Under the Insert menu, in the Animation
Popup menu there is a "clock". When I inserted
it, all I got was a // FIX-ME message. So that
gave me an idea, I began work on a clock animation
(acually a clock). The hour hand moves from 4 to
5 and the minute hand moves all around. Here is
the code (it will probably need some fixing before
you - if you - use it in POV-Ray):
// Clock Animation for POV-Ray
// David Young
background { < 0, 0, 0> }
location <-5, -8, 7>
angle 68
sky <0, 0, 1>
look_at <0.5, 2, 4>
light_source { <15, -15, 15> <1, 1, 1> }
union { // Min Hand
box {
<-1, -1, -1>, <1, 1, 1>
scale <0.3, 0.125, 1.0>
translate <0.0, 0.6, 5.5>
prism {
linear_sweep
linear_spline
-1.0,0.0
4
<-1.0, -1.0>,
<1.0, -1.0>,
<0.008493, -0.008493>,
<-1.0, -1.0>
rotate -x*90
rgb <0.2, 0.2, 0.2>
scale <0.5, 1.0, 0.25>
rotate 90.0*x
translate <0.0, 0.75, 7.25>
rgb <0.2, 0.2, 0.2>
translate -4.5*z
rotate clock*360*y
translate 4.5*z
union { // Hour_Hand
box {
scale <0.3, 0.125, 0.6>
translate <0.0, 0.625, 5.1>
prism {
linear_sweep
linear_spline
-1.0,0.0
4
<-1.0, -1.0>,
<1.0, -1.0>,
<-1.0, -1.0>
rotate -x*90
scale <0.7, 1.0, 0.25>
rotate 90.0*x
translate <0.0, 0.75, 6.5>
rgb <0.2, 0.2, 0.2>
translate <0, -0.25, -4.5>
rotate (120+(clock*30))*y
translate 4.5*z
cylinder {
<0,0,1>, <0,0,0>, 1
rgb <0.2, 0.2, 0.2>
scale <0.5, 0.5, 0.6>
rotate -90.0*x
translate <0.0, 0.25, 4.5>
difference { // Clock
union {
cylinder { // Clock Body
<0,0,1>, <0,0,0>, 1
scale 4.0
rotate -90.0*x
translate 4.5*z
superellipsoid { // Clock Base
<0.4, 0.3>
scale <4.5, 1.5, 0.5>
translate <0.0, 2.1, 0.5>
torus { // Clock Front
1.75, 0.25 rotate -x*90
scale <2.1, 2.1, 2.0>
rotate -90.0*x
translate 4.5*z
torus { // Clock Back
1.85, 0.15 rotate -x*90
scale <2.05, 2.05, 2.0>
rotate -90.0*x
translate <0.0, 4.0, 4.5>
cylinder {
<0,0,1>, <0,0,0>, 1
scale <3.15, 3.15, 1.0>
rotate -90.0*x
translate <0.0, -0.25, 4.5>
rgb <0.9, 0.9, 0.2>
finish {
ambient 0.2
diffuse 0.7
brilliance 4.0
phong 0.75
phong_size 80.0
roughness 0.1
metallic 1.0
union { // Hour Dots
cylinder { // Hour Dot1
<0,0,1>, <0,0,0>, 1
scale <0.25, 0.25, 0.1>
rotate -90.0*x
translate <-1.375, 0.625, 6.88157>
cylinder { // Hour Dot2
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <-2.38157, 0.625, 5.875>
cylinder { // Hour Dot3
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <-2.75, 0.625, 4.5>
cylinder { // Hour Dot4
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <-2.38157, 0.625, 3.175>
cylinder { // Hour Dot5
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <-1.375, 0.625, 2.11843>
cylinder { // Hour Dot6
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <0.0, 0.625, 1.75>
cylinder { // Hour Dot7
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <1.375, 0.625, 2.11843>
cylinder { // Hour Dot8
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <2.38157, 0.625, 3.125>
cylinder { // Hour Dot9
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <2.75, 0.625, 4.5>
cylinder { // Hour Dot10
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <2.38157, 0.625, 5.875>
cylinder { // Hour Dot11
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <1.375, 0.625, 6.88157>
cylinder { // Hour Dot12
<0,0,1>, <0,0,0>, 1
rotate -90.0*x
translate <0.0, 0.625, 7.25>
rgb <0.2, 0.2, 0.2>
