I didn't get any response in the images group..
The hf with smooth set seems to be transmitting light. I'm using a pattern{} to
keep the scene all text. The same can be reproduced with a regular hf in the
official version. Is this a known bug?
sig.
#version unofficial MegaPov 0.4;
#declare Lys= light_source { 0, .85
looks_like { sphere { 0, .1 pigment { rgb 1 } finish { ambient 1 } } }
object { Lys translate <1,-3,1> }
object { Lys translate <-1,-3,1> }
#default {finish {ambient 0 specular .1 roughness .05 specular 1.1 diffuse .6}}
background { rgb .1 }
disc {0,y,10 pigment {rgb 1} translate -3.1*y}
camera { location <0, 1 ,-5> look_at 0 }
#declare Pig= pigment { color rgb <.4,.2,0>}
height_field {
pattern 100,100 {
hf_gray_16
cylindrical color_map { [0 rgb 0] [1 rgb 1] }
translate 1
scale .3
//smooth
pigment {Pig}
clipped_by {plane {-y,-.05}}
scale <5,2,5>
height_field {
pattern 100,100 {
hf_gray_16
translate 1
scale .3
smooth
pigment {Pig}
scale <5,2,5>
translate -x*3
sphere {0,.15
pigment {rgb x}
translate <-1,-.2,.3>
sphere {0,.15
pigment {rgb x}
translate <1,-.2,.3>
On Fri, 28 Apr 2000 23:00:46 +0200, Sigmund Kyrre Aas
If it were a bicubic_patch I'd call it double_illuminate trouble, but
I don't think hf's have this problem. I'm at a loss too.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
Well, it seems to have that. While setting up a bug-report scene I ran
into another bug. It chrashes in 3.1e but not in MegaPov 0.4. Both return
"Illegal grid value in dda_traversal()" during trace. Changing the
rotation of the height fields to something else than 90*x or changing the
camera position fixes this.
My most recent official version is unable to run (Linux is down). Could
someone with the latest official version confirm this bug?
Note that the appearance of hf.gif is not relevant. Just use whatever you
have at hand.
#version 3.1;
// lights above plane:
light_source { <1,1,10>, .85 }
light_source { <-1,1,10>, .85 }
// the first camera statement causes the error
// "Illegal grid value in dda_traversal()" and eventually crashes.
#declare ChrashCam =1;
#if (ChrashCam)
camera { location <0,0,-3> look_at 0 }
plane {y,0 pigment {rgb 0}}
#else
plane { y,0.01 pigment {rgb 0}}
camera { location <0.01,0.01,-3> look_at 0 }
//lights below plane:
light_source { <1,-1,-10>, .85 }
light_source { <-1,-1,-10>, .85 }
#declare Rot=90*x; // <-- changing this to 90.1*x makes it run with ChrashCam=1
// lit from behind:
height_field { // top left
gif "hf.gif"
smooth // <-- commenting out this makes it appear black as it should
translate -.5
rotate Rot
pigment {Pig}
translate <-.6,.6,0>
height_field { // top right
gif "hf.gif"
//smooth
translate -.5
rotate Rot
pigment {Pig}
translate <.6,.6,0>
// lit from front:
height_field { // bottom left
gif "hf.gif"
smooth
translate -.5
rotate Rot
pigment {Pig}
translate <-.6,-.6,0>
height_field { // bottom right
gif "hf.gif"
//smooth
translate -.5
rotate Rot
pigment {Pig}
translate <.6,-.6,0>
> have at hand.
Without us having hf.gif to work with it would be impossible for us
to recreate your problem. The dda_traversal problem is one that is
well documented and there is no real fix for it. It is covered in
the VFAQ at Warps site -
http://www.students.tut.fi/~warp/povVFAQ/miscVFAQ.html#ddatraversal
hf.gif posted to p.b.i
pattern{} to
the
Peter Popov <pet### [at] usa net> replied:
But aren't the smooth height field and the bicubic patch essentially the
same? i.e. they are both internally subdivided into meshes of smooth
triangles. This means that, in official POV at least, they both use double
illumination, which is why you get the translucent effect.
On Mon, 1 May 2000 10:26:52 +1000, "Chris Colefax"
I know, it's just that I don't recall anyone reporting double
illumination troubles with a height field. Internally the only
difference between a hf and a bicubic patch is the bounding scheme of
the hf, but afaik it's not related to illumination at all.
to which Peter Popov <pet### [at] usa net> replied:
A very quick test (solid colour height map, height field translated to fill
camera view, zero ambient, light source behind height field) reveals that
smooth height fields are indeed doubly illuminated. I guess in the most
common usages of height fields this isn't ever an issue, as the camera only
sees the "top" surface of the field, lit as expected.
All povray objects have to potential to double_illuminate. Just try to give a
clipped sphere a surface normal and you will find out.
Samuel Benge
E-Mail: STB### [at] aol com
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Chris Colefax <chr### [at] tag povray org> wrote:
: But aren't the smooth height field and the bicubic patch essentially the
: same?
AFAIK the heightfield routine uses a specialized algorithm while the
bpatch routine uses a more general triangle mesh algorithm. This makes
a HF faster to raytrace.
I don't know if it affects the double-illumination thing.
