POV-Ray : Newsgroups : povray.unofficial.patches : i_dat3d & *.df3 Server Time
7 Apr 2026 16:10:58 EDT (-0400)
  i_dat3d & *.df3 (Message 1 to 10 of 11)
Subject: i_dat3d & *.df3
Date: 28 Jul 2000 15:52:34
Message: <8F7FD9A61seed7@204.213.191.228>
1. Is there a limit to the size of a df3 file that can be used with
"i_dat3d"? A 100^3 file parses ok. A 150^3 file gives the error:
#declare Func={"data_3d_3",<1> library "i_dat3d",
"pytest.df3",<150,150,150,5>  <----- Error
..\box_erode.pov:62 error: out of memory, cannot allocate -4764052 bytes
for Lib.
2. All I get when using a df3 with "i_dat3d" is no object or a white box.
Can somebody show me the function working with spiral.df3 (from the
standard pov).
Ingo
Subject: Re: i_dat3d & *.df3
Date: 28 Jul 2000 15:56:00
Message: <slrn8o3q2n.o8l.ron.parker@fwi.com>
>standard pov).
Is i_dat3d supposed to work with df3 files?  I thought it used a more
human-readable format.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 28 Jul 2000 16:11:40
Message: <8F7FE26EBseed7@204.213.191.228>
Yes, I think David Sharp added that part.
Ingo
Date: 28 Jul 2000 16:40:25
Message: <slrn8o3sm0.oba.ron.parker@fwi.com>
Why is it necessary?  Can't you just use the pigment function with a
pigment defined by the df3 file?
Date: 28 Jul 2000 17:02:34
Message: <8F7FE8B08seed7@204.213.191.228>
Can't answer the first question. For the second one, just wanted to
compare the speed and output of both methods.
Ingo
Date: 28 Jul 2000 17:58:29
Message: <chrishuff-320CA7.16591628072000@news.povray.org>
In article <8F7FE26EBseed7@204.213.191.228>, ing### [at] homenl (ingo)
I'm not sure, but I think all that was added was the ability to use an
array as i_dat3d input. I think you have to use a pigment function to
get df3 files to be useable in isosurfaces.
Date: 28 Jul 2000 18:16:43
Message: <8F80366Dseed7@204.213.191.228>
From the doc for WinMegaPov:
The final vector <32,32,16,0> contains the parameters for the i_dat3d
library. : <L0,L1,L2,L3>
<snip>
sample parameters.
from the DF3 file's header and just ignore the sample parameters found in
the llibrary parameter vector <Nx,Ny,Nz,6>
Ingo
Subject: Bug: Re: i_dat3d & *.df3
Date: 28 Jul 2000 18:56:57
Message: <39820fb9$1@news.povray.org>
ingo <ing### [at] homenl> wrote in message
news:8F7FD9A61seed7@204.213.191.228...
> for Lib.
The cause is a bug in the initialization.
The MegaPOV 0.5 source level fix is to change line 1216 in isosurf.c from
        char df3header[6];
to
        unsigned char df3header[6];
Date: 28 Jul 2000 19:16:00
Message: <chrishuff-83377C.18164628072000@news.povray.org>
In article <8F80366Dseed7@204.213.191.228>, ing### [at] homenl (ingo)
...snip...
I stand (well, sit) corrected.
Hmm, does the interpolation of the i_dat3d library differ from the df3
pattern interpolation?
Date: 28 Jul 2000 19:27:29
Message: <398216e1$1@news.povray.org>
The df3 reading was added to the dat3d/dat2d functions just because
it seemed logical that as long as there already existed a POV 3d data
format, the dat3d/2d functions should be able to use it.
