POV-Ray : Newsgroups : povray.unofficial.patches : Announce: SkyPOV 0.1 Server Time
7 Jul 2026 02:49:16 EDT (-0400)
  Announce: SkyPOV 0.1 (Message 6 to 15 of 65)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Announce: SkyPOV 0.1
Date: 3 Nov 2000 01:04:09
Message: <3a025559$1@news.povray.org>
Chris Huff wrote in message ...
>In article <8FE01D1B3markwagner17gtenet@204.213.191.228>,
>mar### [at] gtenet (Mark Wagner) wrote:
>> Features that might make a future version:
>>  * Colour curve post-processing to replace the infinite-light hack
>I am going to make a post_process filter which uses a spline to adjust
>color values...is this what you are talking about?
Yes.
>>  * Random rendering order
>You mean it picks a random pixel each time? Another thing that might be
>nice: some kind of "progressive" antialiasing, that renders the image
>without antialiasing and then makes several "refinement" passes.
That's going to be part of the system, since I can't do antialiasing with
just one pixel.
>>  * A polynomial parser to allow polys to be written as "3x^5+2xy+z-1"
>>  etc.
>Couldn't you use isosurface functions? I haven't had a look at your
>patch yet, so I don't really know what this is for...
I don't have it implemented yet, but this will be for the "poly" object
type.  It's much easier to enter a formula for a 7th-order polynomial as a
formula than as a string of a hundred coefficients.
>>  * Improved "quality" command-line options
>I hope command line options aren't necessary for this...you should be
>able to specify all options in the scene file. Or are you talking about
>changing the "Render Quality" option syntax?
Yes, render quality options.  I'm going to make it possible to turn specific
things on and off -- specifically, these will be available in version 0.2:
 +QQ = use quick colors
 +QA = use area lights -- cancels +QF
 +QF = use ambient only -- cancels +QA, +QM
 +QS = calculate shadows
 +QM = use reflection -- cancels +QF
 +QL = use refraction
 +QN = use normals
 +QV = use media?
>>  * Improved splines
>I would suggest using one of the spline patches...less duplicate code,
>more standardized, etc...
This is going to be an improvement on the spline{} syntax.
Mark
Date: 3 Nov 2000 01:14:03
Message: <3a0257ab@news.povray.org>
Mark Wagner wrote in message
<8FE01D1B3markwagner17gtenet@204.213.191.228>...
>Announcing.....SkyPOV 0.1!
A Windows binary is available at:
http://www.geocities.com/rengaw03/download/wskypov.zip
Mark
Date: 3 Nov 2000 04:06:42
Message: <3A02B82F.1A446F24@chesapeake.net>
I tried to use the link provided but geocities said
that page was not available. I tried .../rengaw03/download/
and HAL invited me to go back.
sniff..... I so wanted to see this version.... sniff
> Mark
Date: 3 Nov 2000 09:46:00
Message: <chrishuff-AE6B1C.09490803112000@news.povray.org>
In article <3a025559$1@news.povray.org>, "Mark Wagner"
> Yes.
I will send you the code as soon as it is tested.
> just one pixel.
Good. :-)
> object type.  It's much easier to enter a formula for a 7th-order
> polynomial as a formula than as a string of a hundred coefficients.
Oh, I thought this was for something else...this seems rather redundant,
since you can just use isosurfaces to do the same thing, and
often(usually?) with faster rendering.
Oh...
Ok, what improvements are you thinking of? More spline types, the
ability to choose what kind of spline to use at evaluation time?
By the second, I mean something like this:
#declare Spline = spline {...the usual spline stuff...}
#declare Val1 = Spline(XVal);
#declare Val2 = Spline(XVal, cubic_spline);
#declare Val3 = Spline(XVal, linear_spline);
Another wild idea that might be useful: allow splines to be used as
color maps. :-)
Christopher James Huff
Date: 4 Nov 2000 00:41:54
Message: <3A03A18D.FDFBCBF0@peak.edu.ee>
Ditto
Margus Ramst
Date: 4 Nov 2000 01:23:16
Message: <3a03ab54$1@news.povray.org>
>> Yes.
Thanks!
>Oh...
I'm going to be removing the limit on the number of points in a spline, and
making it possible to use the points from one spline as the basis for
another spline, like:
#declare Spline2 = spline{ Spline 1,<2,2,2> etc.}
Right now you can't do that.
Mark
Date: 4 Nov 2000 01:27:25
Message: <3a03ac4d@news.povray.org>
Margus Ramst wrote in message <3A03A18D.FDFBCBF0@peak.edu.ee>...
>Ditto
How odd.  I just downloaded it successfully from that address.  Was it
giving you a "file not found" error, or some other error message?
Mark
Date: 4 Nov 2000 01:43:29
Message: <3a03b011$1@news.povray.org>
Try the links from my POV-Ray downloads page to see if they work for you.
http://www.geocities.com/rengaw03/povray.html
Mark
Date: 4 Nov 2000 02:54:44
Message: <3A03C0CC.E0F7CBFC@peak.edu.ee>
Got it.
As far as I know Geocities doesn't like direct download links originating from
non-geocities addresses. Since your home page is also at Geocities, a link from
there will work.
Margus Ramst
Date: 4 Nov 2000 06:10:59
Message: <chrishuff-DDBC53.06140904112000@news.povray.org>
In article <3a03ab54$1@news.povray.org>, "Mark Wagner"
> Thanks!
I'm having a hard time getting it to work though...I suspect the problem
is in my parsing code, though I'm not sure why it is misbehaving.
Anyway, this is the syntax I am planning to use(I am currently working
on the first form):
curves {rgb RED_SPLINE, GREEN_SPLINE, BLUE_SPLINE}
curves {red RED_SPLINE}
curves {green GREEN_SPLINE}
curves {blue BLUE_SPLINE}
curves {gray GRAY_SPLINE}
(got a better name for the last one? "all"?)
When I add color space conversion filters, you will be able to adjust
other types with these filters(convert to another color space, modify
the correct channel, convert back to rgb).
There is a limit? I hadn't noticed...
> and making it possible to use the points from one spline as the basis
> for another spline, like:
I noticed the Parse_Spline() function had the ability to take an
identifier to create a copy of the spline, but also had a bug which made
that useless when no new points were defined. I think it was intended to
work the way you describe, allowing new points to be inserted.
Also, it would be useful if you could access the control points, with
functions that behave similar to the array functions and an array-like
syntax.
