POV-Ray : Newsgroups : povray.unofficial.patches : #let keyword(was: Previews of Ice Planet...) Server Time
23 Mar 2026 17:39:41 EDT (-0400)
  #let keyword(was: Previews of Ice Planet...) (Message 16 to 25 of 35)
Subject: Re: #let keyword(was: Previews of Ice Planet...)
Date: 3 Sep 2000 20:52:04
Message: <chrishuff-F17AC1.19534403092000@news.povray.org>
In article <slr### [at] tealhhjpat>,
hjp### [at] SiKituwsracat (Peter J. Holzer) wrote:
> I would prefer if no keyword was necessary at all, just
>     # a = a + 5
> I think this should be possible with minor changes in the parser, since
> keywords cannot be used as variable names anyway.
That might be quite possible...but you should always use upper case to
avoid name conflicts, since new keywords are always lower case. :-)
It also looks like it might be easy to allow semicolons after every
assignment, something that I wish POV already did.
Christopher James Huff
Date: 3 Sep 2000 21:35:44
Message: <39b2fc70$1@news.povray.org>
In article <slr### [at] tealhhjpat> ,
>     # a = a + 5
I have to admit, I kind of like this idea ... and it does not add a
additional symbol to the scene language.
    Thorsten
Date: 3 Sep 2000 22:06:07
Message: <chrishuff-9358DC.21074603092000@news.povray.org>
In article <39b2fc70$1@news.povray.org>, "Thorsten Froehlich"
<tho### [at] trfde> wrote:
> >     # a = a + 5
I think it would be possible by adding a boolean "Modify_Only" parameter
to the Parse_Declare() function(to tell it whether to create a new
variable or give an error if given an undefined symbol), and add a call
to Parse_Declare() here, replacing the "UNGET EXIT" that is there now:
    OTHERWISE
       Parse_Declare(TRUE);
    END_CASE
  END_EXPECT
Most of the same code from the #set patch could be reused for this, for
modifying the most local variable, just check the Modify_Only parameter
instead of the token.
I just finished making these modifications, I haven't tested it yet
though...it might blow up in my face.
Date: 3 Sep 2000 22:21:30
Message: <39b3072a@news.povray.org>
There are programming languages like this out there? <shudder>
Date: 3 Sep 2000 22:59:48
Message: <chrishuff-0F96DD.22012703092000@news.povray.org>
In article <chrishuff-9358DC.21074603092000@news.povray.org>, Chris
Huff <chr### [at] maccom> wrote:
> I think it would be possible by...
Well, it isn't that easy. :-(
I will take a closer look, but I don't really understand much of the
parser code.
Date: 4 Sep 2000 00:18:14
Message: <39B1FEFE.BF7675DE@pacbell.net>
The example he gave is not very different than what we had in
POV-Ray v1.0.
Date: 4 Sep 2000 02:28:42
Message: <39B3400C.F5C3D553@skynet.be>
Some MS-DOS versions of the POV-Ray 3.1 betas used to do that.  Dunno
why it has been removed.
Fabien.
Date: 4 Sep 2000 06:26:36
Message: <39b378dc$1@news.povray.org>
Peter J. Holzer <hjp### [at] sikituwsracat> wrote:
:     # a = a + 5
  A semi-colon at the end would be nicer.
Date: 4 Sep 2000 06:41:06
Message: <39b37c42@news.povray.org>
I like the keyword (and the concept). It is short and clear in its meaning
(imho).
Povingly,
Philippe
Date: 4 Sep 2000 10:33:56
Message: <39B3B53A.38EEA979@free.fr>
What about #eval if not used elsewhere ?
	(okay, one letter longer)
*** Nicolas Calimet
*** http://pov4grasp.free.fr
