POV-Ray : Newsgroups : povray.advanced-users : Strange colors for SpectralRender metals Server Time
6 Jul 2025 01:47:20 EDT (-0400)
  Strange colors for SpectralRender metals (Message 1 to 7 of 7)
Subject: Strange colors for SpectralRender metals
Date: 2 Jan 2014 14:25:01
Message: <web.52c5ba798f4d4bea306548240@news.povray.org>
Using Ive's SpectralRender, I get strange colors for chrome and gold.
M_Chrome() renders a dark navy blue, and M_Gold() renders a pure yellow that
seems much too garish.  I'm sure the little bit of gold I've seen in person is
only 14 kt, but the images of pure gold I've seen are less saturated and have an
orange cast.
Using C_Metal in preview mode yields rgb <0.5496, 0.5559, 0.5549> for chrome and
rgb <1.0224, 0.7810, 0.3449> for gold, which are much more the colors I expect.
However, M_Chrome() and M_Gold() in preview mode yield smoky black and silvery
white, respectively.
The following scene description file illustrates the anomalies:
_______________________________________________________________
#version 3.7;
#include "spectral.inc"
#ifndef (Rad) #declare Rad = yes; #end
global_settings
{ assumed_gamma 1
  max_trace_level 15
  #if (Rad)
    radiosity
    { count 100
      error_bound 0.5
      pretrace_end 2 / image_width
      pretrace_start 32 / image_width
      recursion_limit 2
camera
{ location <0.0, 1.25, -7.0891>
  look_at <0.0, 1.25, 0.0>
  angle 38.8508
light_source
{ <-3.6875, 8.6250, -6.3869>,
  SpectralEmission (E_D65) * 5013.1
  fade_power 2 fade_distance 0.10417
  spotlight point_at <0.0, 1.25, 0.0> radius 45 falloff 90
#default { finish { diffuse 1 ambient SpectralEmission (E_D65) * 0.24520 } }
box
{ -1, 1 scale <9, 10, 9>
  pigment { rgb 0.6 }
plane
{ y, 0
  pigment { checker rgb 0.03 rgb 0.6 }
sphere
{ <-1.2, 1, 0>, 1
  M_Chrome (1)
sphere
{ <1.2, 1, 0>, 1
  M_Gold (1)
Subject: Re: Strange colors for SpectralRender metals
Date: 3 Jan 2014 07:05:27
Message: <52c6a787@news.povray.org>
Am 02.01.2014 20:14, schrieb Cousin Ricky:
> orange cast.
I wouldn't expect "classic" materials (i.e. defined in terms of an RGB
colour) to work "out of the box" with SpectralRender. There are
infinitely many spectra that match any given RGB triplet, and
SpectralRender needs to resort to wild guessing in order to pick one of
them.
Date: 3 Jan 2014 11:00:01
Message: <web.52c6dd1d2edc18a6306548240@news.povray.org>
> them.
That's not what I'm doing.  I'm using the spectral definitions of the metals
that are bundled with SpectralRender.  (The only RGB colors in the example are
for the plain gray floor and walls, which I didn't see the need to jump through
hoops just to get a flat spectral curve, and which turned out as expected
anyway.)
Date: 4 Jan 2014 11:48:50
Message: <52c83b72$1@news.povray.org>
Am 03.01.2014 16:54, schrieb Cousin Ricky:
>> them.
> anyway.)
I see...
Looking at the M_Spectral_Metal macro, I find that it looks bogus to me.
For starters, instead of "#if (WavelengthIndex < 0)" the tests should be
"#if (!SpectralMode)"; the "fresnel on" should only be used in spectral
mode (if at all); and in non-spectral mode there should only be one
parameter to reflection, as the "metallic" keyword already takes care of
all variable effects applicable to metals.
I get good results with the following:
#macro M_Spectral_Metal (N, K, Reflectance)
   material {
       pigment { C_Metal(N, K) }
       finish {
         ambient 0  emission 0  diffuse (0.5 - Reflectance*0.45)
         reflection { Reflectance metallic }
         conserve_energy
         brilliance EXT_Metal(N, K)
         metallic
I concede that this is probably not 100% exact regarding the variable
reflection effects, but it's certainly better than what the current
macro gives us ;-)
Date: 4 Jan 2014 17:45:13
Message: <52c88ef9@news.povray.org>
Am 04.01.2014 17:48, schrieb clipka:
>>> them.
>> metals
>> example are
>> jump through
>> anyway.)
> I see...
>    material {
>      texture {
>        finish {
>          conserve_energy
>          metallic
> #end
Maybe this is what it was supposed to be:
   material {
       finish {
         reflection {
           #if (SpectralMode)
             Reflectance * C_Metal_(N,K), Reflectance fresnel on
           #else
         conserve_energy
         metallic
     interior { IOR_Metal(N, K) }
(where C_Metal_(N,K) is identical to C_Metal(N,K) except that it omits
the "rgb" keyword)
Date: 5 Jan 2014 10:25:01
Message: <web.52c979082edc18a6306548240@news.povray.org>
> the "rgb" keyword)
Rather than write a new macro, I replaced:
with:
  #local C_Metal_ = C_Metal (N, K);
  Reflectance * C_Metal_.x, Reflectance fresnel on
(With or without the .x makes no difference.)  Your first attempt looks more
believable.  I have posted some results in p.b.i.
Date: 7 Jan 2014 11:43:08
Message: <52cc2e9c$1@news.povray.org>
> orange cast.
Well, it happened *AGAIN* that I did mess things up.
As Christoph spotted the statement #if (WavelengthIndex) doesn't make
any sense (a relict from version 0.1) but the whole file is the wrong one.
I have a quite automated way of generating the zip file and updating the
web-page and somehow managed it to copy the wrong file while I use local
the correct one, so would never have spotted my mistake.
Anyway, I'll find some time tomorrow and correct this mess. And BTW
thanks for trying the whole spectral thing.
-Ive
