POV-Ray : Newsgroups : povray.advanced-users : Pigment functions... Server Time
9 Jun 2026 07:25:54 EDT (-0400)
  Pigment functions... (Message 11 to 17 of 17)
Subject: Re: Pigment functions...
Date: 12 Sep 2006 23:20:00
Message: <web.45077826a29fb3bbdda07a910@news.povray.org>
Samuel Benge <stb### [at] hotmailcom> wrote:
> Sometimes the only way to get enough color-saturation in a scene is to
> bump up the assumed gamma and brighten the lights. Or you could put a
> rgbt<1,1,1,2> plane in front of everything....
> ~Sam
I like to think of it as a "contrast control" (although that's not what it
was meant for, of course.) Whites stay white and blacks stay black, but all
the intermediate color/grey values can be altered.
BTW, if you have image_maps in your scene...and you want them to stay
looking the same no matter what assumed_gamma you throw at
them...converting them to the png format is the way to go.  But there's a
hitch: You have to "embed" an assumed_gamma of 1 into them somehow. This is
kind of a little quirk (?) with POV-Ray, but a useful one. Photoshop 5 (my
current version) allows this embedding (some graphics apps do, some don't,
apparently.) In Photoshop, the place to look is FILE/COLOR SETTINGS/RGB
SETUP, where you can enter a gamma of 1.  And then turn "Display using
monitor compensation" OFF there, otherwise the image (in PS) will brighten
up and the colors will look washed out.  But the image will reproduce
beautifully in POV-Ray, ignoring assumed_gamma altogether.
Ken W.
Date: 13 Sep 2006 00:00:00
Message: <web.45078185a29fb3bbc55e8ebc0@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> ...  But the image will reproduce
Hmm.  Well...uh...that's not *exactly* true, as I've just discovered from
doing a few tests. Putting some wild assumed_gamma settings into POV-Ray
(.5 up to 3) shows some subtle changes in the rendered image_map.
Especially at the .5 setting (which no one in his or her right mind would
use, of course.  I think.) Not even sure how to describe the odd effect IT
produces.  But IN GENERAL, a gamma-of-1 png image_map does stay looking
practically the same, throughout a good range of assumed_gamma values.
Ken
Date: 13 Sep 2006 08:41:59
Message: <4507fc97$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.45077826a29fb3bbdda07a910@news.povray.org...
> is
This is only tangentially related, but perhaps someone can explain the
browser issues with PNGs and gAMA chunks:
http://pmt.sourceforge.net/gamma_test/
http://hsivonen.iki.fi/png-gamma-test-results/
Is it a browser issue, or is PNG the problem?  I have heard both arguments,
but I don't understand exactly what's going on.
Anyone care to shed some light?
- How
Date: 13 Sep 2006 10:13:21
Message: <45081201@news.povray.org>
  The problem is not with the gamma value in a PNG. The problem is that
PNG *has* support for gamma value. Other formats don't have this problem
because they don't have gamma support at all.
  The problem is that some programs will write the gamma value to the
PNG while others, when reading the PNG, will ignore it. Another problem
is that when a PNG doesn't have gamma info, some programs (especially
some browsers) will "guess" a gamma value for it anyways, instead of
taking the pixels unmodified (as with all other image formats).
  So the problem is that a theoretically good idea has completely
backfired because of poor program support. Now the exact same PNG
*without* any gamma value might look different in different browsers,
simply because the makers of these browsers got confused and started
making some assumptions. Adding the gamma value to the PNG does not
help because it may still look different in different programs
because some programs will just ignore the gamma value.
  This gamma fiasco is one of the biggest reasons why the industry
(especially the WWW industry) as a whole hasn't switched to PNG from
other lossless formats.
Date: 13 Sep 2006 10:33:52
Message: <450816d0$1@news.povray.org>
news:45081201@news.povray.org...
Thanks, Warp.  Your explanation has helped me see much more clearly.
So, according to the docs, then, POV-Ray stores the gamma value as
1.0/display_gamma.  It also says "PNG is the only one that has any gamma
correction features and is therefore preferred for images that will be
displayed on a wide variety of platforms."  Isn't this somewhat misleading?
PNG is the preferred format (in part) because it has the capability of
storing gamma values, but not because PNG can be displayed on a wide variety
of platforms.  Most likely, PNGs will be displayed with many differences
across platforms/programs compared to another image format that doesn't
contain gamma information.  In order to have an image created in POV show up
most consistently (as opposed to 'correctly') across platforms, PNG is not
the best choice.
I'm not complaining, I'm just making sure I understand (from a user
perspective).  If I want my image to display as I intended it, I should use
PNG, and blame the program (browser, etc.) if it doesn't implement PNG gamma
support properly.  On the other hand, if I want to be sure my image is
displayed as consistently as possible, regardless of the program used to
view it, I should opt for some other image format, and complain quietly to
myself that I don't get to store the gamma info as I want.
- How
Date: 18 Sep 2006 05:55:00
Message: <web.450e6b0da29fb3bb725e2aee0@news.povray.org>
Yes, I think you're right. I was likewise confused, for quite a while. My
own guess is, that part of the POV documentation was written when PNG was
"the next big thing" and had great promise as a cross-platform and
cross-browser image display standard. But as Warp explained, things just
didn't work out the way they should have. Too bad. But you're right--that
part of the documentation should be rewritten.
Yep!  It may not be a perfect solution, but a non-gamma-embedding file
format would probably be a better choice. I use plain 'ol JPEG, but
that's lossy, of course. BMP or PICT are good choices, but the file
sizes are large. Alas, no ideal solution!
You and Warp have explained the present PNG situation quite clearly.
BTW, since I have both a PC and a Mac  -- with their different display
gammas of 2.2 and 1.8 respectively -- and since I do my POV'ing on the PC,
I've elected to alter IT's display gamma to be "in the middle" (2.0) so
that my final POV renders will look *almost* the same when viewed on both
platforms. (I do this with a utility called Adobe Gamma.) Just a small
detail, but better than nothing!
Ken
Date: 18 Sep 2006 13:03:32
Message: <450ed164@news.povray.org>
Thanks, this has been a very informative thread for me.  I also came across
a link discussing the use of PNGCrush to remove the ancilliary gamma
information, and a comparison of various browsers' behavior when it comes to
PNGs:  http://user.fundy.net/morris/?photoshop03.shtml
- How
