POV-Ray : Newsgroups : povray.unofficial.patches : Megapov 1.2.1 Linux - Followup Server Time
28 Sep 2024 18:04:43 EDT (-0400)
  Megapov 1.2.1 Linux - Followup (Message 1 to 10 of 17)
Subject: Megapov 1.2.1 Linux - Followup
Date: 12 Sep 2005 11:19:20
Message: <43259c78$1@news.povray.org>
Follow-up promised after my remarks about quality of Megapov 1.2.1 release.
Problem: Megapov 1.2.1 as compiled by Christoph (binary download) or
compiled by myself (source download) using the default ./configure
settings, crashes and/or hangs my Athlon XP with Gentoo Linux 2.6.12.
Which scene ?
Halfway through projection.pov  and at approx 75% of the cube animation.
Its your hardware !!!!
No. Booted into memtest86+, let it run for a night, no problems.
Booted into XP (yes I have to admit, I still have a XP partition)
downloaded Megapov 1.2.1 for Win. All scenes rendered ok.
It's your kernel/glibc etc. !!
No. Got a free Suse 9.3 disk from a magazin, installed on free
partition: same errors. Installed new Gentoo 2005.1 release: same errors.
You run a patched version.
No. Downloaded stock versions of PovRay 3.6.1. and Megapov 1.2.1,
installed on empty partition and compiled using default settings.
Any progress ?
Yes. Recompiled with: ./configure --disable-optimiz  Slow as turtle, but
completed the scenes. Added, one-by-one, "O1" "-march=athlon-xp" "02"
"-fomit-frame-pointer" and finaly "O3" and "-ffast-math". I am currently
enjoying a stable version !!
Configured with:
./configure COMPILED_BY="Willem" --disable-optimiz
CXXFLAGS="-march=athlon-xp -ffast-math -O3 -fomit-frame-pointer -pipe"
CFLAGS="-O3 -march=athlon-xp -ffast-math -fomit-frame-pointer -pipe"
Anyone else using the unix version ??
Subject: Re: Megapov 1.2.1 Linux - Followup
Date: 12 Sep 2005 12:04:14
Message: <4325a6fe@news.povray.org>
	If I undestand your previous messages correctly, you get a buggy
binary while building with default configure options.  It would be quite
useful to know what are the default compiler flags that configure sets
for you to compare with those above.
	- NC
Date: 12 Sep 2005 12:15:01
Message: <web.4325a93f5d76c42f971e17950@news.povray.org>
So there is still a kernel panic when you run MegaPOV with any of those
kernels?
Date: 12 Sep 2005 12:23:03
Message: <4325ab67$1@news.povray.org>
> kernels?
On my machine, yes.
Date: 12 Sep 2005 12:45:01
Message: <web.4325af815d76c42f971e17950@news.povray.org>
> On my machine, yes.
Well, then you have found a kernel bug and should report it to the kernel
developers. The kernel should never crash no matter what an application
does. There is no reliable way of telling if there is a bug in MegaPOV or
not as long as the kernel crashes. Of course, it is likely possible to
modify MegaPOV to not trigger the kernel bug or work around it some other
way, but that does not imply there is a bug in MegaPOV at all.
Date: 12 Sep 2005 12:50:01
Message: <dg4bfb$kc3$1@chho.imagico.de>
Willem wrote:
> Any progress ?
If your compiler produces a faulty binary with one set of options and a
working one with a different set that's a bug in the compiler.
Both the binary version from the website (using -O3 -march=i586) and the
default options (here: -O3 -ffast-math -malign-double
-minline-all-stringops -m3dnow -march=athlon-xp -mtune=athlon-xp)
work without problems (both using unpatched gcc 3.4.3).
As Nicolas said it would be important to mention what the default
options are for you.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 12 Sep 2005 14:20:32
Message: <4325c6f0@news.povray.org>
Nope, not all code can handle all levels of optimisations well. Lets
assume, for the sake of argument, that Gcc 3.4.3 is stable, since we all
use it ;). Yet I know know numerous programs which can only be compiled
using special flags, or without any Ox-flag at all.
I did some physical modelling with a program called, p3d, which
generated completely different results when compiled with different
settings. This program too, like MegaPov, was dealing with floating
numbers which could differ only in order of magnitude like 1e-7.
Suddenly compiler option are not trivial anymore, although
theoretically, it should be just fine.
If I run ./configure without options the following flags are produced in
the Makefile:
CXXFLAGS =  -pipe -Wno-multichar -s -O3 -ffast-math -malign-double
Which are exactly the same flags you have.....
> the kernel developers.
Always look in the mirror first. Especially if you compile with
"-ffast-math". The compiler generates code which directly accesses the
FPU to perform i.e sin,cos operations en there is no checking for NaN of
Zero; this is responsibility of the programmer. Strange things can &
will happen !!
Anyway, interesting to see that all no-one (!) accepts the possibility
that the MegaPov distribution could contain a error. Although it most
probably does not contain serious bugs, Christoph does a great job here,
 not too many people use it on a linux-box, so there could always be
"something" if compiled on a different Unix-box. Yet all fingers pointed
directly at my hardware, my kernel, my compiler and my dog.
Was the problem itself or did I use foul language ?
So I restate my question: Is anyone using a self-compiled version of
MegaPov and does it run all supplied scenes without trouble ?
I Do !! My Megapov-version is, right now, happily processing,
yet-another-stupid ball-hits-block-animation.
Always willing to help out ;)
Date: 12 Sep 2005 16:33:23
Message: <4325e613$1@news.povray.org>
I have been following this for a while, so maybe this helps you understand a
bit better what you need to do.  While I respond to everything in your
message, the important part is in the last two paragraphs.
> use it ;).
Note that there are 166 bugs in 3.4.3 which were fixed in 3.4.4 alone.  Of
course, if gcc is buggy or not has nothing to do with the problem at hand.
Which is 99.9% of all cases indicates either a bug in the programs, the
compiler performing certain optimizations or a user misunderstanding the
proper configuration of compiler optimization options.  Of course, this also
Your statement, while being correct in the observation that certain compiler
options may influence floating-point precision (for various reasons, non of
which are bugs at all), has nothing to do with the problem at hand. In fact,
it shows a clear misunderstanding of the nature of the problem.
This is plain wrong, this is not what "-ffast-math" is about.  "-ffast-math"
is nothing more than shortcut to enable various generally non-IEEE/ISO
conforming floating-point optimizations (and the example you mention isn't
one of them).  And it has, just like all the things you mentioned so far,
> will happen !!
Nothing strange can happen, the behavior is complete deterministic (except
of certain generations of P1s, of course ;-) ) and completely predictable.
And this also has nothing to do with the problem at hand.
No, it is you who does not understand what many people have told you so far:
  Somehow you have run into a dead end and are now pushing against a wall,
not listing to anybody else who is trying to tell you to just turn around to
get out of the deadened and find a solution to your problem ;-)
Nobody can reproduce your bug and you cannot expect help if you refuse to
get a fixed kernel.  It has already been pointed out to you that you need to
get a fixed kernel first.  A kernel panic isn't pov's fault no matter how
you twist and turn it.
Once your kernel is fixed, one of two things can happen: Either MegaPOV
works, or you get a reasonable crash of MegaPOV without a kernel panic.  In
the former case you can just be happy, in the later you will need to come
back with a bug report.  The neat thing is once your kernel no longer
panics, and if there should indeed be a problem in MegaPOV, you can include
a stack trace and other relevant information along with your report.
	Thorsten Froehlich, POV-Team
Date: 12 Sep 2005 17:21:10
Message: <4325f146$1@news.povray.org>
Oops,
I clearly forgot to mention that I indeed was worried
about the system crash. Although the kernel served me well for months, I
discarded it and I switched to a "official" stable kernel,
recompiled Gcc & Glibc just for good measure. Nor more
system crashes as noted in my first post last week. The feedback was
right; a program crash should be handled by the OS.
That is why I promised to do a follow-up. I purposely installed two
clean distributions, with proper, stable, non-patched kernels.
Unfortunately the MegaPov behaviour persisted, but those collapses were
handled correctly by the O.S. I did not mention "system crashes" at all
in my follow-up.
Could you please explain? This could be exactly the problem we deal
with. MegaPov could have bugs; 1.2.1 is a bug-release, and the
./configure script could have generated compiler flags which uncovers
these bugs. Remember, ./configure is dynamic script, trying to make
educated guess to which compiler flags are best for your specific
Unix-box. Thats why I started hard-coding these flags, in order to make
sure I could produce a correct binary for my machine.
> (except of certain generations of P1s, of course ;-) ) and completely
> predictable. And this also has nothing to do with the problem at hand.
Sorry, joyfull language obscured the message: it is deterministic: it dies.
> far:  Somehow you have run into a dead end and are now pushing against a
> wall, not listing to anybody else who is trying to tell you to just turn
> around to get out of the deadened and find a solution to your problem ;-)
See first paragraph. I did address the kernel issue right away. I try to
be open-minded.
No-one has either confirmed, nor rejected the bug.
> ..include a stack trace....
I'd love to. I will google for a HowTo.
Are you realy sure about the --fast-math ? It is just so typical for
MegaPov, with all the physics code and the ininitesimal calculations
associated. I have seen so many physical simulations die because the
approximations were approaching Zero en there was just not enough
boudary checking..because there never is time/imagination to prevent
them all... I hated it too when wrote those programs.
Anyway, I try to cooperate :)
Date: 12 Sep 2005 17:29:12
Message: <4325f328@news.povray.org>
> in my follow-up.
Hmm, five hours ago you said something different ;-)
-------- Original Message --------
Date: Mon, 12 Sep 2005 18:23:03 +0200
Newsgroups: povray.unofficial.patches
 > kernels?
On my machine, yes.
