POV-Ray : Newsgroups : povray.advanced-users : Animation Server Time
15 Jan 2025 08:43:46 EST (-0500)
  Animation (Message 1 to 10 of 15)
Subject: Animation
Date: 30 Oct 1999 12:41:48
Message: <381b1fcc@news.povray.org>
Which , if any, animation programs are directly able to take POV Ray output
files as they are produced and create an AVI or MPEG clip.
The descriptions that I am seeing, so far, look as if most programs are only
assembling a series of frames.
Subject: Re: Animation
Date: 30 Oct 1999 14:51:13
Message: <381b3e21@news.povray.org>
None I know of for Mpeg.  I found this one program which mentions Mpeg
output.  Quote, "Output to PostScript, popular image files, as well as
animation and direct MPEG video generation are also available.", unquote.
It's a part of that particular program I guess.  URL telling very little of
it: http://www.mayon.ro/redhat.dir/redhat/redhat/softdir/detail.phtml32.html
DTA, aka Daves Targa Animator, could compile each frame one at a time into
it's proprietary format of Flt.  The most recent version can do the Avi
though I don't know if it can append each frame into the Avi file on the
fly.  Guessing it actually could though. URL here:
http://www.sapere.com/dearmad/
David Vincent-Jones <geo### [at] galaxynetcom> wrote in message
news:381b1fcc@news.povray.org...
output
only
Date: 31 Oct 1999 03:16:27
Message: <381bfadb@news.povray.org>
David Vincent-Jones <geo### [at] galaxynetcom> wrote:
: Which , if any, animation programs are directly able to take POV Ray output
: files as they are produced and create an AVI or MPEG clip.
: The descriptions that I am seeing, so far, look as if most programs are only
: assembling a series of frames.
  I don't understand. The povray output are frames, so any program that
assembles a series of frames will do it.
  Perhaps you could formulate your question better?
Date: 31 Oct 1999 17:25:20
Message: <381cc1d0@news.povray.org>
Let me try again;
Rather than produce 500 frames which are to be stored prior to assembly and
compression I had hoped that there would be a program that took the
individual frames as they were produced and create the AVI on the 'fly'
without burdening my system with the multiple frames.
Maybe I should have asked, what is the best software solution to producing
AVI specifically from POV Ray?
Nieminen Juha <war### [at] punarastascstutfi> wrote in message
news:381bfadb@news.povray.org...
output
only
Date: 1 Nov 1999 05:56:06
Message: <381d71c6@news.povray.org>
I dont think you can do this, not untill POVray directly supports AVI or
MPEG export
I have always used the huge stock of frames method !
news:381cc1d0@news.povray.org...
> Let me try again;
and
> output
are
> only
Warp -*/
Date: 1 Nov 1999 08:34:20
Message: <381d96dc@news.povray.org>
I say again, I think DTA32 will do it even though I haven't checked.  All
you'd need do is append each frame as a post command via the INI file and
delete the frame after that.  A batch file would be needed also, use it to
set up DTA for the input with required parameters.  I may want to give DTA32
a try again myself just to see if this works.
Rick <pov### [at] dialpipexcom> wrote in message
news:381d71c6@news.povray.org...
> MPEG export
> Rick
> > Let me try again;
> and
producing
> > output
> are
> > only
that
> Warp -*/
Date: 2 Nov 1999 03:34:45
Message: <381EA144.2CE061E0@pacbell.net>
  IF it would work, and I'm not saying it will, I can only imagine
the amount of time overhead it would add to a long animation rendering
session. While disk space is still at a premium for some people it is
not nearly so for as many as it used to be. There is also the issue of
which command line parameters to use for the best results. Personaly
when I compile my animations I like to try different features like
frame averaging and specifying different frame speeds to optimize the
final animation to my liking. If you have it done automaticaly for you
there is a risk that the final animation will not be what you want
it to be and all of your render time is wasted with no recourse for
correction.
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 2 Nov 1999 06:47:33
Message: <381ecf55@news.povray.org>
Ah, except that I think the Avi could be made with no compression and later
the frames extracted to redo in another way.  Again, I have little to no
experience with DTA32 and its Avi feature.
Ken <tyl### [at] pacbellnet> wrote in message
news:381EA144.2CE061E0@pacbell.net...
> correction.
Date: 3 Nov 1999 20:56:52
Message: <3820e7e4@news.povray.org>
Ken;
What approach do you take to 'frame averaging'
Can you achieve good intermediate frames from this?
All
and
to
DTA32
> correction.
Date: 6 Nov 1999 21:54:52
Message: <3824EACA.29F0@the-spa.com>
Of course in that case, the AVI file would likely be the same size as
all of the frames seperate anyways, unless you take into account the
overhead of an OS for storing multiple files.
If that was the case, an alternative might be to call out to add each
file into a zip file. Then when you were going to make a movie, you
could temp. uncompress them all, or you could then make a script to
unzip them one at a time and add to an animation. That way you would
still have the zip file to work with in case something goes wrong.
I personally use png files for the frames of an animation and then zip
them up into one file. Then I unzip and do any necessary conversions
when the time comes...
Shawn =)
P.S. Just as a note, I found Bumper to be an extremely handy program
when doing test renders of animations. If anyone is not familiar with
it, it will take a bunch of loose frames and play them out without
actually making a movie. I couldn't get the real frame rate with it on
my 100mhz (having to decompress png probably didn't help it any), but it
was great to preview.
sha### [at] the-spacom
http://www.the-spa.com/shawn.fumo/
