POV-Ray : Newsgroups : povray.advanced-users : prism (conic_sweep) + bounded_by Server Time
30 Sep 2024 12:13:53 EDT (-0400)
  prism (conic_sweep) + bounded_by (Message 1 to 3 of 3)
Subject: prism (conic_sweep) + bounded_by
Date: 8 Mar 2000 08:16:09
Message: <38C651F0.B6EB3B74@netvision.net.il>
I can't do bounded_by on prism somewhy, but its not a mathematical
shape,
so on what bounded_by do applys on?
conic_sweep prism is ending at a point, that is 1 * delta_height (end
height - start height)
the angle is not neccesarily 45, but it acts funny on advanced prisms
like this:
prism {
  conic_sweep
  linear_spline
  -1,        // height 1
   0,        // height 2
  10,          // number of points
  < 0.2, -1.0>, < 0.2,  0.2>, < 1.0, -0.2>, < 1.0,  0.2>, < 0.2,  1.0>,
  <-0.2,  1.0>, <-1.0,  0.2>, <-1.0, -0.2>, <-0.2,  0.2>, <-0.2, -1.0>
  pigment {color rgb 1}
  // [open]
  // [sturm]
Subject: Re: prism (conic_sweep) + bounded_by
Date: 8 Mar 2000 23:47:10
Message: <38C72C11.1FB6D070@faricy.net>
What exactly is the problem? I can't see anything wrong with bounded_by.
BTW, I do remember one thing about conic prisms; the point is always at y=0
and the width is "normal" at y=1 or y=-1, regardless of the start and end y
values. This threw me off because at values like y=4 I was getting huge
prisms and didn't know why.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 9 Mar 2000 19:54:25
Message: <chrishuff_99-05A2AB.19561209032000@news.povray.org>
In article <38C651F0.B6EB3B74@netvision.net.il>, Eitan Tal
> shape, so on what bounded_by do applys on?
I don't really understand the problem you are having, but the fact that
you are still messing around with bounded_by seems to imply that you are
still trying to misuse it as a kind of clipped_by. The bounded_by
feature is NOT a CSG operation. It does not operate at all like one. It
does not chop pieces of the object off. It is an optimization feature,
and one which you usually don't have to bother with at all because of
the automatic bounding done by the program. All shapes use bounded_by,
including solid shapes like spheres, cones, lathes, and prisms, and
non-solid shapes like polygons, meshes, and bezier patches.
If you want to chop pieces off of the object, use clipped_by(to leave
the cut surfaces open), or intersection(to close the cut surfaces). The
manual and example scenes have several samples and explanations of these.
If this is not the problem you are having, you will have to explain it
more clearly and include code demonstrating your problem. The code you
enclosed didn't even include a bounded_by statement.
Chris Huff
e-mail: chr### [at] yahoocom
