POV-Ray : Newsgroups : povray.unofficial.patches : HDR Output unrecognized Server Time
6 Apr 2026 20:08:16 EDT (-0400)
  HDR Output unrecognized (Message 1 to 8 of 8)
Subject: HDR Output unrecognized
Date: 15 Sep 2004 02:48:29
Message: <4147e5bd@news.povray.org>
Try this...
megapov A_file_of_your_choice.pov +fh
Do you get this message too?
Unrecognized output file format h.
The HDR file is fine... And I think it's a great feature :)
It's just the message that might cause some confusion.
Greetings :)
Thorsten
Subject: Re: HDR Output unrecognized
Date: 15 Sep 2004 04:40:01
Message: <ci8v1d$d9a$1@chho.imagico.de>
Thorsten wrote:
> Try this...
If this is supposed to be a bug report it misses *all* important
information.  This includes at least:
- MegaPOV version and platform
- complete text messages POV-Ray prints out.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 15 Sep 2004 05:08:36
Message: <41480694@news.povray.org>
Christoph Hormann wrote:
I'm sorry, Christoph. Please excuse.
MegaPOV 1.1 - Linux version.
Output:
Followed by the usual output.
Is this enough, or do you need the _real_ output?
Thorsten
Date: 15 Sep 2004 05:20:02
Message: <ci918q$dp9$1@chho.imagico.de>
> Output:
You you are interested in a comment on the matter that would be quite a
good idea.
Date: 15 Sep 2004 05:39:18
Message: <41480dc5@news.povray.org>
> good idea.
> Christoph
Here we go :)
One additional information:
At the moment I'm using a local install of MegaPOV 1.1.
megapov Blanko.pov +fh gives me this output:
megapov: cannot open the system configuration file
/usr/local/etc/megapov/1.1/povray.conf: No such file or directory
Persistence of Vision(tm) Ray Tracer Version MegaPOV 1.1/ based on Pov-RAY
3.6.1
 (g++ 3.4.1 @ i686-pc-linux-gnu)
This is an unofficial version compiled by:
 The POV-Ray Team(tm) is not responsible for supporting this version.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
  Chris Cason         Thorsten Froehlich  Nathan Kopp         Ron Parker
Contributing Authors: (Alphabetically)
  Steve Anger         Eric Barish         Dieter Bayer        Steve A.
Bennett
  David K. Buck       Nicolas Calimet     Aaron A. Collins    Chris Dailey
  Steve Demlow        Andreas Dilger      Alexander Enzmann   Dan Farmer
  Mark Gordon         Christoph Hormann   Mike Hough          Chris Huff
thmp11@linux-p4:~/Documents/Blanko> megapov Blanko.pov +fh
3.6.1
Bennett
  Kari Kivisalo       Lutz Kretzschmar    Jochen Lippert      Pascal
Massimino
  Jim McElhiney       Douglas Muir        Juha Nieminen       Bill Pulver
  Eduard Schwan       Wlodzimierz Skiba   Robert Skinner      Yvo
Smellenbergh
  Zsolt Szalavari     Scott Taylor        Massimo Valentini   Timothy Wegner
  Drew Wells          Chris Young
MegaPOV Contributing Authors: (Alphabetically)
  Christophe Bouffartigue  Thorsten Froehlich       Christoph Hormann
  Chris Huff               Jurjen                   Kari Kivisalo
  Nathan Kopp              Vahur Krouverk           William Pokorny
  Micha Riser              Wlodzimierz Skiba        Rene Smellenbergh
  Yvo Smellenbergh         Massimo Valentini        Thomas Willhalm
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
  ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.6, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 6b, Copyright 1998 Thomas G. Lane
  LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file: Blanko.pov (compatible to version 3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /home/thmp11/pov361/share/megapov-1.1
    /home/thmp11/pov361/share/megapov-1.1/ini
    /home/thmp11/pov361/share/megapov-1.1/include
    /home/thmp11/pov361/share/povray-3.6
    /home/thmp11/pov361/share/povray-3.6/ini
    /home/thmp11/pov361/share/povray-3.6/include
Output Options
  Image resolution 512 by 384 (rows 1 to 384, columns 1 to 512).
  Output file: /home/thmp11/Documents/Blanko/Blanko.hdr, 24 bpp (none)
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
  Clock value:    0.000  (Animation off)
  0:00:00 Parsing
  0:00:00 Creating bounding slabs
  0:00:00 Creating vista buffer
  0:00:00 Creating light buffers 2K tokens
Scene Statistics
  Finite objects:            2
  Infinite objects:          1
  Light sources:             1
  Total:                     4
  0:00:00 Displaying
Using 24 bit TrueColor visual
Using default window background
Mapping background image
  0:00:02 Rendering line 284 of 384, 2174 supersamples
  0:00:02 Postprocessing Phase 0, line 0
  0:00:02 Done Tracing
Render Statistics
Image Resolution 512 x 384
Pixels:           197120   Samples:          214512   Smpls/Pxl: 1.09
Rays:             214512   Saved:                 0   Max Level: 1/25
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                    28971            6072     20.96
Plane                           323465          107000     33.08
Sphere                           61275             850      1.39
Bounding Box                     20917           11904     56.91
Light Buffer                    435812          227965     52.31
Vista Buffer                    563515          441481     78.34
Calls to Noise:                   0   Calls to DNoise:              10
Shadow Ray Tests:            187712   Succeeded:                  1099
Smallest Alloc:                   9 bytes
Largest  Alloc:              786440 bytes
Peak memory used:            938295 bytes
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  2 seconds (2 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  2 seconds (2 seconds)
Thorsten
Date: 15 Sep 2004 05:52:49
Message: <414810f0@news.povray.org>
Thorsten wrote:
Oops... Copy/Paste error. My fault.
Another try:
3.6.1
Bennett
Massimino
Smellenbergh
Redirecting Options
Parsing Options
  Library paths:
Output Options
Tracing Options
  Quality:  9
  0:00:00 Parsing
Scene Statistics
  Finite objects:            2
  Infinite objects:          1
  Light sources:             1
  Total:                     4
  0:00:00 Displaying
Render Statistics
Thank you for your patience.
Thorsten
Date: 15 Sep 2004 06:10:01
Message: <ci9472$ea9$1@chho.imagico.de>
> 3.6.1
Ah, right at the beginning.  Note that isn't the usual place where this
message occurs when you use a format really not supported.  Will be
fixed in next version (although it's damn inconvenient in case the other
Thorsten is listening... ;-))
Date: 15 Sep 2004 06:15:10
Message: <4148162e@news.povray.org>
> Christoph
Thank you, Christoph :)
Thorsten
