POV-Ray : Newsgroups : povray.advanced-users : Problem rendering large image Server Time
28 Sep 2024 19:01:11 EDT (-0400)
  Problem rendering large image (Message 1 to 10 of 10)
Subject: Problem rendering large image
Date: 18 Oct 2012 07:15:01
Message: <web.507fe48eb1b5e2779a9ee9f50@news.povray.org>
When attempting to render a 6000*8000 pixel image (V 3.7.0 RC6 msvc10.win64), I
get the following message :
Intermediate image storage backing file write failed at creation.
Failed to start render: Cannot access data in file.
Smaller size images render without any problem.
The quickres.ini entry is :
[6000x8000, AA 0.3]
Width=6000
Height=8000
Antialias=On
Antialias_Threshold=0.3
Anything I can do about this?
Subject: Re: Problem rendering large image
Date: 18 Oct 2012 13:40:36
Message: <50803f14@news.povray.org>
I'm guessing that the file is hitting the magic 2-gigabyte line, but
I'm not sure why that should matter, especially since you are using
the 64-bit version of POV-Ray. (Which filesystem are you using? The
only one that has a 2-gigabyte limit is FAT32, but it would be really
strange if your system were using that. Could still be a possibility.)
Someone who has more detailed knowledge about the internal working of
the intermediate file should be able to give a better answer.
Date: 18 Oct 2012 14:00:01
Message: <web.5080426d8203a6b9a9ee9f50@news.povray.org>
> I'm guessing that the file is hitting the magic 2-gigabyte line, .....
It's strange because I did an 8000*8000 pixel image before , but this was with
an earlier version of 3.7, so I wonder if something changed in this area during
the last release...
Date: 18 Oct 2012 14:05:01
Message: <web.508044468203a6b9a9ee9f50@news.povray.org>
"Jos leys" <jos### [at] pandorabe> wrote:
If some good soul with the same Povray version installed on a 64bit Windows
system could try and render a large (say 8000*8000) image, then it would be
clearer if the culprit is my computer or the program...
Date: 18 Oct 2012 14:33:17
Message: <50804b6d$1@news.povray.org>
tried this with a simple sphere and checkered plane, memory use went
up to about 1 GB during the first 20 seconds (which were also reported
as render time). Reported render state was about 20%, memory use then
slowly trickled down over the next minutes as the render completed.
I assume the last part is actually some transfer time, data shoveling
and image encoding.
I would expect the extra memory requirement for high resolution
renders to be mostly scene-independent. But I could be wrong.
Date: 19 Oct 2012 05:30:11
Message: <50811da3$1@news.povray.org>
Le 18/10/2012 19:40, Warp nous fit lire :
The 2 Gigabyte line should be met with
Intermediate image storage backing file write/seek failed at creation.
Normally...
(that's the one that's doing the lseek64/seek_set call to reach the tail
of the file at creation: combined with the next write, it will allocate
the full file on the disk at creation time, you do not want the write to
fail later due to a disk full after 72 hours of rendering ;-) (unless
the OS handle it with an hollow file, which windows does not, IIRC) )
The message "Intermediate image storage backing file write failed at
creation." is due when the actual write of 3 integers (well, it's  wider
than "int", currently it's a "long") fails (or rather: it should have
returned the actual size written, and it does not match the size.
To sum up: (oversimplifying the actual code)
long long last_position;
//value is about height*width * 5 * sizeof(COLC)
//  it might get a bit more for rounding of blocking factor
// it's about 2 400 000 000 in this case
lseek64(the_file_descriptor, last_position, SEEK_SET)
long info[3];
info[0] = something;
// the data structure size for a single pixel in the cache
info[1] = more; // the width
info[2] = yet; // the height
if (write(the_file_descriptor ,&info[0],3*sizeof(long)) !=
3*sizeof(long)) { Your Failure }
Any clue why it might fails on Windows ?
Does the lseek be deferred until actual usage ? (which write does)
A packing issue with the array of long ? (but even if the written data
are bogus, we asked for X bytes to be written, we should get X bytes
written, no more, no less. (at worst, X could be shorter than the
coverage of info[], or do you see a way to access bytes out of info[]
scope ?)
Or the call to write was interrupted ? (Windows actually has to allocate
the whole file now on disk: if the allocation mechanism suck, it can
take a lot of time: it has to write allocated and write all the needed
sectors, that's a write of 2.4G file here... windows is not know to
handle such request (of nearly empty file) as lightly as linux
(according the actual filesystem, linux might just somehow fake it with
an hollow file, whereas Windows will actually make the plain file right
now: with a write to disk at 50MB/s (my reference for hard disk speed
I/O), that's about 45 seconds of optimal I/O... may be more, as there is
also the underlying filesystem structures to update)
Is there on Windows a limit to the filesize that a user can create ?
(man of write talk about RLIMIT_FSIZE resource)
Date: 19 Oct 2012 13:00:01
Message: <web.508185eb8203a6b9a9ee9f50@news.povray.org>
Well, after this problem, I turned on my PC this morning and attempted again to
render the 8000*8000 file.
Off it went, without any complaints this time!
No error messages, just smooth rendering. I don't understand at all. Was it
because I had some other program open yesterday?
Anyway, thanks to all who tried to help..
Date: 19 Oct 2012 13:20:32
Message: <50818be0$1@news.povray.org>
Am 19.10.2012 11:30, schrieb Le_Forgeron:
> scope ?)
FWIW I've just created a 16000x9800 pixel file (an OpenEXR, but PNG
works the same) with 3.7RC6 msvc10.win64 and Windows 7 without any problems.
And the delay between parsing (not much to parse) and the render start
was about 3 seconds.
-Ive
Date: 19 Oct 2012 18:52:45
Message: <5081d9bd$1@news.povray.org>
Le 19/10/2012 19:18, Ive nous fit lire :
> problems.
traditional hard disk or SSD ?
Should I revise my reference speed ?
or maybe they now make a better OS with more file caching or handling of
hollow file.
Date: 24 Oct 2012 05:12:38
Message: <5087b106$1@news.povray.org>
Am 18.10.2012 20:33, schrieb Christian Froeschlin:
> and image encoding.
As a matter of fact, on Windows it isn't: Due to some quirks of the
communication between the render threads, simple scenes eat /more/
memory than complex ones (because the render threads generate image data
way faster than it can be written to the interim file).
