Subject: Re: Changing the images directory
Date: 9 May 1999 18:55:47
Message: <37360463.0@news.povray.org>
Inside the tool menu up the editor you'll see an "Edit povray.ini"
entry. Once inside look for a line beginning by Output_File_Name = (a path).
Replace that path by whatever you like better.
JM
>Does anyone out there know how to change the default output directory? I>tried searching the registry but no luck.
