POV-Ray : Newsgroups : povray.advanced-users : CSG error. Help? Server Time
16 Mar 2026 13:54:25 EDT (-0400)
  CSG error. Help? (Message 1 to 6 of 6)
Subject: CSG error. Help?
Date: 25 Apr 2000 09:24:51
Message: <39059ca3@news.povray.org>
(Was originaly posted in p.prog)
I was having another try at smoothly joining 2 different sized pipes or tubes
at rightangles when I hit this problem - one tube developed large holes in it.
Open or closed cylinders made no difference but they do change with camera
angle or RadW. I used DOS versions of mpov 0.4 and pov 3.1g.
Any ideas where the problem is please?
As my project was intended to be hollow glass I think I'm in trouble anyway
with this idea. Or am I trying to re-invent the wheel?
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
// Begin pov file.
// Attempts smooth transition between 2 different size
// cylinders joined at right angles.
// Is OK to use either MegaPov 0.4 or Pov 3.1g - try 120*90
camera{ location <9,6,-12> angle 6 look_at <0.9,0,0> }
light_source {<80, 80, -100> color White }
#default{ finish{ phong 1 phong_size 40 ambient 0.5 } }
#declare RadL=1;    // Large radius (L pipe).
#declare RadS=0.5;  // Smaller radius (S pipe).
#declare Pipes =
union{
  cylinder{ -y,y,RadL open pigment{ Cyan } }
  cylinder{ 0,x*1.4, RadS open pigment{ Yellow } }
// Sphere radius used to form weld line,
// reduce to 0.05 to reduce problem.
#declare RadW=0.12;
// Minimun X-offset from L cylinder axis (max is RadL).
#declare XoffMin = sqrt( RadL*RadL - RadS*RadS );
// Weld X-point on L pipe moves sinusoidaly (cos used)
// between RadL and XoffMin.
#declare Xscale = (RadL - XoffMin)/2;  // Will be +/- wrt 0.
// Rotates Weld point around S pipe surface,
// then adds X offset which will be 2 cos waves over 360 deg.
// object{ Pipes } // Here instead of later is different.
#declare AnglW=0;
difference{
  union{
    object{ Pipes }
    #while (AnglW<360)
      sphere{ 0, RadW
        translate <0,RadS,0>
        rotate -x*AnglW
        translate < cos(radians(AnglW*2))*Xscale + XoffMin+Xscale, 0,0 >
    #declare AnglW = AnglW+1; // This increment also alters output error.
// Simple object to replace the one that will be used here.
sphere{ 0,0.1 }
pigment{ Magenta }
Subject: Re: CSG error. Help?
Date: 28 Apr 2000 19:53:56
Message: <390A24CC.262FE585@hotmail.com>
I have no idea of what causes this error, but I
have included a file below that produces similar
errors in my POV-Ray v3.1g for Windows 98.
The spheres are "shining" through the cylinder
when there are many of them in a "sweep" behind it.
Tor Olav
mailto:tor### [at] hotmailcom
#version 3.1;
light_source {
  100*<2, 3, -2>
  color 2*<1, 1, 1>
  location <3, 2, -3>/2
//  location <3, 0, 0> // To see posistion of spheres
  look_at <0.5, 0, 0>
#declare NrOfSpheres = 200; // Also try 100 and 250
#declare Cnt = 0;
difference {
  union {
    cylinder {
      <0, 0, 0>, <1, 0, 0>, 0.5
      pigment { color <0, 1, 0> }
    #while (Cnt < NrOfSpheres)
      sphere {
        (0.5 - Cnt/NrOfSpheres)*y + z, 0.1
        pigment { color <1, 0, 0> }
      #declare Cnt = Cnt + 1;
  sphere {
    <1, 0, 0>, 0.2
    pigment { color <0, 0, 1> }
Date: 28 Apr 2000 20:08:23
Message: <390A282C.362D2FDF@hotmail.com>
I just discovered that the problem seems to
disappear (in both mine and your scene) if one uses
merge {
instead of
union {
in the difference statement, then the problem
disappears.
And I if you are planning on making this into a
object of glass, then merge is what you'll need
to use anyway.
Tor Olav
Date: 29 Apr 2000 16:18:16
Message: <390b4388@news.povray.org>
Tor Olav Kristensen <tor### [at] hotmailcom> wrote in
message
news:390A282C.362D2FDF@hotmail.com...
I think this is probably a better and simpler demo scene than mine.
> merge {
> instead of
> union {
> disappears.
Just tried your suggestion and it did seem to work until I tried my
original scene and found it may move the problem somewhere else :(
I have a union of spheres similar to the one inside the loop in my
post but slightly different calculations with an, as yet, uncorrected
maths error. This is used in the difference to finish the seam and the
maths error leaves unwanted pieces in the CSG. These pieces do not
show if merge is used and the _join_  seems different but I can't see
why yet :-/
Your solution would seem to be OK for non-glass objects :)
Further info - Povray 3.0 for DOS doesn't work either.
Alf
Date: 29 Apr 2000 18:43:02
Message: <390B6C8C.C4910D20@merlin.net.au>
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Note that in the statistics reported after the trace, there is a report
of I-stack overflows.
Increase max_intersections in the global_settings section.
Cheers, PoD.
Date: 30 Apr 2000 15:02:30
Message: <390c8346@news.povray.org>
PoD <pod### [at] merlinnetau> wrote in message
news:390B6C8C.C4910D20@merlin.net.au...
report
Many thanks for that - problem cured witth max_i 200.
I think I need new glasses coz I hadn't noticed that in the stats.
Must pay more attention in future.
Alf
