POV-Ray : Newsgroups : povray.advanced-users : Strange pigment error (3.6.1) Server Time
16 May 2026 23:53:24 EDT (-0400)
  Strange pigment error (3.6.1) (Message 1 to 10 of 12)
Subject: Strange pigment error (3.6.1)
Date: 11 Sep 2009 02:42:04
Message: <4aa9f13c$1@news.povray.org>
I'm using the following pigment:
#local Temp_fnc1 = function {pigment {spherical}}
#local Temp_fnc3 = function
	Temp_fnc1(x, log(y + 1) / log(2),z).gray
The image actually *renders* most of the way. But about 3/4 done it
quits with the error, "Parse Error: Floating-point exception detected in
function 'Temp_fnc3'. Your function either attempted a division by zero,
used a function outside its domain or called an internal function with
invalid parameters."
Aren't parse errors supposed to occur *before* the image begins
rendering? How do I fix it?
-Mike
Subject: Re: Strange pigment error (3.6.1)
Date: 11 Sep 2009 03:27:06
Message: <4aa9fbca$1@news.povray.org>
Forgot to add the warp which seems to be the actual culprit:
warp
	turbulence	<1/4,1/64,1/4,>
	octaves		4
	lambda		2
	omega		1/2
Date: 11 Sep 2009 06:21:41
Message: <4aaa24b5@news.povray.org>
> rendering?
This is nothing that could be caught during parsing. After all, how is
POV-Ray supposed to know whether or not the function will be called with
parameters value that will cause one of the sub-expressions to operate
on invalid operands?
For instance, if your function is
     function { 1 / (x+1) }
then how should POV-Ray know whether you will make sure it isn't called
for any x smaller than -1?
 > How do I fix it?
The problem is most likely the subexpression
     log(y + 1)
which is undefined for any y <= -1. So make sure the pattern's native
range of y <= -1 is always outside whatever object it is applied to.
Or clip the parameter to a safe range, e.g.:
         Temp_fnc1(x, log(max(0.0001,y+1)) / log(2),z).gray
which forces the parameter for log() to be no smaller than 0.0001.
Date: 11 Sep 2009 16:39:05
Message: <4aaab569@news.povray.org>
> rendering?
  It should be labeled "rendering error" rather than "parse error".
Only a cosmetic problem, but perhaps worth a bug report.
Date: 11 Sep 2009 16:50:39
Message: <4aaab81f$1@news.povray.org>
>> rendering?
How about "post-rendering parse error"?
-Mike
Date: 11 Sep 2009 16:52:27
Message: <4aaab88b$1@news.povray.org>
>  > How do I fix it?
>     log(y + 1)
As I pointed out in my second post, the error only occurs after I apply
the turbulence warp.
-Mike
Date: 11 Sep 2009 16:55:02
Message: <4aaab926$1@news.povray.org>
> -Mike
Oops! I made a mistake when copying the function. Here's the actual code:
	1 - min(1, sqrt(x*x + y*y + z*z))
	max(0,min(1,Temp_fnc1(x, log(y + 1) / log(2),z)))
And the warp:
warp
	octaves		4
	lambda		2
	omega		1/2
Date: 11 Sep 2009 18:11:12
Message: <4aaacb00$1@news.povray.org>
Would not make any sense at all, as rendering does not start until
parsing has completed.
Date: 11 Sep 2009 18:14:39
Message: <4aaacbcf$1@news.povray.org>
Probably because the object normally doesn't touch the "dangerous"
range, but the warp pertubs the coordinates in such a way that the
pattern's original y<=-1 range ends up "exposed".
Date: 11 Sep 2009 19:21:10
Message: <4aaadb66@news.povray.org>
clipka wrote:
>> apply the turbulence warp.
Is it possible to do use an IF statement to substitute a different
function where y<=-1?
-Mike
