POV-Ray : Newsgroups : povray.windows : How do I create .TGA image Server Time
20 Mar 2026 08:36:53 EDT (-0400)
  How do I create .TGA image (Message 1 to 3 of 3)
Subject: How do I create .TGA image
Date: 5 Dec 1998 01:30:32
Message: <36697316.51F2@mozart.inet.co.th>
Hi!
     Newbie here. I'm using the latest Windows version with Windows 95.
I'm working through the tutorial/documentation. In
the section for Height Fields, you first create an image in .TGA
"Targa" format. My images are all in Windows Bitmap (.BMP) format.
     How do I change the format to .TGA? I was under the impression that
.TGA was a native POV-RAY image format. Is there a setting or .INI file
to modify? Need help here. Please send an email reply to:
can### [at] mozartinetcoth
     I'll try to check the newsgroup as often as I can.
Thanks in advance.
James Cannon
mailto:can### [at] mozartinetcoth
http://www.inet.co.th/cyberclub/cannon
Subject: Re: How do I create .TGA image
Date: 5 Dec 1998 06:14:50
Message: <3669150B.F01F6AC3@pacbell.net>
Choose "edit master povray.ini" from the tools menu
and add the following line anywhere in the file:
Output_File_Type = t
Ken Tyler
James Cannon wrote:
> Hi!
> Thanks in advance.
> James Cannon
Date: 5 Dec 1998 13:10:11
Message: <36697703.0@news.povray.org>
If you want to create a tga for a height field you need to convert your bmps
to tga in paint shop pro or corel draw or photoshop or any image conversion
program
Mick
James Cannon wrote in message <366### [at] mozartinetcoth>...
>Hi!
>Thanks in advance.
>James Cannon
