POV-Ray : Newsgroups : povray.advanced-users : finish_map? Server Time
14 Oct 2025 19:06:41 EDT (-0400)
  finish_map? (Message 1 to 6 of 6)
Subject: finish_map?
Date: 30 Mar 2000 23:40:39
Message: <38E58E07.46364CA6@gate.net>
I would like to able to assign different finishes to different areas of
a texture using a map image; call it a 'finish_map'. Having often seen
3d artists use specular or shininess maps with other programs,
I expected I would be able to in pov as well, perhaps by clever use of
material_map to map entire textures onto the object, with different
finishes for each. This doesn't produce the desired result: material_map
is designed to use indexed color images, with one texture assigned to
each color in the index. What I really want is to be able to use a black
and white image, with lighter pixels indicating that more shininess
should be applied there. What can I do?
Subject: Re: finish_map?
Date: 31 Mar 2000 00:24:10
Message: <38e4367a@news.povray.org>
Get MegaPov 0.4 at http://nathan.kopp.com/download.htm , if you haven't already,
and use 'image_pattern' and I think you might be able to do what you're asking
about.  From the MegaPov HTML document is an example of it's use:
  image_pattern { tga "image.tga" use_alpha }
  texture_map {
    [0 mytex ]
    [1 pigment{transmit 1} ]
"anonymous" <dum### [at] gatenet> wrote in message
news:38E58E07.46364CA6@gate.net...
Date: 31 Mar 2000 09:37:39
Message: <38E4B828.1D6B98C6@stud.ntnu.no>
Dear anonymous. This can be done with material_map since it contains textures,
and textures contain finishes. I'm not sure what your question is because you
seem to know that already..
Date: 31 Mar 2000 12:35:23
Message: <38E4E26F.7AEB7DAB@yahoo.com>
to do this the dumb way, you could make a 256 color greyscale image and
make a separate texture for each (the same, only with varying shininess)
and map each to the 256 shades.  you might be able to write a macro to
do this for you.
Date: 31 Mar 2000 16:41:28
Message: <38E67D48.9DE90CFB@gate.net>
> do this for you.
bleah! That IS dumb. By the way, I am the "anonymous" that first posted this; sorry
for the confusion. You see, I have to keep switching my netscape "identity"
settings back and forth between anonymous with an email address of ano### [at] anoncom,
to Eiki Martinson/dumpms@gate.net. This is because I fear, rightly or wrongly, that
these settings are also available to web pages. Time to get off of netscape for my
mail and news needs, I think.
Date: 1 Apr 2000 02:59:08
Message: <38E70E0E.84C7F24C@gate.net>
that
> See for yourself what the web pages see which is basically IP, browser
> and referer:
> http://kuolema.infodrom.north.de/cgi-bin/cgitest/listall
>                       TubeAmp skin for WinAmp
>     http://216.65.92.2/download.php3?file=tubeamp.zip&area=winamp2
> Kari Kivisalo                                          www.kivisalo.net
Thanks for the URL. It appears that this information is not available to web sites.
I'm
still setting up REAL mail, though. :)
