POV-Ray : Newsgroups : povray.advanced-users : Quadtrees/Octrees: Possible with POV's SDL? Server Time
9 Jun 2026 22:29:44 EDT (-0400)
  Quadtrees/Octrees: Possible with POV's SDL? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Quadtrees/Octrees: Possible with POV's SDL?
Date: 31 Mar 2011 20:20:00
Message: <web.4d95196edc51ece9b05ef170@news.povray.org>
Have a look at this thread from a few years ago
http://news.povray.org/povray.advanced-users/thread/%3C446b33a3@news.povray.org%3E/?ttop=356390&toff=300
-tgq
Date: 31 Mar 2011 20:55:01
Message: <web.4d95222bdc51ece9b05ef170@news.povray.org>
> -tgq
Odd, link doesn;t show up in the web interface.
-tgq
Date: 31 Mar 2011 22:30:58
Message: <4d9538e2@news.povray.org>
>> -tgq
> -tgq
No problem on my side. Your link works good.
Date: 31 Mar 2011 23:20:01
Message: <web.4d9543fbdc51ece9b05ef170@news.povray.org>
> >> -tgq
> > -tgq
> Alain
It's odd.  I've seen it recently on the web version.  The link isn't there in
the message, but does appear in the reply box (I can see it while typing this
response, but it won't be visible on the actual post).  Must be some html thing.
-tgq
Date: 1 Apr 2011 07:12:37
Message: <4d95b325$1@news.povray.org>
On 31.03.11 20:39, stbenge wrote:
> Hi,
> I'm trying to find an efficient way to test all points within a set against
> each other. Quadtrees/octrees seem like the way to go, but... it appears
> that I need arrays containing vectors with other arrays mixed in. POV
> doesn't allow that sort of thing.
> Would something like this work for quad/octrees?
> #declare Array =
> array[2]{
> array[1]{
> <0,0,0>
> array[2]{
> array[1]{
> <0,0,0>
> array[1]{
> <0,0,0>
> Am I assuming the worst? What would be a good way to structure my data?
You can build trees with POV-Ray arrays indeed. Note that arrays inside
arrays do not need to have the same size or dimension.
     Thorsten
Date: 1 Apr 2011 13:09:42
Message: <4d9606d6@news.povray.org>
That discussion is interesting; it is now bookmarked :) I may eventually
use a hybridized technique based on some of those principles.
The web interface is a bit buggy sometimes...
Date: 1 Apr 2011 13:20:46
Message: <4d96096e@news.povray.org>
>> #declare Array =
>> array[2]{
>>  array[1]{
>>   <0,0,0>
>>  array[2]{
>>   array[1]{
>>    <0,0,0>
>>   array[1]{
>>    <0,0,0>
Right, I figured out that one :) I just can't mix objects, vectors,
floats, other arrays, etc. together.
Do you think the above array structure would work for data trees though?
Where each 1D array entry corresponds to a filled bucket? As I said
before, I'm a total newbie when it comes to these things :(
Thanks Thorsten,
Sam
Date: 1 Apr 2011 13:40:02
Message: <4d960df2$1@news.povray.org>
>> against each other. Quadtrees/octrees seem like the way to go, but...
>> it appears that I need arrays containing vectors with other arrays
>> mixed in. POV doesn't allow that sort of thing.
> You might be better off exporting data from another programming
> language.
Great suggestion, Christian! I spent the better part of yesterday doing
just that.
The best option (and the most accessible) was to use voro++, a Voronoi
library for C++. Now I can generate a list of nearest neighbors for each
point, which will be useful for many things. In POV, testing the
neighbors of 1024 points (even adding spheres to each point, cylinders
between them) takes less than a second to parse! The calculations that
the voro++ app itself performs take hardly any time at all. Of course to
do this I now need to export my points from POV, run my application, and
then run my scene file.
I may investigate the possibility of calling a batch file from within
POV-Ray so I can perform calculations iteratively between frames. If I
can do /that/, I can run a particle simulation with even more points
than before :)
Sam
Date: 3 Apr 2011 18:39:52
Message: <4d98f738@news.povray.org>
You can also take the reverse approach and write a batch
file that executes generator and render as needed.
Date: 3 Apr 2011 23:53:59
Message: <4d9940d7$1@news.povray.org>
Whichever way works best.... I'll find out :)
I read that for some discrete element methods (DEMs) the
neighbor-finding part needs to only be calculated once every few frames.
I'm sure this has its consequences, but it would be a good way to save
time. Unfortunately I have no idea how to do that... I might need to
write an extra program just to generate batch files on-the-fly...
