POV-Ray : Newsgroups : povray.windows : WARN: POV-Ray 3.1 Official Release Server Time
13 Mar 2026 07:34:05 EDT (-0400)
  WARN: POV-Ray 3.1 Official Release (Message 1 to 1 of 1)
Subject: WARN: POV-Ray 3.1 Official Release
Date: 24 Sep 1998 09:04:11
Message: <360a345f.12892538@194.174.214.10>
Warning
The POV-Ray 3.1 Official release does not work correctly with Moray
For Windows. Specifically POV-Ray will not render the file that Moray
requests it should render. Instead POV-Ray always renders the last
manually (in POV-Ray) rendered file.
If you are working on a scene you can workaround this by loading the
INI or POV script into POV-Ray and rendering (Alt-G) it once. You must
then close the script window. After that POV-Ray will always render
this file when Moray requests a render.
When you change MDL files or when you go into the Texture Editor to do
a preview, you will need to repeat the above procedure.
This is a POV-Ray bug that has cropped up in the official release
only. The Beta6 worked fine. We have no control over this behaviour.
We have reported it and as soon as we know more we will post it here.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
