POV-Ray : Newsgroups : povray.advanced-users : Color conversion Server Time
17 May 2026 02:28:38 EDT (-0400)
  Color conversion (Message 11 to 20 of 30)
Subject: Re: Color conversion
Date: 11 Nov 2009 04:31:44
Message: <4afa8480$1@news.povray.org>
> Taken care of by whom? Well, thats a rhetoric question 'cause obviously
> you do *NOT* use chromatic adaption but again and in more detail:
> chromatic adaption is *ALWAYS NEEDED* when your target color space uses a
> whitepoint that differs from D50 and the source xyz is referring to
> reflective colors (as Munsell) and not to emitted colors (as spectral
> data).
Doesn't that depend on whether he wants to reproduce the exact XYZ colour on
his monitor, or the colour that the surface would have looked if lit with
the same white point as his monitor rather than the original white?
Date: 11 Nov 2009 10:56:12
Message: <4afade9c@news.povray.org>
>> obviously you do *NOT* use chromatic adaption but again and in more
>> detail: chromatic adaption is *ALWAYS NEEDED* when your target color
>> space uses a whitepoint that differs from D50 and the source xyz is
>> referring to reflective colors (as Munsell) and not to emitted colors
>> (as spectral data).
> colour on his monitor, or the colour that the surface would have looked
> if lit with the same white point as his monitor rather than the original
> white?
I'm talking about the correct conversion xyY to s(c)RGB and nothing
else. How exact the reproduction on any kind of monitor will be depends
on quality and calibration of that device and has nothing to do with the
  color space conversion itself. The second half of your sentence does
not make much sense.
-Ive
Date: 12 Nov 2009 04:18:15
Message: <4afbd2d7$1@news.povray.org>
> I'm talking about the correct conversion xyY to s(c)RGB and nothing else.
In that case the idea of a "source whitepoint" is meaningless - xyY
specifies colours exactly in absolute colour space, there is no need for a
reference white, nor does one exist.  An xyY colour like (0.3,0.3,10)
specifies one unique colour exactly, no need for any additional information
about a white point.
Date: 12 Nov 2009 05:13:33
Message: <4afbdfcd@news.povray.org>
The CIE calls it a device independent color space.
> a reference white, nor does one exist.
The CIE has defined D50 as reference white for the device independent
xyz color space and e.g. every spectrophotometer including my own one is
calibrated to D50 for exactly this reason.
> information about a white point.
There is a strong need to take the reference white and the whitepoint of
any device dependent target color system (and e.g. RGB or CMY or YCC are
always device dependent) into account.
You can only ignore refrence white for e.g. converting from CIE xyz to
CIE L*a*b 'cause L*a*b is also a device independent color space.
-Ive
Date: 12 Nov 2009 05:31:56
Message: <4afbe41c$1@news.povray.org>
> The CIE has defined D50 as reference white for the device independent xyz
Sure, but your meter does not use the reference white to calculate xyY
values, these are calculated directly from the measured spectral response
using only the colour matching functions - a "reference white" does not
appear in these calculations at all!
(Your meter *will* use the reference white of D50 to calculate things like
dominant wavelength, L*a*b* colour, saturation, etc).
Of course, but showing an exactly specified colour (like XYZ, xyY, Yuv etc)
on an sRGB monitor is a simple process.  You can see the calculation here:
http://en.wikipedia.org/wiki/SRGB#Specification_of_the_transformation
It is completely incorrect to do any chromatic adaption before plugging the
XYZ values into the calculation.
FWIW, if you do attempt a chromatic adaption, eg from D50 to D65, what you
are in affect doing is saying "ok these colours come from a reflective
object lit with D50, now tell me how they will appear if I had instead lit
it with D65".  I don't understand why you would want to do that if you
simply want to show a particular xyY colour on a monitor.
> You can only ignore refrence white for e.g. converting from CIE xyz to CIE
Err no, CIE L*a*b* colour space *needs* a reference white.  xyY (or XYZ, Yuv
etc) does not.
Taken from: http://en.wikipedia.org/wiki/Lab_color_space
"Lab values do not define absolute colors unless the white point is also
specified."
Date: 12 Nov 2009 07:57:57
Message: <4afc0655$1@news.povray.org>
>> is calibrated to D50 for exactly this reason.
> response using only the colour matching functions - a "reference white"
> does not appear in these calculations at all!
Err, my spectrophotometer has to illuminate the surface to be measured
to get the reflected spectral data (otherwise everything would obviously
be just pitch black) and therefor it is calibrated to D50. I can also
measure spectral emissions (e.g. to calibrate a monitor) but thats a
different story.
> etc) on an sRGB monitor is a simple process.  You can see the
> calculation here:
Thanks for the link but I'm already quite familiar with such things,
they are part of my per day pay-job.
> the XYZ values into the calculation.
Err, no.
> you are in affect doing is saying "ok these colours come from a
> reflective object lit with D50, now tell me how they will appear if I
> had instead lit it with D65".  I don't understand why you would want to
> do that if you simply want to show a particular xyY colour on a monitor.
Your main misconception seems to me that you are assuming xyY values are
some given values already there by definition, but within a real world
work-flow they are almost always the result from measurement of a
reflected spectrum by a spectrophotometer (like e.g. the Munsell xyY
values or the ones for the GretagMacbeth Colour Chart or databases for
real world materials or Pantone colors and so on...). And measurement
indeed implies that objects are illuminated by some device.
And as you insist on your "showing on a monitor" phrase, this is in fact
quite complicated and a different beast as using s(c)RGB just as a
working color space e.g. within POV-Ray (and it seems to become the de
facto standard there).
sRGB on your monitor also assumes a dominant lighting condition of about
to take the chromatic adaption of the human visual system into account.
sounds familiar to you, remember the D50 reference white, even if you
still seem to thing this doesn't matter.
In other words sRGB as an output device color space requires a viewing
Therefor *in this case* there has no (mathematical) chromatic adaption
to be applied as the chromatic adaption is assumed to be done by *your*
eye/brain system.
How many working places of computer users do you think will match this
condition? Does yours?
Anyway, for professional environments - where the work flow implies full
color-management and the closest possible visual color match on various
devices is needed - there are much more evolved concepts around (defined
by the CIE and ICC) for taking the environment lighting condition into
account.
But again, all this is not relevant when using s(c)RGB as a working
color space and there has something like the Bradford chromatic adaption
to be applied for given xyY values to make e.g. POV-Ray calculate with
"good" RGB values.
Very true. And it just happens that CIE L*a*b is just another
mathematical representation of the CIE xyz color space where the same
*need* for reference white exists.
> xyY (or XYZ, Yuv etc) does not.
Wrong. See above.
-Ive
P.S. sorry if I may sound rude when it comes to this subject but not a
so long time ago I was forced to explain such things more than once a
day to people who had not the faintest idea what color management is
about but still did insist in having s strong opinion how such a thing
should work - and I do not mean you ;). I guess it has something to do
with the fact that color vision is such a natural thing to humans that
*everybody* seems to think he has also a basic understanding what color
science is about...
Date: 12 Nov 2009 08:49:27
Message: <4afc1267$1@news.povray.org>
Ah ok - I see where the confusion is now between us.  You are assuming that
the OP wanted to reproduce the reflective surface that those xyY values were
measured from, whereas I was just reproducing those exact xyY colours on the
monitor.  FWIW my colour meter just measures the incoming spectrum, it has
no light source, in fact we usually use it in a totally dark room.
> Thanks for the link but I'm already quite familiar with such things, they
Mine too, but mine is mainly dealing with emitted light, not reflective, I
suspect that's where the confusion has arisen between us.
Yes, sorry, the link that was posted here was just a list of xyY values, I
assumed you just wanted to reproduce those xyY values on an sRGB monitor (in
the dark), not the colour of some reflective surface that the xyY data was
originally generated from when viewed under sRGB standard conditions.
> Very true. And it just happens that CIE L*a*b is just another mathematical
> representation of the CIE xyz color space where the same *need* for
That's not strictly true.  When dealing with reflective surfaces, you need
to specify the *illuminant* used, but with CIELAB you need to additionally
specify a reference white - these do not necessarily need to be the same
thing.  If you are using XYZ (or xyY, Yuv, Yu'v' etc) then you only need
specify the illuminant.
That is why in our specs for emissive displays, if the customer wants XYZ
values they just get XYZ values, but if they want CIELAB then the reference
white needs to be specified for it to make sense.
Date: 12 Nov 2009 09:45:07
Message: <4afc1f73$1@news.povray.org>
> need to specify the *illuminant* used, but with CIELAB you need to
> additionally specify a reference white - these do not necessarily need
> to be the same thing.  If you are using XYZ (or xyY, Yuv, Yu'v' etc)
> then you only need specify the illuminant.
> XYZ values they just get XYZ values, but if they want CIELAB then the
> reference white needs to be specified for it to make sense.
Yes, OK, but I always failed to see the reason why anybody would use
L*a*b with e.g. D65 'cause every piece of hardware and any color
management software I could put my hands on is using D50.
Otherwise I'm happy that things seem to be clear now ;)
-Ive
Date: 12 Nov 2009 10:37:25
Message: <4afc2bb5$1@news.povray.org>
In some industries (eg the one I work in) D65 is the "de facto" standard
used for everything - illuminants, CIELAB reference white, reference for
dominant wavelength/saturation values, etc.  Every bit of kit I have and
every piece of software/spreadsheet we use is set up for D65.  I would
imagine that if some customer came along and started asking for D50 as the
standard there would be *massive* confusion throughout our department and
everything would come out wrong :-)  It's just what you're used to I guess.
Date: 12 Nov 2009 12:29:24
Message: <4afc45f4@news.povray.org>
> the standard there would be *massive* confusion throughout our
> department and everything would come out wrong :-)  It's just what
Ok then. Somehow I did suspect that such other worlds do exist somewhere
out in the wild ;)
-Ive
