![](/i/fill.gif) |
On Thu, 20 May 1999 11:35:50 +1000, Steven Jones <ste### [at] tsn cc>
wrote:
>How do I go about continuing a render I have previously halted?
From the editor window press ALT+C to bring up the Render Settings
dialog box (there's toolbar icon that does the same thing). Enter '+c'
(without the apostrophe marks) in the Command Line box to resume
trace. An alternative is to create your own .ini with these command
line options already in it. The +c option and most others can be
overridden from the Render Settings dialog box.
Alan
news.povray.org - where POV-Ray enthusiasts from around the world
- get together to exchange ideas and experiences
![](/i/fill.gif) |
![](/i/fill.gif) |
The INI equivalent to +C on the command-line is:
Continue_Trace=On
You should use this in the INI if you have removed (done something else
with) the previosly rendered frames, ie. they no longer exist in the
output path:
Subset_Start_Frame=45
Subset_End_Frame=90
Example frame numbers, of course. Also good for partial animations to
check things out, etc.
> Alan
mailto://inversez@aol.com?Subject=PoV-News
![](/i/fill.gif) |
