POV-Ray : Newsgroups : povray.advanced-users : difficult questions (for me anyway) Server Time
15 Oct 2025 00:55:20 EDT (-0400)
  difficult questions (for me anyway) (Message 1 to 10 of 22)
Subject: difficult questions (for me anyway)
Date: 8 Mar 2000 11:48:51
Message: <38c68473@news.povray.org>
I've two questions:
I have a cylinder from 0 to x*1, rotate it randomly around the y axis. Can I
find the xyz values of the end point that was x*1?
If so: I make a second cylinder from this point to x*2 and rotate it
randomly - does it rotate around zero or around the end point of cylinder
one? If it rotates around zero how can I make it rotate around the end of
cylinder one? do I have to translate it to zero, then rotate it, then
translate it to the end of cylinder one?
loop back to question one!
Hope that makes sense
Mick
       http://www.minda.swinternet.co.uk/index.htm
Subject: Re: difficult questions (for me anyway)
Date: 8 Mar 2000 12:11:02
Message: <38c689a6$1@news.povray.org>
Mick Hazelgrove skrev i meddelandet <38c68473@news.povray.org>...
I
I don't think that's possible, if you don't calculate the random value and
save it in a variable before you rotate the cylinder, like this:
#declare R = rand();
rotate <0, R, 0>
Then you can calculate the new endpoint using sin() and cos().
>one?
Yes, everything rotates around <0, 0, 0> in POV.
Yeah.
--ll
Date: 8 Mar 2000 12:19:55
Message: <38c68bbb@news.povray.org>
Lars Luthman <no### [at] spamse> wrote:
: #declare R = rand();
: rotate <0, R, 0>
: Then you can calculate the new endpoint using sin() and cos().
  Or more easier with vrotate().
Date: 8 Mar 2000 13:13:23
Message: <38c69843@news.povray.org>
Please explain, for me and for other maths disadvantaged pov users!
Date: 8 Mar 2000 13:38:06
Message: <38C69E24.E80E6439@gci.net>
From the docs:
vrotate(A,B)
Rotate A about origin by B.
Given the x,y,z coordinates of a point in space designated
by the vector A, rotate that point about the origin by an
amount specified by the vector B. Rotate it about the x-axis
by an angle specified in degrees by the float value B.x.
Similarly B.y and B.z specify the amount to rotate in degrees
about the y-axis and z-axis. The result is a vector containing
the new x,y,z coordinates of the point.
A contains a point reference
B contains a rotation reference.
The function vrotate(A,B) returns the new point reference
if you rotate point A by rotation B.
i.e. point{<0,0,0> translate A rotate B}
I know that there is no object called point{ <location>
[OBJECT_MODIFIERS...] }
but it does help to use it in this way with translate and rotate .
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 8 Mar 2000 14:07:53
Message: <38c6a509@news.povray.org>
Thanks everybody, problem solved.
Mick
"mr.art" <mr.### [at] gcinet> wrote in message news:38C69E24.E80E6439@gci.net...
> From the docs:
> vrotate(A,B)
> Mr. Art
> Bill DeWitt 2000
Date: 8 Mar 2000 15:20:01
Message: <pwldTMAYWrx4EwnE@econym.demon.co.uk>
You can get it to behave either way. You just have to configure things
right. If you want cylinder 2 to rotate about the end of cylinder 1,
then define them something like this:-
#declare Forearm = cylinder {0,x,...
  rotate <...>  // elbow
#declare WholeArm = union {
  cylinder {0,x,...}
  object {Forearm translate x}
  rotate <...>  // shoulder
The rotate instruction attached to Forearm rotates it about the elbow,
and the rotate instruction attached to WholeArm rotates the whole arm
about the shoulder keeping the elbow joint connected.
In general, the trick is to create the objects with the rotation point
at zero, apply the rotation, then perform the translation to where you
really want them later. In this way you can keep adding more sections to
the hierarchy and they'll all hang together and rotate correctly about
the joints you create.
Mike Williams * ##
Gentleman of Leisure
Date: 8 Mar 2000 23:38:18
Message: <38C729F2.FF588583@faricy.net>
> I've two questions:
cylinder { <0,0,0>,<1,0,0>,n rotate bla*y } //correct?
then the end point will be <sin(bla),0,cos(bla)>
Unfortunately, yes. Maybe I should add arbitrary origin to those macros... :-)
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 9 Mar 2000 03:17:10
Message: <38c75e06@news.povray.org>
Mick Hazelgrove <mha### [at] mindaswinternetcouk> wrote:
: Please explain, for me and for other maths disadvantaged pov users!
  As mr. art said, there's this thing called "documentation". Ever heard
about it?
Date: 9 Mar 2000 03:27:47
Message: <38C7611A.C08BD85@pacbell.net>
> about it?
I have but without the proper educational background there are times it
makes absolutely no sense what so ever. An example is sometimes worth
1000 documented words. If a person had understood the original explaination
they would not have asked for clarification. What is easy for you may be
difficult for others. Not every thing in POV-Ray is inherently obvious
or intuitive. We are here to help not criticize. Dare to teach so that
others may learn. Patients is a virtue. Lead by example. Give till it
hurts.
