POV-Ray : Newsgroups : moray.win : Questions/problems with scaling textures on shapes ... Server Time
13 Jun 2026 08:35:44 EDT (-0400)
  Questions/problems with scaling textures on shapes ... (Message 1 to 6 of 6)
Subject: Questions/problems with scaling textures on shapes ...
Date: 4 Dec 2004 23:20:50
Message: <41b28ca2@news.povray.org>
Folks,
consider the following.
A is a 4x4x4 scaled cube
B is two 1x1x1 cubes in a CSG Union then the CSG scaled by 4x4x4
C is two 4x4x4 cubes in a CSG Union
D is an 8x4x4 scaled cube
The same texture has been applied to all the high level shapes (A -
cube, B - CSG, C -CSG, D - cube)
What I am trying to achieve is 'D' but for the CSG created objects (they
won't always be simple cubes).  I can see that I can create D for CSG
created entities by creating multiple materials and scaling them for
each shape but what I want is one material and not have to have multiple
copies.
In summary, I guess I am needing some pointers to the relationship
between scaling and materials, especially when applied to CSGs.
Any help appreciated.
Neil
Download 'iso-8859-1' (2 KB)
Subject: Re: Questions/problems with scaling textures on shapes ...
Date: 5 Dec 2004 09:43:04
Message: <na76r093vhq7gml1u9rs3h46fi3ol7dfmq@4ax.com>
On Sat, 4 Dec 2004 22:20:35 -0600, "Neil Kolban" <kol### [at] kolbancom>
>Neil
I don't think you can do what you want to do, if I understand you
correctly. (It was a bit hard to read your question as it was all on
two lines) BTW I am not renowened for my textures :-(
Once you have the correct scaling of your material and apply it to
your object the material will be scaled along with your object or
group.
Here is something that might give you more of an insight.
Copy group C and place it below it. Change the "Space" to "world" then
move the new group on the X axis. Note how the texture does not move
with the object.
I think you will need different textures for the different scaled
groups.
Regards
Date: 5 Dec 2004 09:45:04
Message: <41b31ef0@news.povray.org>
created entities by creating multiple materials and scaling them for each
shape but what I want is one material and not have to have multiple copies.
I think what you are looking for is to scale the texture differently for
each object you use it on. You can achieve this by:
   Make sure the 'Configuration\Moray\Show Material proxies' is selected
   Hold down the 'shift' key and left click on the proxy wireframe
   Scale as needed
If the proxy is completely contained within the object, it may be hard to
select. You can temporarily scale the texture in the Material Editor, select
and move the proxy wireframe for the object in question and then remove the
scaling.
See ScaleTextureOnShape.zip file in moray.binaries
I think you want how I did CSG005
Date: 5 Dec 2004 11:52:10
Message: <o5f6r0h7ucjcmkcq8fqr7iai5qft4645a3@4ax.com>
Nice one Stephen. I knew that if I said that it could not be done then
someone would prove me wrong :-)
Regards
Date: 5 Dec 2004 12:42:26
Message: <41b34882$1@news.povray.org>
news:41b31ef0@news.povray.org...
copies.
>    Scale as needed
select
the
> scaling.
You can also select and transform the material of a selected object by
hitting alt+t
Marc
Date: 5 Dec 2004 14:33:07
Message: <41b36273$1@news.povray.org>
Thanks to all of you.  The responses you provide to my questions are
fantastic and give me all the information I need to make progress.  I hope
that, one day, I can add value to newbies like myself.
I appreciate you all.
Neil
