POV-Ray : Newsgroups : povray.advanced-users : Converting pre-gamma scenes to assumed_gamma = 1? Server Time
16 May 2026 22:43:32 EDT (-0400)
  Converting pre-gamma scenes to assumed_gamma = 1? (Message 1 to 10 of 13)
Subject: Converting pre-gamma scenes to assumed_gamma = 1?
Date: 8 Jun 2010 23:57:28
Message: <4c0f1128@news.povray.org>
Any general guidelines on converting scenes created before assumed_gamma
or 3.7 were in wide use to the new defaults?
http://isometricland.com
Subject: Re: Converting pre-gamma scenes to assumed_gamma = 1?
Date: 9 Jun 2010 07:26:23
Message: <4c0f7a5f@news.povray.org>
Am 09.06.2010 05:57, schrieb SharkD:
That's a bit problematic: Before "assumed_gamma 1.0" or the most recent
3.7 betas, the color math was simply /wrong/. So in order to get exactly
the same result, you'd have to mimick that wrong color math - which 3.7
refuses to, except for legacy scenes using "#version 3.6" (or anything
smaller than 3.7) and "assumed_gamma 2.2".
If you do want to port the scene to the right math, here's what I expect
to be the most important steps:
(0) In the ini-file, set the "Display_Gamma" to whatever fits your
system; set "File_Gamma" to the same. (Ideally, your system should have
a Display_Gamma of 2.2.)
(1) In the scene file, use "#version 3.7", and remove any
"assumed_gamma" statement.
(2) Gamma-adjust all color literals, by raising the R,G,B components to
the power of 2.2 (or wait for the next beta, and add "gamma 2.2" to the
color literal). Check your scene for colour values that are computed
from some other values - you may (or may not) want to gamma-adjust these
as well.
(3) Check your scene for input image files, and whether they are handled
properly regarding gamma. For images that are used as anything non-color
(e.g. height field data, bump map, texture map or what-have-you),
explicitly specify "file_gamma 1.0" after the filename (next beta will
also support "gamma 1.0" here). For any images that do wind up being
used as a colour, try the default first (i.e. no "file_gamma"
statement); if the colours appear too washed-out or too strong, try
explicitly specifying "file_gamma srgb".
(4) Toy around with overall brightness and/or brightness of individual
light sources, until you feel comfortable with the illumination. You may
also want to tweak some of the colours in your scene (both pigment and
light sources). If you're using self-made input image files, you may
also want to tweak their file_gamma setting, but try to avoid this with
3rd party input images (you should usually find a way to make them work
by tweaking the scene rather than the image).
Date: 9 Jun 2010 15:42:25
Message: <4c0feea1$1@news.povray.org>
> as well.
Mind if I copy your post to the wiki?
Date: 9 Jun 2010 15:57:18
Message: <4c0ff21e$1@news.povray.org>
> as well.
Are you sure about raising to a power? Old scenes are generally brighter
in 3.7 than they were originally, so wouldn't you want to lower them
instead?
Date: 9 Jun 2010 17:04:18
Message: <4c1001d2$1@news.povray.org>
Am 09.06.2010 21:57, schrieb SharkD:
>> as well.
> instead?
Yes, I am sure; note that raising values between 0.0 and 1.0 to some
power > 1 does actually give you smaller values (e.g. 0.50^2 = 0.25).
Date: 9 Jun 2010 17:08:13
Message: <4c1002bd$1@news.povray.org>
Am 09.06.2010 21:42, schrieb SharkD:
The idea already crossed my mind, too - so as I currently don't find the
time myself, by all means go ahead.
Date: 9 Jun 2010 17:33:21
Message: <4c1008a1@news.povray.org>
>>> as well.
>> instead?
Oh, OK! Just tested it and everything looks good so far.
Date: 9 Jun 2010 19:54:09
Message: <4c1029a1$1@news.povray.org>
Am 09.06.2010 13:26, schrieb clipka:
I just recalled another thing:
You may want to check your adc_bailout setting; in darker scenes, the
current defaults may still be too high and cause visible artifacts.
(I think the adc_bailout mechanism actually needs an overhaul to better
suit proper gamma handling as well as HDR output; I don't think it will
be too easy though.)
Date: 17 Aug 2010 19:35:17
Message: <4c6b1cb5@news.povray.org>
> as well.
What about colors like <1,1,1> or <1,0,0>? Raising them to a power has
no effect.
Date: 17 Aug 2010 19:59:41
Message: <4c6b226d$1@news.povray.org>
>> as well.
> no effect.
And there are also cases where assumed_gamma was (ab)used instead of
ajusting the lights intencity or the finish. Like: My scene is to
dark/bright, don't bother looking at the lights/finishes/pigments,
change assumed_gamma to compensate.
Often, you'll need to adjust the falues of the light_source as well as
the pigments and textures.
