POV-Ray : Newsgroups : povray.advanced-users : How to make my own 3D pigment? Server Time
8 Feb 2026 13:21:52 EST (-0500)
  How to make my own 3D pigment? (Message 1 to 8 of 8)
Subject: How to make my own 3D pigment?
Date: 22 Jun 2011 10:13:46
Message: <4e01f89a$1@news.povray.org>
I want to render objects having a self-made 3D pigment that is defined
via 3 user-defined functions (one for red, one for green and one for
blue), or via one function that returns an RGB color vector directly
(Or even an 4- or 5-dimensional rgbf, rgbt or rgbft vector)
Is that possible, somehow?
As far as I understand a user-defined pigment functions just returns a
single float that is used as an index in a color_map.
			Lars R.
Subject: Re: How to make my own 3D pigment?
Date: 22 Jun 2011 10:40:44
Message: <4e01feec$1@news.povray.org>
> defined via 3 user-defined functions (one for red, one for green and
> one for blue), or via one function that returns an RGB color vector
> directly
> a single float that is used as an index in a color_map.
  If I understood it correctly, I think the "average" pattern should help
there: create 3 separate pigments for each function, then use a
pigment_map to average them together.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 22 Jun 2011 10:45:40
Message: <4e020014@news.povray.org>
>> directly
If you want to add a filter or transmit component, use your function
this way, after the pigment itself:
filter My_Filter_Function(x,y,z) transmit My_Transmit_Function(x,y,z)
Date: 22 Jun 2011 18:19:56
Message: <4e026a8c$1@news.povray.org>
Am 22.06.2011 16:40, schrieb Jaime Vives Piqueres:
>> directly
Yup, AFAIK that's the only way to do it. For each channel, use a
color_map ranging from "rgbft 0" to "red N" (or "green N", "blue N",
etc., respectively), where N is the number of channels you intend to
mix, e.g. 4 for rgbf. (This is required because what you really want is
a sum, not the average.)
Date: 22 Jun 2011 22:20:05
Message: <4e02a2d5$1@news.povray.org>
> 			Lars R.
There are some good examples here:
http://lib.povray.org/searchcollection/index2.php?objectName=ColorSolid&version=1.21&contributorTag=SharkD
Mike
http://isometricland.com
Date: 23 Jun 2011 02:27:52
Message: <4e02dce8$1@news.povray.org>
Looks nice. I'll download it and look into its source to explore how
they did it. :-)
Thank you!
			Lars
Date: 23 Jun 2011 02:35:32
Message: <4e02deb4$1@news.povray.org>
AFAIK the pigment_maps have to be nested:
the outermost pigment is i.e. 'gradient z' and it pigment_map maps from
the "black/red/green/yellow" pigment of the front xy face to the
"blue/magenta/cyan/white" pigment of the back xy face.
The two 4-color pigments are created the same way:
A gradient in y direction to merge from "black/red" at the bottom to
"green/yellow" at the top => Front face pigment.
A second gradient in y direction to merge from "blue/magenta" at the
bottom to "cyan/white" at the top => back face pigment.
And finally, each of the four vertical ramps are "gradient x" from "left
color" to "left color + red".
Do I got it?
			Lars R.
Date: 23 Jun 2011 11:23:12
Message: <4e035a60$1@news.povray.org>
> they did it. :-)
> Thank you!
> 			Lars
I was thinking it would be a good subject for a tutorial, but I'm not
sure I'll get around and do it.
