POV-Ray : Newsgroups : povray.unofficial.patches : failed renders v1.1+OS X 10.3.8 Server Time
28 Sep 2024 18:13:28 EDT (-0400)
  failed renders v1.1+OS X 10.3.8 (Message 1 to 3 of 3)
Subject: failed renders v1.1+OS X 10.3.8
Date: 11 Mar 2005 16:55:00
Message: <web.423212f6db227cfafcb3d43f0@news.povray.org>
Have just started looking at MPOV but any Render commands fail with the
message "Init Error: Failed to chdir to '/Applications/2D
path."
I am new to POVRay/MPOVRay but should mention POVRay runs OK.
Any suggestions?
Subject: Re: failed renders v1.1+OS X 10.3.8
Date: 12 Mar 2005 02:43:41
Message: <1gtaybk.n72q451e4saeaN%yvo.s@gmx.net>
> applications∞/MacMegaPOV Mach-0 1.1/scenes/' while determining output
> path."
This indicates that you are using the Mach-O version.
Simply remove '∞' from your folder name and it will work.
Or use the Carbon version which will run like POVRay.
Cheers,
Yvo
MegaPOV at:  http://megapov.inetart.net
MacMegaPOV at:  http://users.skynet.be/smellenbergh
E-mail: yvo### [at] gmxnet
Date: 12 Mar 2005 16:55:00
Message: <web.423364dbb55dc2d4fcb3d43f0@news.povray.org>
Many thanks,
removing the special characters from the directory name solved the
problem.
Patrick
> > path."
> Cheers,
> Yvo
