POV-Ray : Newsgroups : povray.advanced-users : How to make a decent carpet texture? Server Time
21 Dec 2025 14:03:15 EST (-0500)
  How to make a decent carpet texture? (Message 1 to 10 of 11)
Subject: How to make a decent carpet texture?
Date: 19 Jun 2000 12:53:09
Message: <01bfda0f$97a068a0$601ba1d0@mk>
I've been having trouble making something carpet-y.  I want one that's good
enough to withstand having a camera a foot or two away.  I don't want to do
one with crand or bumps because it just doesn't look right.  Any idea?
Incidentally, the type of carpet is industrial strength grey with a short
nap meant to withstand heavy wear.  That's probably easier to do than shag.
Thanks in advance,
CreeD
Subject: Re: How to make a decent carpet texture?
Date: 19 Jun 2000 13:56:58
Message: <394e5eea@news.povray.org>
"CreeD" <mes### [at] nqinet> wrote in message
news:01bfda0f$97a068a0$601ba1d0@mk...
good
do
    Have you tried a height-field (could be tiled to cover large areas), or
an ISO-surface (available in the MegaPOV patch) ?
Scott Hill. (sco### [at] innocentcom)
Software Engineer.
Author of Pandora's Box (coming to a web page soon(ish)).
*Everything in this post is IMO.*
Date: 19 Jun 2000 14:36:32
Message: <8F58D0F30seed7@204.213.191.228>
Try 3dnoise in MegaPov, scale it in the y direction. Gives a rough carpet.
Ingo
Date: 19 Jun 2000 16:13:44
Message: <394E7FCF.2CB589AC@aol.com>
If I'm not mistaken, noise3d is the same as bumps.
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
Date: 19 Jun 2000 16:57:20
Message: <urpsks8c2gcnv0p3smd0abe9277n9e7gov@4ax.com>
On Mon, 19 Jun 2000 18:54:12 +0100, "Scott Hill"
>> good enough to withstand having a camera a foot or two away.  I don't
>> want to do one with crand or bumps because it just doesn't look right.
>> Any idea?
Scott is right, probably the best way to do it would be with the
built-in 'mesh' isosurface function in MegaPOV. A compex normal
statement based on scallop-wave gradients could also work but it would
be somewhat harder to get to look right.
Peter Popov ICQ : 15002700
Date: 19 Jun 2000 16:57:38
Message: <8F58E4858seed7@204.213.191.228>
Ah,
well, this is what I used some time ago.
#declare CarpetPigm= pigment {
   function {(sin(x^2)-cos(y^2))}
   scallop_wave
   colour_map {
      [0, rgb 1.5]
      [0.3, rgb <0.8,0,0.1>]
      [1, rgb <0.5,0,0.1>]
   rotate <90,0,0>
   scale <2.65,1,2.65>
union{
   disc {0,y, 10
      pigment {CarpetPigm}
      finish {ambient 0.5}
   intersection {
      isosurface {
         function {y + noise3d(x*30,y*20,z*30)*1}
         bounded_by{ box{<-11,-1,-11>,<11,0.4,11>}}
         threshold    0.48
         method 1
      cylinder {<0,0,0>,<0,0.15,0>,10}
Ingo
Date: 20 Jun 2000 04:28:48
Message: <394f2b40@news.povray.org>
CreeD wrote in message <01bfda0f$97a068a0$601ba1d0@mk>...
If you've got access to a camera and a scanner, try taking a close up photo
of
some carpet, scanning that in. Use a grayscale image for height and the
actual photo
for imagemap. I've had reasonable success with that.
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2      *
Date: 20 Jun 2000 18:05:53
Message: <chrishuff-2413B0.17101520062000@news.povray.org>
And "bozo", and "spotted" (though "bumps" is different when used in
normals).
However, I think CreeD was referring to a noise3d() isosurface.
Personal Web page: http://chrishuff.dhs.org/
Date: 24 Jun 2000 22:16:56
Message: <39555DB5.87466C98@peak.edu.ee>
I'm not sure what type of carpet you are going for, but some fabrics can be
simulated pretty well with the "quilted" pattern. From two feet away, I think a
normal pattern should suffice. For real close-ups you could use "quilted" as an
isosurface function, with real 3D geometry and thus more realistic lighting
(haven't tried this myself, so no quarantees).
Margus Ramst
Date: 7 Aug 2000 15:43:00
Message: <398f1144@news.povray.org>
Sir,
I atttach a texture file of my attempt at a carpet texture.  I attach also a
view of the carpet underneath a hi-fi cabinet in a model of my
computing/listening room.  The carpet is a 'woollen twist' pile in a colour
'mink' on a floor of slightly warped boards.  Tinker with the pigments and
the control values in the quilted texture to get the effect you desire.
Yours sincerely,
Don Barron
good
do
shag.
> Thanks in advance,
> CreeD
Download 'carpetex.inc.txt' (1 KB) Download 'CORNER.jpg' (18 KB)
Preview of image 'CORNER.jpg'
