![](/i/fill.gif) |
Ingar Halvorsen Wasbotten <ing### [at] chem uit no> wrote:
> I am tired of changing the black background manually. How do I set this
> in POV-ray?
background { rgb <1,1,1> }
![](/i/fill.gif) |
![](/i/fill.gif) |
> in POV-ray?
simply with a line like
background { rgb <0.5,0.5,0.5> }
in your pov-scenes files. (this line give a 50% grey)
> I am working with orbital-pictures generated from ADF using
> molden and ADFrom.
I do not know if it make you unable to edit the pov-scene files...
P.S: you seems to have a clock delta of one month back.
PS2: searching the povray-help for background should
have give you the information!
![](/i/fill.gif) |
