POV-Ray : Newsgroups : povray.pov4.discussion.general : On triangle and smooth_triangle shapes. Server Time
11 May 2025 06:40:39 EDT (-0400)
  On triangle and smooth_triangle shapes. (Message 1 to 9 of 9)
Subject: On triangle and smooth_triangle shapes.
Date: 12 Nov 2023 21:43:57
Message: <65518d6d$1@news.povray.org>
In the binary images forum there has recently been discussion related to
triangles and meshes as sprite surfaces representing plants.
https://news.povray.org/povray.binaries.images/thread/%3Cweb.654efeced2ab8e2ef22cdb33dabc9342%40news.povray.org%3E/
I've had on my yuqk to do list a partly finished triangle /
smooth_triangle sample scene / test case. Scene file and image attached.
The scene file in this case runs back to v3.7 so long as the version
gets set on the command line with +mv3.7 or +mv3.8.
In the image there are six columns. Left two are v3.7. Middle two
v3.8b2. Right two yuqk.
The top two rows are just triangle{}s and the ccw or cw order relative
to the incoming ray (the camera ray here) in which the corners are
specified sets the surface normal direction. The ccw order points back
toward the 'z' ortho camera.
For the triangles there is always both an texture and an
interior_texture specified with an emission 1.0 finish.
The middle two rows are smooth-triangle{}s. In the left column of each
column pair the specified normals all point back at the camera. In the
right column of each column pair the specified normals all point away
from the camera. If normals are specified, it looks like the corner
order specification does not matter.
The bottom two rows are an open question for me. These rows are
duplicates of the middle two rows except I invert one (or it can be two)
of the normals. This does cause a degenerate triangle warning, but I
suddenly get a black result - why the latter? My naive thought is if bad
normals are the reason for the degenerate condition, the normals should
all be ignored and the ccw or cw order used instead. I think we should
get the interior or exterior texture no matter how mangled the normals.
Bill P.
Aside (1) not directly triangle related, but shown in the scene file:
The sample scene has some stuff in it related to open questions about
finish{} texture updates - applying to pigment{}, normal{} updates too.
One of the cool things about the original Scene Description Language
(SDL) approach was that more often we could update aspects of already
defined things.
With an object's texture, if in some later placement / use, we want to
tweak the finish we just write:
object { Widget12 finish { ... } translate ToMoon }
However, when the interior_texture{} capability was introduced, this
sort of blind update capability of an aspect of the object's original
interior_texture was not implemented.
The only way to make a 'partial' interior_texture{} update to a
particular instance of something with an interior_texture{} is to
re-specify the entire interior_texture. This method is, of course, ugly.
Especially true if the object's texture is not accessible as a defined
ID. There we basically have to unravel the inline interior_texture{} to
be to replicate the whole of it, so we can update just the finish{}
aspect.
Download 'triangles.pov.txt' (2 KB) Download 'tristory.png' (2 KB)
Preview of image 'tristory.png'
Subject: Re: On triangle and smooth_triangle shapes.
Date: 12 Nov 2023 22:00:00
Message: <web.655191013d333187f22cdb33dabc9342@news.povray.org>
> Bill P.
> defined things.
> aspect.
Thanks' so much for all the info. I'll study the scene file for a closer look.
Mike
Date: 12 Nov 2023 22:10:00
Message: <web.6551936d3d3331871f9dae3025979125@news.povray.org>
It looks like you might be running into what I discovered here: ?
http://news.povray.org/povray.advanced-users/thread/%3Cweb.5f763c8daf8e23f91f9dae300%40news.povray.org%3E/
I'm guessing that you'll likely have to implement some debugging capability to
output or make visible the normal vectors.
If the normal vector is <0, 0, 0> does that result in a degenerate triangle?
If the normal is zero, very small, or perpendicular to the triangle surface,
wouldn't that result in a black/non-visible triangle?
You might try rendering arrows for the vertex and face normals, and show
warnings/symbols for <0, 0, 0> or <(<threshhold), (<threshhold), (<threshhold)>
normal vectors, and see what that gives you.
Rendering problematic triangles individually, and mapping the surface normals by
interpolating the vertex normals across the face might reveal something wonky
that's hard to do in any other way.
See the excellent link that TOK posted:
https://codeplea.com/triangular-interpolation
- BW
Date: 12 Nov 2023 22:36:22
Message: <655199b6$1@news.povray.org>
As always. Thanks for the references! Yes, related.
Yes, your debugging capability for normals. It's been on my todo list
for a while. I plan to implement it as a special pattern so I can return
the perturbed normals in addition to the raw normals.
I've already modified the yuqk aoi pattern to work with the full range
-1 to +1 possible perturbed normals. I should try that now actually on
the black ones... Ah, it didn't offer clue why things go black in the
degenerate case - things are still black.
I'll need to do some debugging I guess.
Bill P.
Date: 13 Nov 2023 07:15:00
Message: <web.655212913d3331871f9dae3025979125@news.povray.org>
You're welcome.   And thanks for confirming.
While you're in there digging around in the normal code,  perhaps you can make
some notes about exactly HOW that all works.  Normals seem to me like they'd
need a 2D modification (theta, r) rather than just a single scalar value.
That whole weird tetrahedron thing....
https://news.povray.org/5c45e632%241%40news.povray.org
I also had a link to an external site/article, but can't find it atm.
A useful pattern would be something that would allow a function to return the
normal as a vector (and doesn't require the prior existence of an object surface
to work).
Also reminds me of the problem I still have to solve/work-around here:
https://news.povray.org/povray.unofficial.patches/thread/%3C60a268da%241%40news.povray.org%3E/
Speaking of functions, I just threw up my hands and gave up on converting a
"simple" shader, because trying to convert that into SDL with functions blows up
into over 1000 lines of bloated code.  As you know, there's a long list of
things that make the function parser unusable in such circumstances, so I won't
get into it .... here.   ;)
- BW
Date: 13 Nov 2023 08:45:24
Message: <65522874$1@news.povray.org>
Alright. What is happening is the code marks degenerate triangles with
an internal flag setting that they are degenerate.
This flag setting gets tested during most operations including the
ray->triangle intersection code, where it immediately returns with no
intersections. (The bounding box intersections still happen, if those
are active with the active bounding)
Doing this where the specified normals are the only reason it is being
considered degenerate would be wrong for mesh inside testing - and I
think too conservative generally. Those mesh inside tests care not a
whit about normals, but dropping intersections will certainly create
problems.
The complication is the mesh / mesh2 parsing is different and I'm not
yet sure if things all work the same way there. I'll have to dig some more.
With respect to the smooth_triangle, what I've done in the yuqk fork is
modify the code so that, where the specified normals are the reason a
triangle is considered degenerate, we still get the warning messages
from the parser, but the triangle degenerate flag is no longer set.
Updated image of the new behavior is attached.
Bill P.
Date: 13 Nov 2023 09:54:08
Message: <65523890$1@news.povray.org>
It appears the mesh / mesh2 code was already working as yuqk's
smooth_triangle was just updated to work - except there are no
degenerate warnings for the normal cases considered degenerate by
smooth_triangle.
Think I'll leave it as is for now. If there are many triangles people
are going to use mesh / mesh2 anyhow.
Bill P.
Date: 14 Nov 2023 06:45:14
Message: <65535dca$1@news.povray.org>
Digging again into that code is something on my list, but it's not at
the top at the moment.
I need to better understand the gradient calculation method(a) - or
replace it - to understand, for example, what is happening with that
experimental facets pattern when I set the accuracy setting really large
compared to the value region dimensions. I don't get at all why results
become smoother. I have some wild guesses(b), but they are wild. I have
longer standing questions / issues with it too with the sampling pattern.
(a) There is a similar method used to calculate isosurface normals.
(b) My up front one is that the accuracy value is getting used,
intentionally or not, to inverse scale the effect of the perturbation -
before it can be scaled with the bump_size value. In other words, there
'might be' a missing normalization of the resultant gradient value.
I don't remember reading that particular post - thanks.
I had the thought while reading it, we often are too brief when
discussing how scalar values can get to the normal{} mechanism. I have
the follow parser test case which might help as sort of a guide:
// Patterns, pigments with normals
#declare Pig = pigment { bumps }
#declare Nrm = normal { bumps }
#declare Fn0 = function { pattern { bumps } }
#declare Nr0 = normal { function { Fn0(x,y,z) } }
#declare Fn1 = function { pigment { bumps } }
#declare Nr1 = normal { function { Fn1(x,y,z).red } }
#declare Nr1 = normal { function { Fn1(x,y,z).grey } }
#declare Nr2 = normal { pigment_pattern { bumps } }
#declare Nr3 = normal { pigment_pattern { Pig } }
// The following fail today with parsing errors though perhaps
// they should not?
//  #declare Nr4 = normal {
//      pigment_pattern { pigment { bumps } }
//  #declare Nn5 = normal {
//      pigment_pattern { pigment { Pig } }
//  #declare Nn6 = normal { pattern { bumps } }
#error "Parse test. Stopping early"
As a guide for POV-Ray proper would need an example overriding the
default pattern color_maps. The yuqk for doesn't have default color_maps
except for the block patterns).
If it's the one you gave me, I have it somewhere in your folder.
> to work).
The special pattern(s) I have in mind to implement will certainly be
returning vectors. Specifically three 21 bit floats in the double scalar
value return space - something which will work with today's pattern
mechanism.
I should get back to some of these ideas once in a while :-).
Bill P.
Date: 14 Nov 2023 13:35:00
Message: <web.6553bd793d3331871f9dae3025979125@news.povray.org>
No ...  if you're talking about the
* FUNCTION
*   IsoSurface_Normal
in isosurface.cpp, in source/core/shapes,
that looks like just regular old forward-difference to calculate a function
gradient.
Certainly.  I stumbled across it while trying to find one of my other posts.
- BW
