POV-Ray : Newsgroups : povray.advanced-users : Height field bug? Server Time
27 Jul 2025 07:57:53 EDT (-0400)
  Height field bug? (Message 1 to 10 of 10)
Subject: Height field bug?
Date: 28 Apr 2000 17:00:47
Message: <3909FBFE.AC2E2AC6@stud.ntnu.no>
I didn't get any response in the images group..
The hf with smooth set seems to be transmitting light. I'm using a pattern{} to
keep the scene all text. The same can be reproduced with a regular hf in the
official version. Is this a known bug?
sig.
#version unofficial MegaPov 0.4;
#declare Lys= light_source { 0, .85
    looks_like { sphere { 0, .1 pigment { rgb 1 } finish { ambient 1 } } }
object { Lys translate <1,-3,1> }
object { Lys translate <-1,-3,1> }
#default {finish {ambient 0 specular .1 roughness .05 specular 1.1 diffuse .6}}
background { rgb .1 }
disc {0,y,10 pigment {rgb 1} translate -3.1*y}
camera { location  <0, 1 ,-5> look_at 0 }
#declare Pig= pigment { color rgb <.4,.2,0>}
height_field {
    pattern 100,100 {
        hf_gray_16
        cylindrical color_map { [0 rgb 0] [1 rgb 1] }
        translate 1
        scale .3
    //smooth
    pigment {Pig}
    clipped_by {plane {-y,-.05}}
    scale <5,2,5>
height_field {
    pattern 100,100 {
        hf_gray_16
        translate 1
        scale .3
    smooth
    pigment {Pig}
    scale <5,2,5>
    translate -x*3
sphere {0,.15
    pigment {rgb x}
    translate <-1,-.2,.3>
sphere {0,.15
    pigment {rgb x}
    translate <1,-.2,.3>
Subject: Re: Height field bug?
Date: 28 Apr 2000 18:56:52
Message: <755kgss9fjb4cc4dat67s96oan4f8qul48@4ax.com>
On Fri, 28 Apr 2000 23:00:46 +0200, Sigmund Kyrre Aas
If it were a bicubic_patch I'd call it double_illuminate trouble, but
I don't think hf's have this problem. I'm at a loss too.
Peter Popov ICQ : 15002700
Date: 30 Apr 2000 07:11:15
Message: <390C14D3.322D8F0D@stud.ntnu.no>
Well, it seems to have that. While setting up a bug-report scene I ran
into another bug. It chrashes in 3.1e but not in MegaPov 0.4. Both return
"Illegal grid value in dda_traversal()" during trace. Changing the
rotation of the height fields to something else than 90*x or changing the
camera position fixes this.
My most recent official version is unable to run (Linux is down). Could
someone with the latest official version confirm this bug?
Note that the appearance of hf.gif is not relevant. Just use whatever you
have at hand.
#version 3.1;
// lights above plane:
light_source { <1,1,10>, .85 }
light_source { <-1,1,10>, .85 }
// the first camera statement causes the error
// "Illegal grid value in dda_traversal()" and eventually crashes.
#declare ChrashCam =1;
#if (ChrashCam)
    camera { location  <0,0,-3> look_at 0 }
    plane {y,0 pigment {rgb 0}}
#else
    plane { y,0.01 pigment {rgb 0}}
    camera { location  <0.01,0.01,-3> look_at 0 }
//lights below plane:
light_source { <1,-1,-10>, .85 }
light_source { <-1,-1,-10>, .85 }
#declare Rot=90*x;    // <-- changing this to 90.1*x makes it run with ChrashCam=1
// lit from behind:
height_field {  // top left
    gif "hf.gif"
    smooth              //  <-- commenting out this makes it appear black as it should
    translate -.5
    rotate Rot
    pigment {Pig}
    translate <-.6,.6,0>
height_field {  // top right
    gif "hf.gif"
    //smooth
    translate -.5
    rotate Rot
    pigment {Pig}
    translate <.6,.6,0>
// lit from front:
height_field {  // bottom left
    gif "hf.gif"
    smooth
    translate -.5
    rotate Rot
    pigment {Pig}
    translate <-.6,-.6,0>
height_field {  // bottom right
    gif "hf.gif"
    //smooth
    translate -.5
    rotate Rot
    pigment {Pig}
    translate <.6,-.6,0>
Date: 30 Apr 2000 11:33:53
Message: <390C4F7C.2D243296@pacbell.net>
> have at hand.
Without us having hf.gif to work with it would be impossible for us
to recreate your problem. The dda_traversal problem is one that is
well documented and there is no real fix for it. It is covered in
the VFAQ at Warps site -
http://www.students.tut.fi/~warp/povVFAQ/miscVFAQ.html#ddatraversal
Date: 30 Apr 2000 12:22:08
Message: <390C5DAF.CB82F32D@stud.ntnu.no>
hf.gif posted to p.b.i
Date: 30 Apr 2000 20:30:27
Message: <390cd023@news.povray.org>
pattern{} to
the
Peter Popov <pet### [at] usanet> replied:
But aren't the smooth height field and the bicubic patch essentially the
same?  i.e. they are both internally subdivided into meshes of smooth
triangles.  This means that, in official POV at least, they both use double
illumination, which is why you get the translucent effect.
Date: 1 May 2000 15:32:22
Message: <mcmrgss7uja9ptc62r9vbqgrv6auss8od4@4ax.com>
On Mon, 1 May 2000 10:26:52 +1000, "Chris Colefax"
I know, it's just that I don't recall anyone reporting double
illumination troubles with a height field. Internally the only
difference between a hf and a bicubic patch is the bounding scheme of
the hf, but afaik it's not related to illumination at all.
Date: 2 May 2000 19:23:40
Message: <390f637c@news.povray.org>
to which Peter Popov <pet### [at] usanet> replied:
A very quick test (solid colour height map, height field translated to fill
camera view, zero ambient, light source behind height field) reveals that
smooth height fields are indeed doubly illuminated.  I guess in the most
common usages of height fields this isn't ever an issue, as the camera only
sees the "top" surface of the field, lit as expected.
Date: 2 May 2000 22:56:03
Message: <390F95AF.C21F8967@aol.com>
All povray objects have to potential to double_illuminate. Just try to give a
clipped sphere a surface normal and you will find out.
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 3 May 2000 05:42:31
Message: <390ff487@news.povray.org>
Chris Colefax <chr### [at] tagpovrayorg> wrote:
: But aren't the smooth height field and the bicubic patch essentially the
: same?
  AFAIK the heightfield routine uses a specialized algorithm while the
bpatch routine uses a more general triangle mesh algorithm. This makes
a HF faster to raytrace.
  I don't know if it affects the double-illumination thing.
