POV-Ray : Newsgroups : povray.windows : Continuing a render Server Time
1 Apr 2026 03:01:53 EDT (-0400)
  Continuing a render (Message 1 to 3 of 3)
Subject: Continuing a render
Date: 19 May 1999 22:35:52
Message: <374366F6.FF31303A@tsn.cc>
How do I go about continuing a render I have previously halted?  I was
working on an animation when a storm started so I stopped the render.
When I tried restarting (using current.ini) the render began from
scratch.
Subject: Re: Continuing a render
Date: 20 May 1999 01:09:26
Message: <37438a44.33690058@news.povray.org>
On Thu, 20 May 1999 11:35:50 +1000, Steven Jones <ste### [at] tsncc>
  From the editor window press ALT+C to bring up the Render Settings
dialog box (there's toolbar icon that does the same thing). Enter '+c'
(without the apostrophe marks) in the Command Line box to resume
trace. An alternative is to create your own .ini with these command
line options already in it. The +c option and most others can be
overridden from the Render Settings dialog box.
Alan
news.povray.org - where POV-Ray enthusiasts from around the world
                - get together to exchange ideas and experiences
Date: 20 May 1999 03:31:09
Message: <3743AC23.C596D1D3@aol.com>
The INI equivalent to +C on the command-line is:
 Continue_Trace=On
You should use this in the INI if you have removed (done something else
with) the previosly rendered frames, ie. they no longer exist in the
output path:
 Subset_Start_Frame=45
 Subset_End_Frame=90
Example frame numbers, of course. Also good for partial animations to
check things out, etc.
> Alan
 mailto://inversez@aol.com?Subject=PoV-News
