by
simply specifying an `angle` parameter.
Date: 8 Sep 2016 17:41:42
Message: <57d1db16$1@news.povray.org>
As I said, I did this and it did not help.
Mike
Date: 8 Sep 2016 17:44:52
Message: <57d1dbd4$1@news.povray.org>
>         camera
>             spherical
>             angle        360 180
>             up        Camera_Up
>             right        Camera_Right
> what is going on?
> Mike
I'd start with a default like camera located at the origin and looking
toward +z.
Next, I would translate it to the desired location then orient it using
look_at.
camera{
  spherical
  location <0,0,0> // from here
  up y sky y
  right 4/3*x
  direction z // to here we replicate the default camera parameters
  translate Camera_Location
  look_at Interest_Point
  angle View_Angle
If the image is upside down, you can :
negate the up and sky vector. You may also need to negate the right
vector in this case.
rotate the camera 180° around the z axis before translating it.
Date: 8 Sep 2016 17:59:55
Message: <57d1df5b$1@news.povray.org>
>> what is going on?
As I said, I tried totally removing the matrix transformation, and the
result was the same upside-down orientation.
I tried setting both the "sky" vector and the "up" vector to "-y", but
the result was no different.
The camera is spherical. Do I really need to scale the "up" and "right"
vectors to the image dimensions? I was under the impression that the
spherical camera already automatically fills a 2:1 aspect ratio image.
Here's my non-spherical version of the camera, which works perfectly
well and without problems. I am generating panoramic images, and this is
the cube mapped version.
		#declare Camera_Up		= -y*2;
		#declare Camera_Right		= +z*2;
		#declare Camera_LookAt		= Camera_Location + Camera_Direction;		// does
nothing right now
		#ifndef (view_direction)
			#declare view_direction = frame_number;
		#switch (view_direction)
			#case (0)
				#declare Camera_Rotate	= <0,000,0,>;
			#break
			#case (1)
				#declare Camera_Rotate	= <0,090,0,>;
			#break
			#case (2)
				#declare Camera_Rotate	= <0,180,0,>;
			#break
			#case (3)
				#declare Camera_Rotate	= <0,270,0,>;
			#break
			#case (4)
				#declare Camera_Rotate	= <0,0,090,>;
			#break
			#case (5)
				#declare Camera_Rotate	= <0,0,270,>;
			#break
			rotate		Camera_Rotate
		//	matrix <0,0,-1,0,1,0,1,0,0,0,-88,-640>		// front entrance
			matrix <0,0,-1,0,1,0,1,0,0,0,-88,100>		// courtyard
		camera
			up		Camera_Up
			right		Camera_Right
I don't understand why with the spherical camera I need to "tweak the
perspective" further. I know I can fix the scene by simply rotating it
180 degrees in GIMP. But I can't shake the feeling that there's a bug in
the spherical camera code.
Mike
Date: 8 Sep 2016 18:30:22
Message: <57d1e67e$1@news.povray.org>
>> Camera_Direction;
>> entrance
>>         camera
>>             spherical
>>             angle        360 180
>>             up        Camera_Up
>>             right        Camera_Right
>> what is going on?
>> Mike
> toward +z.
> look_at.
> camera{
>   spherical
>   up y sky y
>   right 4/3*x
>   angle View_Angle
> Alain
For a spherical camera this is totally wrong.
Mike
Date: 8 Sep 2016 18:58:46
Message: <57d1ed26$1@news.povray.org>
Am 09.09.2016 um 00:00 schrieb Mike Horvath:
My bad, I didn't pay much attention to the camera type.
Having had a closer look at the source code, here's my updated
(counter-intuitive) advice:
- To mirror the image vertically, flip the _right_ vector.
- To mirror the image horizontally, flip the _up_ vector.
- To mirror the image vertically _and_ turn the camera 180 degrees, flip
the direction vector.
Entirely untested, but that's what I infer from the source code.
