POV-Ray : Newsgroups : povray.unofficial.patches : An updated povr tarball for Unix/Linux. b0bcf6c0 Server Time
14 Oct 2026 14:11:00 EDT (-0400)
  An updated povr tarball for Unix/Linux. b0bcf6c0 (Message 1 to 12 of 12)
Subject: An updated povr tarball for Unix/Linux. b0bcf6c0
Date: 26 Apr 2021 07:42:51
Message: <6086a73b$1@news.povray.org>
Ref:
http://news.povray.org/povray.binaries.programming/message/%3C6086a32c%40news.povray.org%3E/#%3C6086a32c%40news.povray.org%3E
Web message: 6086a32c@news.povray.org
A note on this release of the povr branch of POV-Ray. In reworking the
autotools build I pulled all the decades old automatic optimizations.
This means for good performance you have to specify the optimizations
during the configuration.
A collection of configuration examples can be found in the INSTALL.txt
files, but for many this one enabling link time optimization will work:
./configure -q COMPILED_BY="me" \
CXXFLAGS="-std=c++17 -O3 -ffast-math -march=native" \
--enable-lto LDFLAGS="-s"
Bill P.
Subject: Re: An updated povr tarball for Unix/Linux. b0bcf6c0
Date: 26 Apr 2021 08:40:01
Message: <web.6086b3b6c0bd773c79819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> Ref: {...}
had a v quick look, pleased the INSTALL isn't just the usual generic.  will try
a no-SDL install in the coming days.  thank you.
regards, jr.
Date: 28 Apr 2021 12:30:00
Message: <web.60898cfdc0bd773c79819d986cde94f1@news.povray.org>
tried building but got an error.
regards, jr.
using:
  ./configure \
  --enable-silent-rules \
  --without-libsdl \
  --without-libsdl2 \
  --disable-no-lc-identifiers \
  --with-x \
  --build=${ARCH}-slackware-linux \
  COMPILED_BY="$POVRAY_BUILDER"
edited output from extracting archive thru 'make':
povray-3.8.0-x.povr_b0bcf6c0/
POV-Ray (povr) 3.8.0-x.povr_b0bcf6c0 has been configured.
Built-in features:
  I/O restrictions:          enabled
  X/SDL Window display:      enabled (sdl not available)
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
  Unsupported image formats: -
Compilation settings:
  Build architecture:  x86_64-slackware-linux-gnu
  Built/Optimized for: x86_64-slackware-linux-gnu
  Compiler vendor:     gnu
  Compiler version:    g++ 5.5.0
  Preprocessor flags (CPPFLAGS):
    -pthread -I/usr/include/OpenEXR -I/usr/include
  Compiler flags (CXXFLAGS):
    -pipe -w -fno-enforce-eh-specs -std=c++11 -march=native -mtune=haswell -O2
    -fPIC -pthread
  Linker flags (LDFLAGS):
    -L/usr/lib
  Libraries (LIBS):
    -lXpm -lSM -lICE -lX11 -lIlmImf -lIlmImf -lImath -lHalf -lIex -lIexMath
    -lIlmThread -pthread -lIlmThread -ltiff -ljpeg -lpng -lz -lrt -lm -pthread
make  all-recursive
make[1]: Entering directory '/tmp/POV/povray-3.8.0-x.povr_b0bcf6c0'
Making all in source
make[2]: Entering directory '/tmp/POV/povray-3.8.0-x.povr_b0bcf6c0/source'
  CXX      povmain.o
  CXX      backend/bounding/boundingtask.o
  CXX      backend/control/messagefactory.o
  CXX      core/math/chi2.o
  CXX      core/math/hypercomplex.o
  CXX      core/math/jitter.o
In file included from core/math/jitter.cpp:37:0:
../source/core/math/jitter.h: In function ‘void
pov::Jitter2d(double, double, double&, double&)’:
../source/core/math/jitter.h:104:43: error:
‘rand’ was not declared in this scope
     jx = -0.5f + static_cast<double>(rand()) /
(static_cast<double>(RAND_MAX/((0.5)-(-0.5f))));
../source/core/math/jitter.h:104:69: error:
‘RAND_MAX’ was not declared in this scope
Makefile:1309: recipe for target 'core/math/jitter.o' failed
make[2]: *** [core/math/jitter.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/tmp/POV/povray-3.8.0-x.povr_b0bcf6c0/source'
Makefile:707: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/tmp/POV/povray-3.8.0-x.povr_b0bcf6c0'
Makefile:500: recipe for target 'all' failed
make: *** [all] Error 2
Date: 28 Apr 2021 15:01:30
Message: <6089b10a$1@news.povray.org>
> using:
>    ./configure \
>    --without-libsdl \
>    --without-libsdl2 \
>    --with-x \
Thanks for trying. The --enable-silent-rules is probably not needed
unless you've somehow overridden the tarball shipped default (...one can
do it by various methods (the reason the enable and disable are always
both available as configure options), but it is not common).
Of course my compiles with your configure (and some C++ compiler
settings you must be picking up somewhere by env var or something) and
all work. I can't reproduce so my best guess...
With the jitter.h issue could you try changing the two calls to rand()
to std::rand() (a) and then at the top of jitter.h just after the
comment about c++ variants of c includes add an include of cstdlib so it
looks like:
// C++ variants of C standard header files
#include <cstdlib>
Then try the make (the compiles) again?
(a) - What those always should have been I think and the first thing I
see which might be wrong. I see on searching a few more bare rand()
calls sitting in the code too which might also cause you trouble
compiling if this the issue (some in pattern.cpp). Hmm, wonder why those
not an issue before for you if so...
Bill P.
Date: 28 Apr 2021 15:20:00
Message: <web.6089b512c0bd773c79819d986cde94f1@news.povray.org>
hi,
> looks like:
> #include <cstdlib>
tomorrow night.  factoid - when the alpha.10064268 was published, missing
'std::' prefixes were a problem.  cheers.
regards, jr.
Date: 29 Apr 2021 10:20:00
Message: <web.608ac032c0bd773c79819d986cde94f1@news.povray.org>
hi,
> looks like:
> #include <cstdlib>
worked a treat, install tonight.  thanks.  patch attached, in case other Linux
users have use for it.
regards, jr.
Download 'patch20210428.txt' (1 KB)
Date: 1 May 2021 16:10:00
Message: <web.608db561c0bd773c79819d986cde94f1@news.povray.org>
> worked a treat, install tonight. ...
have trouble due to one of the includes.  scene + output attached; 'logo.inc' is
symlinked into povr's include dir.
regards, jr.
Download 'povr.txt' (3 KB)
Date: 1 May 2021 17:56:45
Message: <608dce9d$1@news.povray.org>
> regards, jr.
Thanks!
First, in include/shapes.inc - before installing in a directory, try
adding an include to transforms.inc just below the include for
functions.inc so the includes at top look like:
#include "functions.inc"  // <-- Dependency on povr's f_supertorus()
#include "transforms.inc" // <-- Several transform macros are used
In my cut down set of core includes, I tried to have only the necessary
includes to save on parsing time and core maintenance. I've gotten it
wrong(1).
(1) - I had it in my head if I had tests including each of the shipped
includes, I'd pick up any dependencies, but you have to actually call
each macro and I don't yet, which means probably other include and macro
issues are lurking. :-(  More include macro self testing required I
guess!
Bill P.
Date: 2 May 2021 05:00:00
Message: <web.608e6975c0bd773c79819d986cde94f1@news.povray.org>
hi,
> > have trouble due to one of the includes.  ...
> Thanks!
ok, that solved the problem.  cheers.
> ... which means ... More include macro self testing required I
> guess!
if test parameters can be "presented" as sets, stored in an array of 'array
mixed' for example, foreach might be of help automating the running.
(if there's (small) help I can provide, ask)
regards, jr.
Date: 13 May 2021 08:54:12
Message: <609d2174$1@news.povray.org>
On 4/26/21 7:42 AM, William F Pokorny wrote:
> Ref:
In working with Tor Olav's idea for a more accurate VAngle macro, I
discovered the lower case identifier checking(1) is far too expensive
when making a million calls to a macro with internal #local identifiers.
For now, I recommend configuration with --disable-no-lc-identifiers, if
running scenes calling macros with internal identifiers a great many times.
Bill P.
(1) - I'm using c++11 regex at the moment. I've noted some complaints
about performance of std regex, but whether it's that or just how our
macros work in being re-read / interpreted on each call - I don't know.
Might be significant expense is unavoidable and the case checking should
not be the default behavior.
Date: 13 May 2021 11:45:00
Message: <web.609d491dc0bd773c16086ed03f378f2@news.povray.org>
> > Ref:
ray.org%3E
> Bill P.
You seem to solve so many issues in that linux only branch, is there a chance
that some of those fix propagate to master or do they already? Sorry if this is
not what you were referring to at all, but  some unjustified overhead to the use
of separated pov macro files was mentioned numerous times by Clipka and
supposedly solved in his branch, just in case.
Date: 13 May 2021 16:20:30
Message: <609d8a0e@news.povray.org>
They don't get into v3.8 master today as it is not being updated for a
couple years. Where I believe fixes could be adopted more or less
directly by the v3.8 master branch, I make a point to publish them on
this news server or sometimes on github.
If mainstream work resumes, I have some hope the investigative
information on issues will be of help, if not always my code changes.
> Sorry if this is
I believe the v3.8 master branch, as it sits, has all Christoph's
completed macro performance enhancements. So my branch, hgpovray38 and
qtpovray have them too being based on that code - unless I've missed
something.
Bill P.
