POV-Ray : Newsgroups : povray.advanced-users : how do i get on the up and up with color? Server Time
16 Mar 2026 22:34:37 EDT (-0400)
  how do i get on the up and up with color? (Message 1 to 10 of 11)
Subject: how do i get on the up and up with color?
Date: 10 Aug 1999 19:11:22
Message: <37B0B1A0.FBD5B159@powersurfr.com>
i'm using a while statment to make a bunch of "things" as they rise on
the y access i'd like them to incease certain colors. how would i use an
array to do this?
Subject: Re: how do i get on the up and up with color?
Date: 10 Aug 1999 19:44:13
Message: <37B0B908.75630A9D@pacbell.net>
> array to do this?
An array is one possible solution but it would probably be easier to
eimple use the value of the while loop to increment the colors.
#declare a = 0;
  #while (a < 10 )
    sphere {<0,a,0>, 1
      pigment { rgb <a*0.1, a*0.1, a*0.1> }
  #declare a = a + 1;
  The above example will change each rgb value by 0.1 for each sphere it
produces. There are tricks to using this approach and the example I gave
is a very basic one. If you really want to change the colors using an array
you will still need to write out each color you want to store in the array
before passing it into the while loop. This could be a very tedious task
but it is possible if you really want to do it. If my while loop example
is not what you want let me know and I will work out an array solution for
you.
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 10 Aug 1999 20:06:57
Message: <37B0BEA2.8CA57F86@peak.edu.ee>
I suggest you use this interpolation macro, it's very flexible:
//Interpolation
//GC - global current
//GS - global start
//GE - global end
//TS - target start
//TE - target end
//EXP - interpolation exponent (linear, cubic etc.)
#macro Interpolate(GC,GS,GE,TS,TE,EXP)
        (TS+(TE-TS)*pow((GC-GS)/(GE-GS),EXP))
Do something like this:
#declare StartColor=<1,1,0>;
#declare EndColor=<0,1,0>;
#declare N=10;
#declare C=0;
#while(C<10)
    sphere{y*C, 0.5
           pigment{rgb Interpolate(C,0,N,StartColor,EndColor,1)}
    #declare C=C+1;
Here, pigment changes from StartColor to EndColor as C changes from 0 to N. The
final parameter is 1, meaning linear interpolation.
I use this macro extensively, even though this particular example could be
achieved more efficiently.
Margus
> array to do this?
Date: 11 Aug 1999 03:04:16
Message: <37b12070@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: #declare a = 0;
:   #while (a < 10 )
:     sphere {<0,a,0>, 1
:       pigment { rgb <a*0.1, a*0.1, a*0.1> }
:   #declare a = a + 1;
: #end
  But Ken! That's quite good indentation... :)
  (Although the #while and the #end are not indented at the same level...)
Date: 11 Aug 1999 04:25:43
Message: <37B13342.E296D852@pacbell.net>
> : #declare a = 0;
> :   #while (a < 10 )
> : #end
I'm sorry 8`[
Ken Tyler
Date: 11 Aug 1999 04:48:57
Message: <37b138f9@news.povray.org>
:>   But Ken! That's quite good indentation... :)
: I'm sorry 8`[
  I praise you and you are sorry? I don't understand.
Date: 11 Aug 1999 05:00:36
Message: <37B13B6F.68D8617F@pacbell.net>
> : I'm sorry 8`[
I do have a reputation to maintain you know !
Ken Tyler
Date: 11 Aug 1999 05:14:09
Message: <37B13EEF.474A43B7@powersurfr.com>
thank you ken. it works like a charm
> > array to do this?
> #declare a = 0;
>   #while (a < 10 )
>     sphere {<0,a,0>, 1
>   #declare a = a + 1;
> #end
> you.
> Ken Tyler
Date: 11 Aug 1999 05:24:30
Message: <37B14105.C85DF276@pacbell.net>
Glad to be of service. Now if you just fix my bounding problem for me...
Ken Tyler
Date: 11 Aug 1999 13:11:48
Message: <37b1aed4@news.povray.org>
: I do have a reputation to maintain you know !
  Ah, now I understand :)
  I assure you that there's nothing you have to be ashamed of.
