POV-Ray : Newsgroups : povray.windows : Conversion Server Time
6 Oct 2024 04:08:47 EDT (-0400)
  Conversion (Message 1 to 4 of 4)
Subject: Conversion
Date: 13 Apr 2000 09:15:15
Message: <38F5C85D.418905ED@fel.tno.nl>
My name is Rob Kemp. Having enjoyed working with pov-ray 3.1g (win32
version) I wonder if it is possible to convert the .pov files to other
formats, like for example .3ds files.
Thomas Baier has created a programme to convert to .pob format and he
also has a programme to convert the .pob files to .3ds and lots of other
formats.
Thanks,
Rob
Name:  Rob Kemp, M. Sc.         	Internet:kem### [at] feltnonl
Mail:  TNO - FEL                Addr: TNO Physics & Electronics
       P.O. Box 96864                 Laboratory
       NL-2509 JG The Hague           Oude Waalsdorperweg 63
Phone: ++31.70.374.0458               NL-2597 AK 's-Gravenhage
       ++31.70.374.0000         Fax: ++31.70.374.0654
Subject: Re: Conversion
Date: 13 Apr 2000 09:26:57
Message: <38F5CAD4.AFAC5DA8@pacbell.net>
RAW Kemp wrote:
> Hi,
  Currently there are no conversion utilities that can do this. It is
not impossible but it is something that is very difficult to do. POV-Ray
treats its primitives as mathematical constructs as opposed to the .3ds
format which treats objects as triangle constructs. If someday POV-Ray
adds the ability to internaly tesselate it's mathematical primitives
into triangle meshes it will make it possible to export to other 3D
file formats that rely on triangle based object creation.
  The hardest part of writing a stand alone conversion utility is
that you will need a scene file parser that is as powerful as the
parser that already exists as POV-Ray. It would take someone with
a considerable amount of time and programming experience to write
a stand alone application like this and so far no one has accepted
the challenge. The licensing agreement that POV-Ray uses forbids
ripping out the parser part of the program and using in other
applications such as this.
Date: 13 Apr 2000 21:58:05
Message: <38F67B4F.5A614F7C@hotmail.com>
-Isn't it possible however to create a custom version of POV-Ray that will
do the conversion as part of the rendering process??
Date: 13 Apr 2000 22:08:48
Message: <38F67D41.D940B412@pacbell.net>
Sure it's possible. All someone needs to do is write a patch that will
internally tessellate POV-Ray's primitives. Should be easy for someone
with the right mathematical and programming skills. <g>
