![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Recently POV-Ray crashed will I was trying to render a
scene. So,
I restarted the computer and loaded POV-Ray again, and when
I tryed
to run the demo (to see if it was becuase of the scene), but
it still crashed.
The Messages screen gets to:
Redirecting Options
Warning Stream to console.......On
then a dialog comes up with the title Pvengine, and
reads:
This program has performed an illegal operation
and will be shut down.
If the problem persists, contact the program
vendor.
fallowed by a textbox with:
PVENGINE caused a stack fault in module <unknown> at
0000:00000003.
Registers:
EAX=00000000 CS=0137 EIP=00000003 EFLGS=00010202
EBX=00000001 SS=013f ESP=00a9ff08 EBP=00000000
ECX=0d000000 DS=013f ESI=00000000 FS=2757
EDX=00000000 ES=013f EDI=00000000 GS=0000
Bytes at CS:EIP:
00 65 04 70 00 16 00 dd 13 65 04 70 00 65 04 70
Stack dump:
00401012 0044c5f5 0046013f 00a9ffc8 004d1690
00a9ff36 fffffff4 00000000 006e1104 00000009
00000000 00000001 00a9ffc8 00000003 00000001
00000000
Next, I reinstalled POV-Ray with the newest version
(which was only 3.02, and I had 3.01 [or something like
that]). This also failed.
I really enjoyed the program, so this is very
disappointing,
I hope you can help.
David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
K.Tyler,
Under "Render" in the menu bar you will find a
"Run Demo", that is what I was talking about.
POV-Ray crashes on any file I render. The reason I
used the demo was because it should work, (it was
made to be rendered with the program).
David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Check the settings for max trace levels it must be between 5 and 15 for no crashes (on my 'puter anyway!!)
Date: 23 Aug 1998 02:04:10
Message: <35DFA2B3.74085166@mailexcite.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> scene. So,
> I tryed
> it still crashed.
> Redirecting Options
> reads:
> vendor.
> 0000:00000003.
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> 00000000
> disappointing,
> David Young
The only good politician is a dead politician !!
Politics or religion = corruption and true evil.
Believe 1% of what you see or hear.
The laws that politicians make are mostly bad laws,
we'd do far better without them - the politicians AND their laws.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> scene. So,
> when
> I tryed
> but
> it still crashed.
> Redirecting Options
> reads:
> vendor.
> at
> 0000:00000003.
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> 00000000
> disappointing,
> David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am sure that it is not the fault of scene, because it
crashes rendering any scene. If there is a problem,
syntax error or if I try to render a blank page, it still
crashes - but with an 'invalid page fault'. Can anyone
help me, or tell me where I can find help. I would really
like to get back to Ray-tracing.
David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> David Young
You really need to run it under a debugger to see where
in the code the error occurs, I think.
Dan
http://www.flash.net/~djconnel/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am just about ready to try anything (even
install the DOS version), so if you could tell me
where to find a debugger to use, I would be
very appriciative.
David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try doing a full uninstall, then install beta 6 from
ftp://ftp.povray.org/pub/povray/beta/beta3.1-6/povwin31.exe
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you so much! It worked! Plus,
I really like the new interface (although
it kinda looks like MicroSoft IE).
David Young
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
