POV-Ray : Newsgroups : povray.advanced-users : a planet Server Time
16 Mar 2026 20:39:23 EDT (-0400)
  a planet (Message 1 to 10 of 14)
Subject: a planet
Date: 14 Aug 1999 22:48:27
Message: <37B62A8D.32E824E1@powersurfr.com>
i forgot how to make a sphere get diff color as it goes out from the
center? how do i do it again? (without media density)
Subject: Re: a planet
Date: 14 Aug 1999 22:50:39
Message: <37B62AF5.A20758BF@pacbell.net>
A spherical pattern ?
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 15 Aug 1999 20:28:18
Message: <37B75B34.163BC3C5@powersurfr.com>
yes ken thats it... how? won't it just look like it's a blend of all the
colors not a gradient?
> Ken Tyler
Date: 15 Aug 1999 20:30:09
Message: <37b75b91@news.povray.org>
'onion' was the common pattern for concentric spheres or circles
before v3.1 (frequency or scale needed to apply to anything other than
a 1 unit radius).
You will not actually see any gradation of a color_map used on a
sphere however unless it is CSG'd with another object, ie cut in half
with a plane.
Ken <tyl### [at] pacbellnet> wrote in message
news:37B62AF5.A20758BF@pacbell.net...
the
> Ken Tyler
Date: 16 Aug 1999 08:58:46
Message: <37B80B2F.B7AC0158@compuserve.com>
with a plane.<
Yes, and then you will only see it if the plane has the same texture.
Date: 16 Aug 1999 09:03:45
Message: <37B80C59.E7457AF4@compuserve.com>
>won't it just look like it's a blend of all the colors not a gradient?<
Objects in POV are not really solid, they are made of an infinitely thin
mathematical surface. The color of the surface depends on the color of
the pigment *at that point*(temporarily forgetting about transparency,
reflection, etc). If a spherical pattern is used on  a plain sphere, you
will see a sphere with a color the same as the last color in the
color_map. If you cut it in half with a plane, and texture the cutting
plane with the same texture as the sphere, you will see a half-sphere(a
hemisphere)  and the gradient from the center outward on the cut side.
Date: 17 Aug 1999 01:49:31
Message: <37B8F7DB.37740041@pacbell.net>
> with a plane.<
...or your sphere is transparent.
Ken Tyler
Date: 17 Aug 1999 18:07:40
Message: <37B9DDAD.B709FE46@merlin.net.au>
> > with a plane.<
> Ken Tyler
...or the texture on the sphere has turbulence.
That's the way I do planets - sphere, onion, turbulence.
Cheers, PoD.
Date: 17 Aug 1999 18:15:16
Message: <37B9DEE8.F2533A20@pacbell.net>
PoD wrote:
> > > with a plane.<
> > Ken Tyler
> Cheers, PoD.
... or the texture is translated to some point from the origin or...
Ken Tyler
Date: 19 Aug 1999 13:20:43
Message: <37bc1259.57581187@news.povray.org>
On Tue, 17 Aug 1999 15:15:04 -0700, Ken <tyl### [at] pacbellnet> wrote:
>PoD wrote:
>> > > with a plane.<
>> > Ken Tyler
>> Cheers, PoD.
the texture is applied *after* the CSG, or...
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at http://www.who3d.cwc.net/
