POV-Ray : Newsgroups : povray.advanced-users : How do I limit the scope of turbulence in a texture_map ? Server Time
16 Jun 2026 13:09:33 EDT (-0400)
  How do I limit the scope of turbulence in a texture_map ? (Message 1 to 4 of 4)
Subject: How do I limit the scope of turbulence in a texture_map ?
Date: 11 Feb 2000 08:49:48
Message: <38a4137c@news.povray.org>
I'm trying to create a texture that will cover some parts of an object
with one texture, and the rest of the object with another texture. To do
this, I've written a texture using texture_map:
    #declare Mixed_t =
            gradient <1,1>
            texture_map {
                [ 0   Texture1_t ]
                [ 0.5 Texture1_t ]
                [ 0.5 Texture2_t ]
                [ 1.0 Texture2_t ]
This works fine,  half the object gets Texture1_t, and the othe half
Texture2_t.
The problem is that I'd like to use turbulence to stir up the boundry
between the 2 textures, without stiring up the 2 textures themselves
(which already have the right ammount of turbulence).
If I add turbulence...
    #declare Mixed_t =
            gradient <1,1>
            turbulence 0.2
            texture_map {
                [ 0   Texture1_t ]
                [ 0.5 Texture1_t ]
                [ 0.5 Texture2_t ]
                [ 1.0 Texture2_t ]
... then it stirs up both textures as well as the boundry between them.
Does anyone out there know how I could do this ?
Thanks,
Alun.
(alu### [at] convergyscom)
Subject: Re: How do I limit the scope of turbulence in a texture_map ?
Date: 11 Feb 2000 09:15:37
Message: <38A41988.8A9CD9D3@umh.ac.be>
The only way to do this is to use MegaPov. So you can use the
warp{reset_children} after warp{turbulence 0.2} and just the gradient
(in your example) will have turbulence but not the subtextures.
Look the MegaPov doc for more details.
Fabian.
> Hi,
>     #declare Mixed_t =
>         texture {
>             gradient <1,1>
>             texture_map {
>                 [ 0   Texture1_t ]
>                 [ 0.5 Texture1_t ]
>                 [ 0.5 Texture2_t ]
>                 [ 1.0 Texture2_t ]
> Texture2_t.
>     #declare Mixed_t =
>         texture {
>             gradient <1,1>
>             turbulence 0.2
>             texture_map {
>                 [ 0   Texture1_t ]
>                 [ 0.5 Texture1_t ]
>                 [ 0.5 Texture2_t ]
>                 [ 1.0 Texture2_t ]
> Thanks,
> Alun.
Date: 11 Feb 2000 10:10:30
Message: <38a42666@news.povray.org>
Fabian BRAU wrote in message <38A41988.8A9CD9D3@umh.ac.be>...
>Fabian.
Thanks Fabian,
That looks like exactly what I'm after, I'll give MegaPov a try.
Alun.
Date: 11 Feb 2000 11:48:54
Message: <38a43d76@news.povray.org>
>The only way to do this is to use MegaPov.  [...]
I've given it a quick try and it works like a dream.
Thanks Fabian,
and thanks to everyone involved in MegaPov
Al.
