POV-Ray : Newsgroups : povray.advanced-users : Improving media performance Server Time
10 Jan 2025 02:07:39 EST (-0500)
  Improving media performance (Message 1 to 10 of 16)
Subject: Improving media performance
Date: 25 Jun 2010 11:11:04
Message: <4c24c708$1@news.povray.org>
I'm using the following media for the atmosphere inside the spinner.
   interior
     media
       scattering
         4, <0.2,0.4,1.0>  // crappy approximaion of TerraPOV value
         extinction  1
       density
         cylindrical
         poly_wave  0.25
         density_map
           // should be based on city_units!!!
           [0  rgb 100/5000000]
           [1  rgb 010/5000000]
         scale  city_radius
         rotate  x * 90
The "city_radius" is something less than 1000 units. What kinds of stuff
can I do to improve rendering times with this media enabled? Right now
it's the single greatest performance bottleneck in my scene.
http://isometricland.com
Subject: Re: Improving media performance
Date: 25 Jun 2010 11:56:14
Message: <4c24d19e$1@news.povray.org>
Am 25.06.2010 17:11, schrieb SharkD:
At this size, wouldn't it be more realistic to have a roughly constant
atmospheric density?
Date: 25 Jun 2010 16:24:38
Message: <4c251086$1@news.povray.org>
I'm not sure. I forgot to say in my last post that 1 unit = 1 meter.
Would the fact that "gravity" is zero at the center make a difference?
For that matter, how would a gas behave in a cylinder that is spinning?
I would think that it would tend to remain completely at rest except
where it comes into contact with the surface objects. Maybe over time
sustained contact would cause it to build momentum and turn as a
whole... I dunno.
Date: 25 Jun 2010 21:41:57
Message: <4c255ae5$1@news.povray.org>
Am 25.06.2010 22:24, schrieb SharkD:
> whole... I dunno.
I guess the air dynamics will probably be... quite dynamic ;-).
Presuming that the spinning motion will in general create a slight
pressure gradient, you'll get heat convection with air flows between the
center and the rim. Those currents will be subject to coriolis forces
and the like, giving the air at higher "altitudes" even a /higher/
angular speed than near the ground. So with all this "up" and "down",
and "horizontal" speed differences, you're in for a lot of eddies I
guess. Which in turn will contribute to somewhat stabilizing angular
speed throughout the whole atmosphere.
Date: 25 Jun 2010 23:30:07
Message: <4c25743f$1@news.povray.org>
And pressure?
OT, I was planning on maybe adding a hang glider flying near the lamp.
They'd be in for one hell of a ride!
Date: 26 Jun 2010 13:59:56
Message: <4c26401c$1@news.povray.org>
> And pressure?
Not for the presure.
As the air in the center may, under some conditions, rotate slightly
faster than the station, the presure *will* diminishes from the surface
toward the center.
BUT, as the radius is /only/ 1 Km and quite probably a rim gravity less
than Earth's gravity, the presure gradient will be relatively small,
possibly small enough to be neglected. Maybe in the order of 2% or 3%.
After all, you realy don't need a full Earth gravity, something between
0.5G and 0.7G should be enough.
Date: 27 Jun 2010 11:58:17
Message: <4c277519$1@news.povray.org>
> toward the center.
> Alain
If I remove the density map, will rendering times change? Also, how
should I specify the media's density when the pattern is absent?
Date: 27 Jun 2010 13:23:57
Message: <4c27892d$1@news.povray.org>
>> toward the center.
>> Alain
You may not need as many samples, whitch will make things go faster.
NEVER use intervals and only use samples. It's MUCH faster.
Set your media base density. The density from the map get multiplied
with it.
scattering{1, rgb 0.01,.....}
Change the rgb value.
Date: 27 Jun 2010 17:16:07
Message: <4c27bf97$1@news.povray.org>
> with it.
> Alain
I'll try that then.
OT - Too bad we don't have a GasSys include like we have a LightSys one! :)
Date: 27 Jun 2010 18:02:06
Message: <4c27ca5e@news.povray.org>
Am 27.06.2010 17:58, schrieb SharkD:
It's worth a try at least. As for the density, just specify none. All
you use to control the constant density is the parameter after the
"emission", "absorption" or "scattering" keyword.
