POV-Ray : Newsgroups : povray.advanced-users : Pointing at an object Server Time
12 Mar 2026 12:07:32 EDT (-0400)
  Pointing at an object (Message 1 to 7 of 7)
Subject: Pointing at an object
Date: 14 Feb 2012 23:01:39
Message: <4f3b2e23$1@news.povray.org>
Being dissatisfied with Point_At_Trans and Reorient_Trans, for use in my
inverse kinesics skeleton, I decided to break out the math and try to
write a replacement.  And I ended up with this macro:
#macro Point_To(tvector)
	#declare rho = sqrt (
		abs (tvector.x * tvector.x) +
		abs (tvector.y * tvector.y) +
		abs (tvector.z * tvector.z)
	#declare sigma = sqrt (
	#declare phi = degrees(acos (tvector.z / rho));
	#if (tvector.x < 0)
		#declare theta = 180 - degrees(asin (tvector.y / sigma));
	#else
		#declare theta = degrees(asin (tvector.y / sigma));
	#if
	<90 - phi, 0, theta - 90>
No doubt someone could make use of this.  :)
Subject: Re: Pointing at an object
Date: 15 Feb 2012 03:53:46
Message: <4f3b729a$1@news.povray.org>
A bit of documentation might help.
Such as : the output is a vector for use with rotate, which will
transform the x direction into the a vector aligned with the parameter.
The other vectors of the base (y & z) are not constrained and might jump
when the parameter evolves (do not be surprised in animation!).
An input parameter of <0,0,0> is not supported and might stop your scene.
Date: 15 Feb 2012 04:15:06
Message: <4f3b779a$1@news.povray.org>
> #if (tvector.x < 0)
> #else
> #end
> #if
> #end
That last #if is not correct. (...) and #end are missing...
Date: 15 Feb 2012 05:16:39
Message: <4f3b8607$1@news.povray.org>
>> #if (tvector.x < 0)
>> #else
>> #end
>> #if
>> #end
While we are at it, #local would be safer than #declare.
Date: 15 Feb 2012 07:39:34
Message: <4f3ba786$1@news.povray.org>
I copied the macro out of the file I used to test it, not the version I
saved.  In other words, the slightly erroneous one.  Yes, the last #if
is superfluous and should be deleted.  In the version I saved, all the
#declare had been changed to #local.  They were made #declare in the
testing version in order to be able to read those variables outside the
macro, for debugging purposes.
The output is a vector, to be used with rotate, that will align the
object about the origin so that its y axis will now point towards
tvector.  Jumps will occur when tvector.y = 0 and tvector.x crosses 0.
And yes, an input vector of 0 will break the macro.
Date: 15 Feb 2012 18:15:01
Message: <web.4f3c3bf38775ae27fb5881bf0@news.povray.org>
Would you care to explain what problems you experience with those macros ?
Tor Olav
http://subcube.com
Date: 18 Feb 2012 20:15:54
Message: <4f404d4a$1@news.povray.org>
The biggest problem was that they tended to jump about as y approached
zero for the target point.  For use in an IK skeleton, this was
problematic.  Mine jumps as well, but along a different axis - y at
zero, and as x approached zero.  This is better for an IK skeleton.
